What happened to the "digital amp revolution"?
Every so often someone does a demo where they have a live musical performance stop and a recording take over. If the room acoustics are proper no one notices.
You mean approximately like this?:
Does that meet the definition of high fidelity?
It meets MY OWN definition of HiFi just fine.
Funnily enough, by modern standards the system shown would not be considered "low distortion", nor does it manage 20Hz - 20KHz (it does do 26Hz - 40KHz though, including speakers). And the Amplifiers are emphatically NOT class D either.
Ciao T
My pictures don't look so nice like yours, but when after concert of Sergey Zadvodny (R.I.P.) we were sitting around the table I switched on record of the concert (tape, actually), and Sergey started speaking from the record, his concertmaster turned her head to real Sergey replying, as if she heard him speaking right here and now. 😉
You can see on the picture with Michael Feldman a tube amp on top of the rack (my Pyramid-V prototype), to the left from him, and on the picture of Angela Steingardt a couple of my large diaphragm mic prototypes. On a kitchen counter you may see a side of a mixer with digital reverberator on top.
It's all in the Camera. I bought a nice Olympus DSLR a few years back, learned from the website of a Polish-American guy the tricks for that model (last SLR I used was a Practica)... I just point the thing and click the button, it takes the pictures all by itself...
A tube Amp!? Surely it cannot be HiFi... (tounge firmly in cheek)...😛
The digital reverb looks Behringer to me... Tsk, tsk, tsk...
Ciao T
The "secret" to recreating realism is either use a reasonably dead room and position the loudspeakers to aim exactly at the single listeners ears, (Of course you have to tweak the room, gear, etc.) or use a live room with acoustics reasonably correct for the type of music and have a special recording with little reverb of it's own. Both techniques work and have their adherents.
Demo rooms try for the first type. I prefer the second. (What percent of live performances do you think are unamplified today?)
Since the live vs recorded demo has been used for years with gear not as good as what is available today does that hint that the acoustics are the most important remaining issue.
I just digitally modified a wall at my house! I turned it from a 1 into a 0! That produced an improvement in the low frequency response and added significant reverb changes.
Not in the context of amplifiers, no, I have to disagree. It's the minimization of the difference between output and input that defines high fidelity for an amplifier.
Now, that should NOT be conflated with the idea (mistaken) that high fidelity in an amplifier is always an engineering goal in an overall system context. One excellent example would be the Carver subwoofer- in order that the system achieve its targeted performance, an amplifier was used that had an output that in no way resembled the input. The overall system was high fidelity, but the amplifier could in no way be called a high fidelity amplifier. Its highly nonlinear performance was part of an overall successful system design (a damn clever one, IMO).
What about being a true voltage source ?
The third one: use open baffle speakers. They somehow blend together both reverberations.
The forth one: use the same room in which the concert was recorded. 😀
If the amp is supposed to be a voltage source, it should be a voltage source. High fidelity (in the context of an amp!) would then mean that the transfer function Vo/Vi is close to a fixed number. Likewise, if it's supposed to be a current source, Io/Vi should be close to a fixed number for the amplifier to be "high fidelity."
Again, though, whether or not high fidelity amplification is appropriate depends on engineering goals and overall system design.
There is a thread currently on Gearslutz where recording engineers discuss proper transformers for sound recording. The point is, when transformers saturate on lows sound is more "focused" than when lows are rolled off. And they indeed are rolled off when reproduced on real speakers, through real amps. Especially, when 20 Hz is considered as minimum audible, and lows roll off with huge phase incoherence.
Your kidding right? A horn is so directional the only people in the room that wont notice are the ones in a very small angle that recreates the recording. And since most instruments (including the voice) are directional this holds true to some degree for any recording. (if your sitting of to the side in a live unamplified gig, it will sound very different than in the middle, not so with a good playback system)
