Hi Everyone
This is my first time posting, I have read many threads on this forum and have found them very helpful I was wondering if anyone could help with a problem I'm facing.
I'm currently building a class D amp based loosely around the IRAUDAMP7. We are using the 2092 chip, and have just powered it up for the first time. For some reason, the LO output is working fine, outputting a nice square waveform, but the HO output isn't doing anything at all. It just seems to be sitting at Vs.
Does anyone have any idea of what might cause this or if it's an easy-to-fix problem?
why are R16, R20 0R resistors?
the main reason I can see is, that you have no Vb capacitor, to hold the voltage, and coz you don't have it, IRS can't open the fet above + supply voltage, which means that fet is 100% closed
you need capacitor between pin 13 and 15, without it, it will never work
Also I think, and you will see that by yourself, input filter, like in IRAUDAMP7, p30
also 100n input cap seems low in values for full range
also capacitors for suppy filtering, all you have, vcc, +5, -5...
And don't even get me started about output filter, I feel this are not the real values
And there are several things still missing, which mush be on board, note that this is not AB amp, if you are designing it like that
Thanks Luka
My apologies, the schematic uploaded was an earlier version. We do have a cap across Vb and Vs (see attached).
R6 and R20 have been meddled with as we thought the high-side current sensing could be the problem. We have tried the recommended values for R2/R16 and R6/R20 as described in the application note for the chip and it didn't seem to do anything. They were then made open in the hope that it would set the threshold so high that we could eliminate it as the cause. But to no avail. We're still scratching our heads.... :/
You really have 1n4001 for D2, D6?? that will not be ok, you need fast diodes there
ok, so, that is the voltage betwen pin 15 and 13, should be Vcc- diode forward drop
Again, none of diodes MUST NOT be 1n400x series, they are slow, 50Hz/60Hz type diodes
What is the freq. of the LO that you said it works
Again, that is real value of the C31
Hi Luka
The diodes used for D2 and D6 are fast recovery diodes. The schematic lacks some minor part number discrepancies due to the fast approaching deadlines of the project. Suffice to say, the diodes are sufficient in this context.
When we put a 100Hz sine wave into the input, we get a 100Hz square wave out of the LO pin that ranges from the negative rail to Vs. However, when this was done, the FETs were not in place, as the circuit would immediately draw large amounts of current and heat up rapidly. So the output may not be correct because the switching frequency feedback from Vs. So we've put it down to the high side not working.
I should also mention that this is for a subwoofer (<200Hz) so high frequencies are not of a concern to us.
We appreciate your help, this is our first D class Amp, so it's a steep learning curve!
You don't need any input to get oscilation, which should be in few 100kHz range, not what you put on input
And you need to have fets in the circuit, that is like having no motor in car, coz it wants a lot of gas.
you can limit current with outside resistors, say 10-22R per rail
Idle current of working circuit is very low
and for start use the biggest dead time you can
Now its time you post some measurements, of the voltages you have
I feel we are wasting our time helping you without a fully up to date circuit diagram.
Is your inductor really 10mH ? it should be around 20uH !
The input capacitor should be 10uF.
I can promise you the 2092 does work if everything is right plus decoupling and pcb layout kept really short.
I have been through the painful exercise of getting one working too.
Its not like class AB which is much more forgiving.
I first fell foul of decoupling the output mosfets and decoupling b+/b-, b+/gnd b-/gnd.
Then my 12 volt supply was a bit lacking and needed extra decoupling.
I then used a power inductor instead of a proper class d inductor, in the end i used a t106-2 core with a couple of meters of 18swg enammeled copper wire.
Hi guys
We tweaked our HIGH side current sensing resistor values and put the FETs in and it works!
We have changed our dead time selected to be the max (45ns) at the moment.
The output filter now has a capacitor value of 2.2uF and inductor value of 30mH which removes all of the switching frequency noise.
Works good for now, next step is to make the second channel and join them to make a full bridge output.
Thanks for all the help guys
Hay luka,
Yes you are right, the dead time is currently 105ns, and the inductor is 30uH not 30mH. No sleep makes eyes not work very well.
It is currently switching at around 400-450kHz.
When we first plugged it in and ran it with a 2vp-p signal we were getting about 3vp-p out. so we increased the value of the feedback resistor from 64k gradually up to 330k were we are now getting a 40v p-p signal out.
reduce the gain of the amp, now you have 100x gain, way too much
It was pointer out to me, and I see it too, that you guys don't know how to set nor calculate the gain of the amp and what input capacitor to use
1. you don't have input resistor, that with resistor in feedback set the gain
2. your input capacitor size would be good for anything but sub application
Here is what you do, increase input capacitor to atlest 1uF, anything up to 10uF will work great too. Add 3.3k resistor after it. Reduce 330k feedback resistor to 120k
that will give you gain of about what, 35 or so
Hay luka,
I found my amp got warm (2092+mosfets) when running that fast.
200KHz would give a cooler solution.
Thanks everyone for your help! It is now going and sounding pretty good
We added some extra caps over the rails as we were getting a fair bit of bus pumping at the lower frequencies, which has solved that problem.
Interestingly, we can run both sides in half-bridge configuration with no worries, they both perform well and we can see on a scope that they're indeed the inverse of one another. However, when we hook them up in BTL configuration, both chips cease function and toggle their CSD pins.
We can't think of a reason for this as everything works up until we connect the speaker across both outputs.
Any ideas?
Any ideas?
Any ideas?
Remember in BTL mode the speakers must be twice the impedance or you will get an over current event.
I M NEW IN CLASS D ,MY AMP 7 PCB NEAR TO FINISH . CAN I STUDY EXPERIENCE FROM YOU ? CAN I USE IRFB4227 ?
BEST REGARD !
I use a pair of irfb4227 in my design and they work well.
They are a little high on gate capacitance but the 2092 seems to drive them OK.
hi niglelwright !
i bought some irfb4227, irf640 and t_130-2 my power supply is +/- 63v , R gate driver 10 ohms . is it okie ? last time, i test my design in break board it resets when clip like yr .maybe pin ocset or DC protect works not right ,have u fix your amps ?
i hope my amps 7 works good .
philip .
Regard !
philip .
Regard !
HI !
MY PCB is ready to make .it can brige or stereo . uv, ov, dc, oc protect but no temp and clip limit, i will make it with lm3080 late , can it work ?
Regard !
We can do it better than that why don't.......
Regard !
- Class D
- Yet another IRS2092 problem
