how do I cure treble harshness/hash
My proposed crossover uses almost similar component values. It means that while building the proven design from Murray, the first order filter can also be tried. If it work without intolerable peak, it must have strength. The over exposed midrange is not a problem ime, it is suitable to be used in TL enclosure.
A beginner ( or similar...) is not a tweaker: needs something proven and bullet proof !!!
add 0.75 ish mH coil || 30 uF ish capacitor || to 2.5 ohm ish resistor, and this all paralell with the woofer.
You have to be careful with compensation circuitry. They are evil!
But the actual problem is simply, that suitable freqvency range for these 2 drivers simply do not overlap enough for a proper design.
Surprise! Murray Zelligman chooses this combo for some reason. In my experience, to get the best from both good woofer and good tweeter sometime I have to find a way to marry 2 drivers that when using theoretical filter simply will not work.
Another approach, would be to just get other type of tweeter.. one that can go lower, so the W22 can be crossed under 2 Khz.
Agree. I believe that each cone material has its own character/signature. To get seamless blend and to make the speaker disappear, the character should be similar. I don't know, may be magnesium cone should go with Focal tioxid tweeter?
but in order to do that I need to know the dimensions of Your exsisting boxes.
Lohan already mention it (40ltr). But no baffle width as I can remember.
Not a minimalistic design, and I can not guarantee it will work 100%
Granted. If I had the drivers it wouldn't be a minimalistic design such as Murray's. But without having the drivers, it is impossible Arty. Complex filter tend to give fatigue (IMD?) that is not shown by measurements. Only by listening you can avoid it.
Sure. You have saved his $$ :D Unfortunately he might have paid Wilmslow :crazy:
I do not know, i like to have drivers that have well overlaping usable freqvency range.
crossover distorsion is allways a pain, no need to have the additional problems of drivers run on the edge.
but it may just be me, seems others like the combination of these 2 drivers, seems like it is just not my style :D
as far as for listening fatigue, i would probably think the current state of those speakers is easyli defeated.
i know it is 2 different approaches, one that uses only the absolute minimalistic number of components, and an other that uses the whole arsenal. Not commited to any, both are fine.
maybe 3rd order is a bit optimistic without RL mesurements, but i would think high quality drivers tend to be more homogenic and provide enough to dare and attempt it :D
Will see what the owner says, actualy it is all his/her decision anyways.
The suggested pre-made xover seems absolute fine, fits my own school for choosen xover point.
(3 to 4 times Fs at 2nd order) so i could not have anything against it at all.
good thinking batman
Instead of trying to reinvent the wheel without the skills nor the tools, the safer way is imho to use a proven design with those drivers.
This one is by Seas, and i hope they know better their job than their dealers...:cool:
THE ART OF SOUND PERFECTION BY SEAS - Trym
I have decided to try out the Seas desingened crossover for the trym!
What I want to know though is the following:
1. the resistors do not set out the wattage;
2. I want to know if the polyprop capacitors from MAplins will be good enough, or should I get better quality ones;
3. should I make up a pcb, or should I use the tag type board;
4. on the positive input can I run a single circuit to the woofer, and a single circuit to the treble. The reason I ask this is because I intend to make outboard cross-overs, so that if I need to fiddle around with it, I don't have to keep taking the whole speaker apart
I really appreciate all the kind input I am getting on this forum.
I am having some difficulty uploading images at the moment, but will do so on monday, along with the full box Height, width, and depth measurements.
thanks once again
Polyprop is polyprop, isn't it? Maplin or else is a brand name and this has nothing to see with quality grades...:rolleyes:
Btw, even cheap elytics and iron core inductors sound great in a good design.
Do yourself a favor and forget about brandings. Just stick to getting the stuff with the needed specs.
If you forecast to produce many hundreds, it might be a good idea and will boost your productivity.
No, GDO. Mundorf is better than Solen. It is just about money. For speakers, I concentrate on good design with Solen MKP as the standard best price-to-performance ratio. Only when I cannot improve more on the design I will use expensive cap. But I always try so no time for expensive cap :D
Uhmm, because you think that the manufacturer knows something about its strengths and weaknesses? See the datasheet:
http://www.seas.no/images/stories/excel/pdfdataheet/e0011_t25cf002_millennium_datasheet.pdf
Power handling for the Millennium is stated with a 12 dB/oct filter at 2500 Hz. If you go lower, you need steeper crossovers. I would not go below 2000 Hz, period. The risk is that heat builds up in the voice coil and destroys it over some time. I lost a couple of expensive Scanspeak Revelators by trying a 1800 Hz crossover frequency instead of 2400 Hz. Sounded fine initially, but even with 96 dB/oct slopes they died a slow heat death over a few weeks. Their power handling is stated at 2800 Hz, which tells you something about the likely size of the safety margins here.
Is it better to use it higher? Yes and as for your situation, I'm sorry about that, and it's unfortunate, but that isn't the same driver. Here's what SL had to say about the excel:
The 8" midrange is matched to the Seas T25CF002 Millennium 1" soft dome tweeter, which has a smooth frequency response, low stored energy, wide dispersion and can be crossed over at a low 1400 Hz through 24 dB/oct filters.
The Millennium tweeter uses ferro-fluid in its voice coil gap for improved heat transfer to the pole piece. This reduces thermal compression from continuous high sound and amplifier power output levels which raise the voice coil temperature and thus the coil resistance. For example, a rise in coil temperature from 20 0C to 70 0C (68 0F to 158 0F) would reduce the tweeter output level by about 1.5 dB.
I consider the drivers used for the ORION to be state-of-the-art. I have not seen, heard and tested drivers that would make me change them, though I keep looking for any worthwhile improvement.
I've decided to buy some caps from IPL make - this is my first proper modification project, and if it all goes terribly wrong, then I will not have broken the bank.
I think that if this does go according to plan, then I may fiddle around with some different capacitors, or just sit back and enjoy for awhile.
As to the resistors in the circuit what is the wattage value i need? - this is made with reference to the SEAS TRYM circuit on the SEAS website.
Cap brands won't make any audible difference. All poly caps are basically pretty damn good as long as the tolerances aren't totally wild... I think even 10% tolerance is fine.... remember we're usually talking +/-.5 db levels of difference in the measured acoustic change here. Even something like placement or tube amp coloration will have a bigger effect than that!
Make sure to use Air Core inductors though - if any component actually, audibly affects sound quality it's the inductor.
Hah! I see from the edit that you realized your error, and that batteries do make a difference. I converted my Tice Clock to run on Sanyo eneloop rechargables and now everything in the room sounds better. Learning from that example I put eneloops in my minimaglight (like night and day the difference, especially compared to the previous dead Duracells) and in all my remotes, and the even greater improvement in the overall sound field from that mod is simply unbelievable.
Say what you will about changing batteries (or what you won't, after editing), but in my experience it makes a big difference . . .
Current update
I have decided to hold fire on copying the trym crossover until I have posted some further measurements of the cabinet.
Internal dimensions:
Height 455mm
Width 235mm
depth 305 mm
External dimensions
Height: 544mm
Width: 322mm
Depth: 395mm
The reason for the large external dimensions is due to using an inner box of plywood and an external box of MDF
I have a port which is 80mm (I have not cut it down yet)
I am dicing on whether or not I should build a whole new cabinet - scrapping my first effort, or alternatively fettle with the crossover?
I considered the Trym, but that has a cabinet which is about 3 litres smaller, has a smaller port, and the port is in the front.
I am trying to make a very clean and neutral loudspeaker. if you PM me ur e-mail address I can e-mail you diagrams of the speaker dimensions, and also the current crossover - which is simply not much cop!
Please help me
I would build a new cabinet to make sure baffle step compensation is optimal. I would also offset the tweeter and use a 3/4" roundover on the edges to minimize diffraction.
For internal Cabinet volume & bass tuning, I would use Martin J King's worksheets to develop an MLTL or Labyrinth
