Does it really make such an hearable difference?
Is better damping factor the only advantage or is there more advantages? Say you use a large inductor in the crossover with series resistance of 100 mOhms. Then damping factor is still 80 % of original with this amp which shouldn't affect it that much or?
Or just if for the sake of it you DIY wind an monster inductor with a series resistance of less than 50 mOhms so that damping factor is 90 % of original value. The Aleph J already have fairly low damping factor, does a decrease of 10-20 % really make such a difference?
I mean, DIY winding of obscene inductors would be way way cheaper and much more simple than building another Class A amp, matching levels and that 😛
If one had an obscene inductor in the crossover with this amp, would biamp-improvements be theoretical or real? Are the tweeters affected negatively by the crossover or is it only the bass that suffers from less damping factor?
// Olle
// Olle
Addition:
What if you had a crossover without an inductor, so that only the tweeters are crossed?
Is there any reason then to biamp for better damping factor or is the advantage less then?
// Olle
// Olle
Since it became a Xover-question i created a topic in multi way to continue that discussion there:
http://www.diyaudio.com/forums/multi-way/185809-biamp-tweeter-no-xover-main-driver.html#post2516749
Driving a sub crossed at 40hz with an Aleph J really makes no logical sense. It was not designed for that. The typical subwoofer has distortion of several percent in that range, current and damping factor are much more important than the vanishing distortion numbers of a particular amp. An active low pass filter is the most logical way to do it.
Pretty much OT, hey.
I have desided to make 3 stereo Aleph J's instead of JX, to run some horns.
I remoddeled some big *** toroids to give 2x18 volts last night and need to order the PSU parts for CRC PSU, can someone help me with this. I am still learning how to do the PSU simulation and want to get a parts order off so i can receive the parts before Easter holidays. I think the toroids should be around 500va and I am using 4 output fets per board, going for 25 watts per channel.
Thanks in advance.
Thanks in advance.
That's pretty much a standard Aleph J or A30, you can copy the First Watt PSU design if you wish to skip the sims.
Best, Bill
Best, Bill
Thanks Bill, I want to keep this pretty much standard, I cant see any need to change from it with my needs.
I will search for the First watt PSU design, if you know a link, that would be appreciated.
I will still sim the design when found, to help learn.
Thanks Bill and Zen, sorted now.
Back to work on the Pumpkin, I need to swap out Resistors R21,22,23,24,23a, 24a to 1E8.
Question:
Is it possible to lower the voltage gain of the Aleph J? And if it can be done, would this be advantageous to using signal attenuators before the amp?
My current DAC has 5V output voltage and I only listen at low volumes...
// Olle
// Olle
easy to try both ways
give me pic - to see physical layout of input ( RCA + XLR , or you have just RCA )
Aleph J
Hi
I would like to build an Aleph J. Can anyone help with schematics (original pass version) and/ or PCB's?
I have very efficient speakers ( >100db) and I do not many watts. What would be the minimun voltage rails that I can use?
Roberto
Hi
Roberto
Hi
Roberto
Look at the first post of this very thread....
And there is a corrected version here
http://www.diyaudio.com/forums/pass-labs/111197-aleph-j-schematic-7.html#post1343785
Thank you!
Thanks a lot Nelson!
shopping for heatsinks I have found this
TRE S SRL - heat sink with fixing clip system - series screwless
what do you think about it??
- Aleph J Schematic
