Hi!
I read somewhere that even Power tube amplifiers likes to have load resistor on the secondary.
Does anybody have experience in this theme?
Tyimo
Tyimo
Yes, in case of your amplifers have no feedback circle, special with pentode tubeHi!
Tyimo
Yes, special with pentode tube, in case your amplifier have no feetback circle
How about "MK1 Very Easy Speaker", Mr Talkactive?
Valve amplifiers like to have some load. If not, clipping can induce big voltages in the output transformer which cause insulation breakdown. Every few weeks, someone pops up on here and says that he thinks he may have blown his amp (often a guitar amp) by accidentally running it with no speaker connected.
The presence of feedback won't help, it could make it worse because when the output stage clips the feedback loop will try to drive it even harder.
DF96,
There have been a lot of discussions on how to protect the Tx. It seems to be easier on a PP amp you can go across the two plate connections with MOV. However on SE the situation is different, a MOV trip would cause B+ short. Was there ever a definitive answer regards SE?
M. Gregg
I used 1/4 inch jacks that have internal switch for when nothing is plugged in. I wired the switch so when no speakers are plugged in it feeds the output into 25 watt 8 ohm(in my case) resistors in my single ended pentode amp. Of course this does nothing if both ends of your wire are disconnectable and you unplug the speaker side
Interesting,
It's another way around the problem!
M. Gregg
Would a 100 ohm resistor be enough load to damp the big voltage spikes that
dammage the transformer insulation?
What you have to remember is how much of the output you are loosing as wasted heat. OK with this you are only dropping resistance by a small amount. It would probably work however you would not know until you get a speaker disconnected.
M. Gregg
Hi!
SE amps usually have no feedback and no tendency to break into oscillation. This is much less critical with an unloaded secondary.
I routinely test new amps which I built with unloaded secondary and fully driven input.
In SE amps the voltage across the primary will probably rise no more than 50% with unloaded secondary. The OPT should have more than this reserve in voltage capability
If you are not sure about the reserve in your OPT, a 100 Ohm resistor across the secondary will do
best regards
Thomas
best regards
Thomas
Hi!
best regards
Thomas
Thomas,
Did this also include cathode feedback SE?
M. Gregg
My guess is that a triode SE will be safer as the anode impedance will damp the OPT. For a pentode output a Zobel network will help.
Yes, I don't see a problem with cathode feedback
Thomas
Hi!
It seems that there are two reason to use load resistors on the OPT's secondary winding.
- for safety reason
- for better (optimal) drive the loudspeaker.
I am interested in the latter. How to calculate the proper value of this resistor. Maybe a kind of Zobel network would be also good?
Tyimo
- for safety reason
Tyimo
You can also deploy a MOV and series R to progressively load the secondary for excessive voltage swing. The MOV may need to be specially purchased, rather than scavanged mains MOV that are suitable for primary side loading for PP. However given that voltage swing on secondary side is lower, it may be better to implement back-to-back zeners with series R, as they will have better tolerance.
Ciao, Tim
Ciao, Tim
Only one reason: protecting OPT. I don't understand your second reason - to adjust the output impedance of an amplifier you change the OPT ratio or add feedback, not add a parallel resistor.Tyimo said:It seems that there are two reason to use load resistors on the OPT's secondary winding.
- for safety reason
DF96!
6moons audio reviews: FirstWatt F4
I know in this example it is a special situation, but I saw already also in normal loudspeaker connection that they used load resistor.
greets:
Tyimo
Check this out!Only one reason: protecting OPT. I don't understand your second reason - to adjust the output impedance of an amplifier you change the OPT ratio or add feedback, not add a parallel resistor.
greets:
Tyimo
Mostly irrelevant woffle. If an amp needs a big resistor in parallel with the speaker then this is a sign that something is wrong with the design or system matching.
- Tubes / Valves
- Load resistor on OPT
