Of course, I apologize. I was concerned with lamination thickness, and its effect on ultimate transformer importance. Whatever the rest of you were debating was 'off-topic' as far as I am concerned. I am trying to discuss low noise audio design, and deviation from this topic, should have been dealt with by others, I should think. What does everyone else think?
Yes, the principles of physics are usually OT here.
Gents,
A most enjoyable and thought provoking discussion. Honestly, one of the best I've had here..
One learns more through conveyance of differences in opinions.
I'll jump back in monday.
Cheers, John
This is fun. Some homework, I don't have access but I think this will shed some light... Phys. Rev. 105, 896 (1957): Thermal Fluctuations in Conductors
Layer winding of audio transformers causes electrical resonance.....bundle winding helps to cure the resonance problem.
Care to elaborate on that?
What do you mean by "bundle winding"? Are you using that term to mean the same as random winding or scramble winding?
High frequency resonance is the result of leakage inductance and winding capacitance. Layer winding keeps winding capacitances very low.
Here's a CineMag CMLI-15/15B which is a layer wound transformer. No resonance problems there.
se
Yes.
Bundle winding reduces the Q.
How does it do that? By making the windings more inefficient and increasing the winding resistance?
se
I got the paper; whoever would like to have a look at it, send me a pm.
resonance "Q" measurements can be very sensitive, but it helps to have a model to put those sensitive measurement numerical results into
for MC step up I think we're talking about ~10 Ohm source Z from the cart, and pretty much 1st order pre-emphasized signal from the disc
within the xfmr bandwidth you need the source impedance of these noise mechanisms to calculate their significance when paralleled with the cart R
the step up ratio shouldn't be too large, giving poor bandwidth, large leakage, which could "decouple" the source Z image at the secondary from the noise "at resonance" beyond the xfmr bandwidth
if it is then you have the bigger issue of not enough bandwidth for audio
I also really doubt any xfmr lamination "eddy current loss noise" will be increasing faster than the RIAA pre emphasized signal with increasing frequency
Thanks, this looks very promising.
As far as core losses are concerned: Quote without comment.
"Then if an eddy-current loss of 6dB is acceptable at 16kc/s (Hz) the lamination thickness must not exceed 6 mils, and for the same loss at 600Kc/s it must not be more than 1 mil." p.50 'A Survey of Factors Limiting the Performance of Magnetic Recording Systems'
JAES, Jan. 1957 E. D. Daniel et al. Most authors were with the BBC. Daniel was with National Bureau of Standards, Wash. D.C.
Hopefully you will get a copy and believe what they say. Equations are provided, on a previous page.
Hopefully you'll start providing some information that's relevant to audio transformers instead of tape heads.
se
Cine-Mag will through my design, out of spec. Eddy current losses.
You don't even know what your "spec" is.
I mean, how can you even know what your spec is if you've never quantified it in the first place?
se
Bundle winding is a variation on pi winding.
Ah, ok.
Anyone using it in audio transformers? It doesn't look to be a very efficient winding.
And in any case, transformers without any resonance problems can be had without it.
se
Yeah, has been used in custom mic and line transformers.....flat out to past 20k.
Layer wound can achieve that as well.
se
No, everyone, I have not yet found any audio transformer info of any significant sophistication, except for Sowter and his 4 mil lams.
And he says nothing of noise.
So again, you don't even know what your "spec" is.
se
- Member Areas
- The Lounge
