Hi all
What would be the best way to lower the B+ in the PS. I have an excessive 30-40V overall. Im pushing 520V into first caps rated max 500V.
Cheers
Cheers
If you can get a GZ37, these will drop at least 20V more than a GZ34. Watch out for extra heater current though!
A better way is to configure the PS to quasi- choke input. Remove the electrolytics at C1 [cap after rectifier] and replace with MKP [stacked] polypropylene. Panasonic box type for preference. Use PSUDii to find the value of the MKP: 1uF to 5uF are good starting points.
Cheap motor run MKPs sound horrible IME. Stacked MKP are cheap and 630V rated, and sound fine.
Hi Rod
Yes, I have been reading up and this might be the way to do it. Pity I don´t know how to use the PSUDII or I would have.....
Try using a buck winding on the primary- a 12.6V filament transformer will work. That will be the most efficient way to do it rather than burn up heat in a higher rectifier drop or series resistors. It will also drop the heater voltages, but not by much- if you drop 30V out of 520, your 5V heater will drop to about 4.7V. That could work in your favor as well.
What's your Load Current?
Rod
I have 390VAC, 0,5A, 18 OHM
Cheers
This maybe a stupid question but why wouldn´t a 600V 30uf cap and resistor after the rectifier and keep whats already there in the PS work?
Cheers
Cheers
It work work fine.
You can make 33uF or so by using 100uF/400V electrolytic (Panasonic HA or HB or TSUP, Nichicon KX). Use three in series like you have two in series now, with 220K 1W resitor across each one, to keep the voltage balanced in each one.
Or you could use a quality MKP of 30uF/630V. I use and enjoy the AMPOHM [LCR] MKP series
AMPOHM WOUND PRODUCTS|FP-CA-10-AU|CAPACITOR, AUDIO, 10UF, 630VDC | Farnell United Kingdom
O, and the second capacitor, if that is seeing more than 500V, would need to be made from 1000uF/400V x2, and 150K 3W across each. That may be found to be somewhat expensive, though, in which case, reducing C1 to a 10uF 630V MKP may be a better solution.
It work work fine.
Rod
Oh shoot, I thought I had 30uf but checking now they are 50uf/600V. So I guess these won´t work?
I was thinking of something like this. 1st cap 50uf/600V and then a resistor.
Cheers
That would be a lot less capacitance.
THe other thing to check is that the output valves are correctly adjusted.
Presumably the original designer intended less than 500V on C2, and if the output valves are drawing less than the right current, the voltage will rise. Adjusting for more current, provinding you keep within rated dissipation on the anodes, might just pull it in.
If you lower the first pair of 47uf caps off rectifier you will be "closer" to a Choke Input Filter (.9* tranny secondary voltage) rather than a Cap Input Filter (1.4* tranny secondary voltage).
You can also model it in PSU designer.
EDIT - whoops, someone already recommended reduce caps size - the choke input deal... looks like I should read more, type less...
Rod
The PS was SS in the beginning but it was changed to tube rectified. C2 had 480V which is pushing it a bit but still under maximum load.
So what would you say about connecting the 50uf/600V cap after the rectifier and then a resistor, would this bring the voltage down?
Cheers
Might work for class A SE amps.
If you're running 100mA class A, 220 Ohms would drop 22V - but burn 2.2W (use a 10W part, wirewound, and mount well away from anything that can't stand the 200 to 300 degrees C of wirewound Rs). The amp may be degraded by the instantaneous volt drops, a little.
For PP class AB amps, the drops caused while the music plays would degrade the sound notably, I suspect, and the power burn in the resistor may be much higher, with music, depending on what kind of power valves you have in there.
O, it's Triode Dick's Bill. Adding a series resistor is certainly the wrong thing there.
Here's a supply based on 10uF MKP. The voltage will be a tiny bit higher with your hybrid bridge - maybe 5-8V. This is a stepped load, corresponding to the standard KT88 conditions of 120mA idle, 300mA full power, 20ms later. the sag is slightly less with 25uF - the price for changing things.
IF the current at idle is different, these results will be off, so beware, and measure first.
Sorry Rod...you lost me there
What does this mean? Im not a techie, just a guy who likes to put things together. However Im learning, all thanks to you.
Cheers
1. Don't add any Resistor, or the performance in this PP amp will suffer.
2. Replacing the two series-connected 47uF/385V caps with 6.8uF or 10uF 630V MKP will reduce the voltage, without any bad things happening.
But - I still think it is worth knowing what the current in each KT88 cathode is, before proceeding.
If the KT88s are tired out (and taking LOW current), the voltage will be higher than expected. Fixing this before modifying the supply is a better way ahead.
I would expect 55 to 65mA at 500V, as a start, unless Triode Dick has a different spec.
Ok, thanks Rod
I have brand new KT88´s in and biased at 60mA. So I guess I will try 10uf/630V caps instead if the ones Im using now.
Thanks again
I would try 6.8uF first, as these give a lower voltage. If it's too low, try 10uF.
Or buy 4.7uF plus a couple 2.2uF, and try adding the 2.2uF to the 4.7, one at a time. THis will give small increases for each extra cap.
- Tubes / Valves
- Lowering B+ in PS
