Simplistic mosFET HV Shunt Regs
Minimal Vin
Hi
Which is the minimal allowed Vin for this shunt to work properly.I need the voltage from 100 - 150.I don't have higher voltage transformers but only 110 - 130V on secondary and want to try the shunt.I use lot of subminiature valves with limited max. voltage possibility and this way the tubes would be protected to not get 250V in case of shunt failure with 250v input voltage (if I understood well what happening with the regulator failure).
Is that possible with filtered 150 - 170V on the shunt input?
Thanks to Salas and everybody around the shunt.
100uF normal electrolytic tolerance is sufficient. You don't need any special ESR, since its highly loaded with external series resistance. The function is to fill out a phase bump in the loop gain at the lows. Just use a reliable make.
