UCD 25 watts to 1200 watts using 2 mosfets
so for a powersupply of +/- 85vlts it is safe to use the irfp360 instead of irfp260 with this circuit
Not really. I'm writing it for the 100th time like many other members: an old, high voltage MOSFET has slow body diode which makes it a bad solution in such a simple output stage. IRF360 has a Qrr of 5.6 uQ, and high channel resistance, so it's a really bad MOSFET for this circuit!
I said you should choose the LOWEST voltage rated device which meets the requirement!
I get it, something like that?
How many turns and thick wire for 20uH with gap of 1mm on this core.
Thanks buddy
Regards, Nikola
@ionutzxpo
Core form PC and from my picture (2.7 x 1.4 x 1.1cm) is actually IRON POWDER CORE 106-26 yellow-white (Al= 900uH/100turns)
Now I do not understand this calculation for 20uH coil and this core
N=100(L/Al)^1/2
=100(20/900)^1/2
=100(0.02222)^1.2= 15 turns
Why 17uH on this core has 23 turns and gap of 1mm????
But I made 23 turns with gap core (in atached pictures), wire that i use is 2x0,8mm
