25W with 2xEL86(6CW5)!
Small, but very powerful guitar amplifier with 2xEL86 output tubes! More than 25W before clipping, and more than 30W at maximum!
Cool amp. :up:
Can you explain the effect level control. It looks like it actually adjusts a parallel "dry" path? I employed a parallel loop in my amp but could not find any schematics. I used a "blend" control to combine the paths after the loop (and a boosting stage immediately after the effects.)
Is there a standard name for the approach you are using for the loop and it's adjustment? Is it based on a particular amp? Is the signal it sends out to the effects unit too strong if the preamp is set high?
No, I did not sketched layout. 2 small board in amp are not PCB, only board with hole raster. Parts on the boards are soldered and connect with wires.
