What speaker system for tube amplifier
Hello,
I have posted this message couple of days ago in the speaker section but I got no reply. Maybe I have some luck in the tube amp section.
I'm building a stereo SE KT88 tube amplifier. The output power will be around 10W/channel.
I would like to know what speakers should I use.
I don't want to spend more than $1000/pair.
I have listen to Paradigm speakers and some of them sound very good but also too expensive.
From what I've been reading in the last 6 months or so I come up with several options:
1. 3 way speaker with very high sensitivity (>95dB). They seam a little more expensive than other options.
2. 2 way speaker with med sensitivity (~89dB). This way I'll loose some low frequency. I don't know how important is this.
3. 3 way speaker with active bass. They are big and expensive.
4. How about this idea? 2 way speaker + 10" or 12" subwoofer for each channel. Similar to option 3 but cheaper. I don't mind to have to boxes stuck one on top of the other.
I think with option 4 I get full range and is not too expensive.
The thing is I didn't see this option anywhere so I guess there is something I'm missing because to me this is ideal.
Could you experts tell me what kind of speakers I could buy for each option? And also could you comment on option 4?
Thank you,
Alex
I built that in a single day using (precut) 20mm plywood pieces, a jig saw, nails and glue !
And there are no crossovers at all 😉
Yves.
Another option is a good set of used speakers.
I'm always looking for original series Klipsch Heresy speakers from the late 70s. I now have two sets, and am quite happy with them. I bought my first set new in 78, but got the second set for only $300 a few years back. I think the early Heresy sound better with tube amps than the later ones (just my opinion).
10W will drive them quite well.
I have driven them with my little 3.5W amp and it can even drive them well, but I don't listen at concert levels any more.
think high efficiency and a nice flat-ish impedance load.
Horn speakers are an obvious path - perhaps a UREI, JBL, Altec, etc studio monitor. I've gotten plenty of volume with a SEUL EL156 (~20Ws) with a pair of UREI 813As.
Other options are vintage 12" or 15" coaxes in a (Onken/Ultraflex/etc) box. For awhile I ran a pair of Stephens 'Trusonic' 12" coaxes in a big homemade Jensen cabinet. Good sound with only 3Ws of SE 2A3 power.
I've run moderate efficiency KEF Q60s and C-75s with 10-25W amplifiers and they make good volume. Just don't expect head banging volumes.
There is also the Lowther, Supravox, etc fullrange drivers but I can't offer much advice in that region. A good speaker is a rare thing indeed as I've had a love/hate relationship with every one I've ever owned.
To me the sound is more important than the looks, but then I'm married and that won't fly. The speaker need to blend with the whole furniture 😕. I'm contemplating the KEF Q60, also Paradigm Studio 20 looks interesting too. What would be the minimum efficiency I should look for?
So Yves, according to your speaker I don't need to have 2 or 3 speakers each for different frequency? I didn't know 1 speaker can cover the whole range of frequency (or at least 45Hz - 18kHz).
I guess my idea of having 2way bookshelf on top of an active subwoofer is not that great. I thought by doing that I could cover the whole range of frequencies and I don't need a lot of power for low frequencies.
Now I got to run and buy a few pairs of shoes and some handbags so that my wife will be blinded when I go and get my speakers😀.
Alex
Philips claims for 97dB per Watt at 1 meter, this is quite hi efficiency for cone speakers.
Measured frequency range extends to 10 / 15 Khz, you may want to add a tweeter but they must have comparable sensitivity.
I was pleased by the Fostex FT17h with just a 0.68 µF capacitor in serie.
At lo end, the room itself and the placement plays a big role. In my 30 sqmeter with the baffles in the corners, I don't suffer from bass weakness 🙂
I routinely use less than 8 Watts per channel amplifier, this is more than needed to put you out of the house !
Remember, the sound level doubles each time you add 3dB, so 90dB speakers would need more than 32 W per channel amplifier to produce the same level.
It is absolutly necessary that your wife be allowed (encouraged) to use the "sound machine" even when you're not at home to listen the music she likes 😀
Yves.
tube speakers
For best matching, try to buy speakers that are 8 ohm. 4 ohm and lower is better for transistor direct coupled amps. Acoustic suspension sucks power you don't have. I'm doing fine at 1.5 V PP average in my living room with my Peavey SP2-XT's, which with horn tweeter are pretty efficient. $600 ea new, the later models are even more refined. Beware of used ones with separate tweeter housing, they may not sound as good, and they are exceptionally cheap for some reason. ($200 a pair usually). They are big hulking black things set on stands above behind and splitting my Steinway, reminds my wife of some disco club she used to dance in decades ago.
I really do believe you may very well be disappointed with those Paradigms...While sounding great at low level, (Background) level....any attempt to push the volume to anything approaching a live level.& your amp will be tapped out. Dynamics will suffer........your music will start getting compressed, distorting.
Myself I've been looking into vintage Cerwin Vegas..The current production of CVs have been losing efficiency over the years. What started out at about 103 Db have been dropping into the 98Db range. I recall a model of CVs rated at 103 Db, two way , 15" driver & one round horn....grey in color. I think its an "HED" model from the mid-seventies. At the second hand "Collector Houses" a pair falls well under your $1000 limit.
____________________________________________________________Rick...
Probably too late, but . . .
Another viable option is a speaker with a series crossover. Often, a series crossover can be designed with a fairly resistive impedance load.
Here's a link to Andy G's site, emphasizing series crossovers and diy:
ARGOS loudspeakers
I'm also interested in making a SE amp using KT88's. Are you using an existing design, or creating your own?
My wife won.
I'm going with Paradigm Monitor 7
East Hamilton Radio 2
I hope my little amp is capable to drive these speakers.
I'm so sad 😱
Never had the opportunity to listen those slim columns but it happens that -for some similar reason- I own a pair of French made "Davis Vezelay" wich look very similar: double small woofer, one medium and one tweeter.
Once you have compared with that infamous "Philips on a board" thingy, nobody can accept to go back . . . including my wife 🙂
She said: "Oh, the singer is singing IN OUR dinning room !"
This disturbed her a bit (a lot) so we are seriously speaking about how to somewhat reorganise furnitures to integrate'em !
Probably the 10 and 13 years old kids will be allowed to add some decorations . . . but I must remove the loudspeakers before 😀 . . . a good opportunity to install the tweeters "cleanly".
Yves.
ARGOS loudspeakers
Hi Dave,
My amp is based on the following link:
I will replace 1k//100uf with 2 red LEDs as per some posts I've read in the past.
I don't have a switch mode: my amp will run triode mode only.
I don't have a switch to change the bias. I have calculated 69mA.
OPT is not Hammond but Edcor (GXSE15-8-5K)
PSU: I don't use 5U4-G. Transformer is Edcor (XPWR105) 4 x UF4007 followed by CRCRC
(82uF/500V 250/13W 820uF/500V 250/13W 820uF/500V). PSU Designer II tells me I get 400Vdc.
Case is done. The color is my daughter's choice not mine (well I kinda like it too!). The method is powder coating.
I have all the components. All I need is to solder them. I also got an oscilloscope and a signal generator.
Congratulations!
Nice looking mains filter. Now, let's wait for the new topic: "What to do with hum that present when I connect a signal source?"
You try to scare me now!
I'm using a star ground system. PS ground will be from the first cap to star. I'm going to use shielded cable from the back of the amp to the front of the amp where the volume is. The shield will also be connected to the star using 1 wire only. Based on what I've been reading in this forum for the past year, this will eliminate the hum. Also twisted wires for the heaters, wires not parallel, etc.
Anything else I should do? I value your opinion highly.
Alex
