LED:
Forward Voltage VF IF=3500mA 32-36 V
Flux Characteristics ¦µv IF=3500mA 6000-7000 lm
Color Temperature Tc IF=3500mA 6000-7000 K
Viewing Angle 2¦È1/2 IF=3500mA 110 deg
LED special power: Constant Current Source (not normal Switching Power Supply )
cooler.:
pure copper base and 4 heat pipeS
condenser diameter 75mm. focal length 70 mm
cooler.:
Ywh,
Have you used this lamp assembly in any projector?
If so, have you any screenshots to share?
Wow! That is pretty impressive. How big is this thing?... I am seriously thinking about getting one.
sorry my poor english
Hi DrFrekkr !
yes! the heatsink get very hot and the enough is 100w .
it can get 55Celsius if you choose this cooler
Oh
If you all want to learn more about this solution, I can analyse it on request.
1. The tempreture on the heatsink? How much? high or low?
2. The total output of the lamp array?
3. The efficiency of the engine?
4. The color temp of the lamp?
5. The real life of the lamp array
balabala
balabala
1. The tempreture is about 60C elsius, on the pole of lamp array
2. The total output of the lamp array is 6000-7000 lm?
3. The efficiency of the engine 60-70lm/w
4. The color temp of the lamp is 6000-7000 k
5. The real life of the lamp array, no time to test
where did you buy the power supply? and also, if it's not too much trouble. a newbie guide would be nice, whit more photos of the installing process.
Kind Regards/rBennich
price of these LED kit is $210, only one kit in my hand now.
You must use this type cooler if you got this LED, at least!
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- 100wLED + driver + condenser + cooler
