My last 1000W (2000W) amp, PCB 40x270mm, 10 x IRFP240/9240 (2 x PCB 40x270mm, 20 x IRFP240/9240 )
often pcb designers have a fiction or a vice with symmetrics and size ( including me ) ....playing this game might end up with an ultra compact and symmetric pcb but that comes with a a couple of troubles
one : that no one can use a bigger semi for the output if exist or if needed
two: keeping so many output semis so close to each other means that the heatsink has to be made of zorex, kryptonex, starson or any other material from the moon or jupiter to be able to absorve this type of heat ...
Federmann
Has anyone ever built this layout and effectively cooled it?
I am strugging to envisage an efficient heatsink layout to suit.
Maybe a re-design is required to the layout of the output mosfets to suit the real world.
For a working example, look at Quasi's designs which are documented on his website
Quasi's DIY Audio Site
10 pair of IRFP mosfets driven by the VAS directly?!![]()
Not even 2 pairs should be driven directly from the vas 😉
There is no reason to give more of the transistor.
It depends on how much current goes through the VAS.
I have succesfully used 3 pairs with just a VAS driver, the frequency response was fine over the audio range.
Federmann
8 pairs and 2x500W
What about liquid nitrogen !? 😀
I see now that the FETs are angled outwards 'in the real world'!😛
The new layout shows the temperature compensation transistor for the bias, not central to the heatsink, is this not an issue?😕
Also I would like to add my vote to the addition of a proper driver stage after the VAS. With FET amps I have modified to include a driver stage, I have noted better stability when driving real loads.😉
Why is the capacitor C15, that is connected across the Feedback Resistor R17 trimmable?
Apart from that I like the distributed resevior capacitance on the output stage, & the separate PSU for the Driver Stage. 😎
Yes C15 is the capacitance trimmer. Only the total feedback, no local feedback. Bandwidth to 500kHz, up to 2MHz.
Second possibility FEFs may be Al prism 30x20mm, then the cooler.
Federmann,
The symbols you used in the schematic of your amplifier for P-channel Fets is Wrong.....😛
Correct it.
I like the simplicity of your amplifier, at what current your VAS is running, since your driving a bunch of 10 Fet pairs directly.😱
Kanwar
Correct it.
Kanwar
Federmann,
Correct it.
Kanwar
I do not have the EAGLE TO247AC for P.
Current T6-T7 = 10 ÷ 15 mA/pair, 10 pairs of 100-150 mA.
Strange to know that you dont have symbol for P-channel in eagle for schematics.
Running VAS at 100-150mA means differential pair transistors must be running at around 10-15mA🙁
well, it s doable if one is satisfied with a THD ratio that
is ten fold higher than when adding an EF buffer stage....
Please do not measure THD at 1kHz, measure, please THD at 100kHz. Many transistors does a very slow amplifier.
- amp 1000W/2000W, IRFP240/9240
