Question About Transistor Matching
Hi I am new to this forum. I got the following transistor matching circuit from the internet it is quite simple and easy to build but the upper section (for NPN measurement) of the circuit has one 10K resistor connected between the two transistors while the lower section (for PNP measurement) has none. Would anyone please tell me is this a drawing mistake? Which one is correct? Thanks.
Image size
Planet10
I now have the same problem when posting images here, that are hosted by ImageShack. Even though the original picture may be quite large, since the DIYAudio upgrade, it is the thumbmail that is being used , instead of being able to use the clickable option for a large image. Perhaps as a Moderator, you may be able to find out why the original option no longer works.
It certainly still functions in other forums.
SandyK
Hi Jan
Any comment for the circuit?
Back to your initial question; I think the 10K is missing in the PNP measurement circuit..... ?
Also if you do want to match transistors, I miss the possibility to match them at different currents like 100uA, 1mA and 10mA....
As to peranders suggestion about matching them in the actual circuit, I agree that that is the most correct way of doing it. Build a copy of the circuit (e.g. current source), and match the trannies at e.g. 3mA
