DIY Golf Club Unipivot Tonearm
Here are some photos of my unipivot tonearm made from a carbon fiber (boron graphite) golf club shaft. It's still in process, I don't have the clips (making those) and the Nextgen RCA jacks.
Thanks, Jim. I had purchased eight different carbon composite golf clubs from Goodwill ($3 each - less than half the price of one 4 foot piece from McMaster-Carr) that I chopped apart and then picked the lightest/deadest piece for this project. The length is 16" (approx.) and it required 180gr counterweight. The last straight 10" tonearm I built needed a 145gr counterweight so I feel that this wasn't much of an increase compared to the length. It is also filled with foam and I could have saved weight by using something other than brass for the headshell.
OH! The headshell is brass?? I am planing to use a piece of plain woven carbon sheet bonded (epoxied) to the end of the arm tube. If I might suggest: Aluminum is light and generally dead, particularly in the lower grades (5000 and under). the (common) 6061 is strong, and can be 'ringy'. Magnesium would be better still, but it is hard to get and no shop wants to machine it...
In my case, I need a 15 degree offset, so I will mill the end of the tube top portion at 15 degrees and bond the flat (~rectangular maybe integrate the lift as well) piece on (after milling mount slots). Just trying to determine how exactly I want the stylus with regard to the centerline of the arm tube and/or arm pivot. I am using a cross axle (similar to Rega arm) and can raise or lower the pivot relative to the arm tube etc. Making it all from scratch gives me freedom; the problem is I am not an expert:wchair:, so it takes a long time to figure out where I want stuff to be!
@Jim- I would love to have machining equipment at my disposal but alas; I don't. Aluminum or magnesium would have been my first choice. I wanted a stronger mount that I could make at my jeweler's bench, because with my other arms I've made I've just cut a flat spot in the tubing to screw the headshell to. My wood arms had a similar mounting scheme. The brass mount in this case is pretty light. It is damped by the deadening paint and the cartridge is mounted to a Dymond wood and titanium headshell. I was looking for a more finished appearance on this arm, hence using brass that's silver soldered and hand tooled.
Which brings me to this question:
When I mount my tube to the yoke, should the center of rotation (of the cross axle) be in line with the center of the tube (both in the same horizontal plane), in line with the center of the stylus (i.e. mount the tube high relitive to the axle), or someplace else? Does it matter?
Second, since I have complete control over everything, would there be any advantage at all to changing the 'accepted standard' of 21 degrees offset for the yoke bearings in relation to the arm tube? Since that is for 9-12" effective lengths, should I change it (more or less- I have no idea) from the 21 degrees?
If it matters, I have a 14.2" effective length and a 15 degree offset.
I think I may start a new thread...:dunno:
I don't know how much it matters. Different cartridges have differing heights, so if it is 'perfect' for one, it will be bad for another...
Rega have it in the same plane (axle and arm) and that's a pretty nice arm, so I'm leaning that way.
The counterweight will most certainly be set low (~in line with the stylus), and close to the yoke.
I will probably stick with 21 degrees, as if it doesn't change for 9-12 inches, it probably won't change for 14.2 inches.
Plus, the more I change, the more reasons for it not to work!:eek:
@ Scott- Magnesium is scary. A long time ago I worked as a model maker- making belt buckle originals from magnesium (recreating big elk, guys fishing and Mack Trucks. WTF?). We had a grinding machine that I ground the etched magnesium plates on, and even though there was a sign that said that the grinding machine was for magnesium only- "no steel grinding - fire hazard". One day one of the doofus's that worked there ground the tip of a screwdriver and started a fire that we tried to extinguish the fire extinguishers to no avail. The fire department was called and the entire bench in that corner of the shop went up in flames.
Clean all magnesium scraps and especially powders and granules up. Unless you like fireworks. I used to take small scraps home and light them in my parents back yard. One little .5" X 1" piece would light up the entire backyard.
That looks good.
What is the wall thickness of the tube and what is the weight of the arm with and without the end fittings.
One thing comes to mind, and you may have already thought of it yourself, would it be beneficial to incorporate a vibration damper in the balance weight assembly?
Just a thought.
Rod
