Burn In speakercable
Such bars are bent like that, on regular basis, and used to conduct kA.
Yep, not uncommon in my hydro transfer switches and transmitters. My question is far simpler than that though: what does this patent claim to address? The author appears to say it's the reliability of very small gauge wire. The buss bars on the output of our half megawatt generator might not care but Litz built up from 45 gauge might. I honestly don't know at what scale they claim it's an issue. Internal IC wiring?
We experience it differently. After three or four repetitions I learned to hear it as 1, 2, 3....20, 21, 2, 3...... A clear (and illusory) downshift in pitch occurs after the repeat first bar. The illusion is an artifact of fast switching ABX-style. Wait three or four seconds between repeats and adjust your expectations to anticipate a slightly higher pitched first bar and the illusion evaporates. At least for me. [snip].
Well at least it's good to read from someone else that illusions play big time in this stuff. And the 'adjust your expectations' is priceless as well, thank you. Now if we only could be sure which are the illusions and which not ....😉
jd
Most likely. They say they're responding to an industry that needs finer wire and thinner foils. There hasn't been any particular problem making 45 gauge and finer wire for decades.
se
But my point being, that the bus bars does not break, when bent, and the scale of the events, is diminishing as the diameter of the wire goes down.
If it's not an issue to the bus bars, then why should it be an issue to 45 gauge?
45 gauge wire, is around 0.05mm, which is manufactured on daily basis.
If you look at the wire manufacturers spec sheets, you see no de-rating of the thinner wire gauges. All have the same current capability per mm2.
Magura 🙂
EDIT: exactly my point Steve.
Its only that I would not use such sharp bends on high current
So the sharp radius bends on the bussbars in the substation I was in today are causing issues? Maybe that's why, when one of our staff stood under one of these bends they suddenly exclaimed "Oh, my god, it feels like I'm in a sunshower" because of the electrons unable to take the tight radius and flooding to the ground, like a little rain of energy.
but what do I know.
Not much obviously.
So the sharp radius bends on the bussbars in the substation I was in today are causing issues? Maybe that's why, when one of our staff stood under one of these bends they suddenly exclaimed "Oh, my god, it feels like I'm in a sunshower" because of the electrons unable to take the tight radius and flooding to the ground, like a little rain of energy.Not much obviously.
Obviously more than you, go read your grade one electricity notes and see what happen when high current flow through a short bend. Strange that is the first point that will fail in a short.
I am already an EE, and the protection systems will operate during a fault. You think any of this is new? It is well known and basic electrical design. Funny that these installations, and we have many of them, function well under all sorts of load conditions including continuous high current draw and survive and function for decades.
I am yet to see any evidence from YOU, beyond hand waving assertion, that tight radius bends have any effect in an audio system, beyond the small difference in R. And I am not discussing fault conditions, but normal operation.
The critical thing (to the extent that it's critical) is not the bend radius, it's the ratio of the bend radius to the diameter.
But, yes, all handwaving from a couple of guys with no evidence, no knowledge of metallurgy, one of whom has no knowledge of basic electricity, and the other of whom admits that he can't tell the difference between wires without peeking but is happy to argue the point anyway.
So, seriously, why does anyone bother to argue?
Hello all.
From my experiences with diy cables I believe it´s the dielectrics that burn in, not metals.
There´s something about PTFE, either solid or foamed, and PVC that adds noticeable (to me anyway) colourations to the sound on the first auditions after the cables are assembled. And such effects seem to go away just after a few hours of use, not days or weeks as usually stated.
I´m aware it could be my imagination, hence the bold and my interest in this test.
For lack of a better description, Teflon sounds initially "greasy" and PVC sounds "smoky".
Other materials such as PE and PP don´t seem to add so much immediately distinct colourations, which is odd since you´d expect such effects to be gradual throughout the Dielectric Constant scale...
I have experienced this mainly in arrangements where the insulated wires are close to each other such as in paralel or twisted pairs. In other geometries, the more air that gets between the conductors, the less initial colourations are noticeable, and arguably the less burn-in time required...
Maybe the best configuration to definitely check for burned-in metals would be running straight wires from plug to plug, well away from each other? Although removing the solid dielectrics out of the equation I reckon I wouldn´t detect any difference between the burned-in cable and the other.
