OK, then, I believe there're already some, here in this forum 😀
I also believe you'll find them without much effort.
plays louder and goes deeper
How many are you interested in using? From what I recall, they hit their mark when you have 8 of them in the pile. Physics is unforgiving.
Then again, one huge monster of great efficiency might be Pe bound compared a group of smaller subs in a pile that end-up being smaller as a total, but who's output capabilities are much greater.
Be aware that below the cuttoff of the horn, all you have is just a sealed box.
So.... what is the total output you are targeting with what roll-off character?
download Danley's paper on designing the Labhorn.
It is very illuminating and in particular Danley compares the Labhorns to an "ideal" vented stack. The vented stack loses out on cost and loses out on power requirement and loses out on size (volume) and loses out on weight. Is that enough?
The Labhorn approaches 50% efficiency and there is little that can be done to improve on that.
12 Labhorns are needed for freespace hanging, or 6, if up against one solid boundary.
If you want to go lower than the 27Hz of the Labhorn, then the horn is going to grow much bigger. How can it be transported? Which driver will have been designed for the new deeper horn? What instruments do you intend reproducing on this new deeper horn?
Requirements are everything heres the lab12 up against the Bill Fitzmaurice Tuba Home theatre both corner loaded. The lab gets higher spl from a single cab but the tuba goes a lot lower.
You cant do wront with the LAB, as they are still a great design compared to about 99% of whats out there. Maybe you could get a better performance with the new danley sound labs tapped horns, but it wont be much of a difference i think and you dont have the bonus of having a professionally designed horn to build. Designing your own opens up lots of possibilities to screw up.
Six LabHorns will do a great job ... the job they were designed to do. There is nothing louder & lower & smaller & lighter. Most people don't need six LabHorns, and building one LabHorn is a waste ...
... and Bill Fitz has nothing that compares.
The lab horn is a careful balance of compromises. Wayne Parham designed a competitor which is bigger and has less of a need for multiples. If you want deeper and louder then be ready for MUCH BIGGER! You might consider tapped horns, and a lot of them. You start with a design that will meet the extension requirement, then use multiples til you reach the target.
And just how much maximum output will the Tuba have around 30Hz, when it's operating as a sealed box?
An extended LF response is pointless without the output capability to use it.
Hi there: Just checked the Bill Fitzmaurice web site: He has posted a newer version Tuba Home Theater, Tuba 36-inch. The posted spl curve removes the dip in the "smaller" 24-inch wide version. The 36 is shown with a flatter response below 40-30 hz and goes much deeper.
...regards, Michael
...regards, Michael
iand:
Another thought.
wonder if the 2 subs were tested in the same corner?
Indoor measurements mean nothing. I've been burned by that trick before.....
Another thought.
Actual measurement of BFM cabinet:
vs claims:
vs claims:
Is the measurement in room, or does the ripple come from a too small mouth? Anyway... it looks like the official measurement is rather optimistic about its performance.
Btw, djk... i think you said on a different forum something about which fs is ideal for a tapped horn tuning and came up with a pretty exact number for it. Could i ask for a short explanation of it? (Dont want to steal the thread though).
- Subwoofers
- is lab horn the best
