Here's the deal...
I'm a relatively novice repair tech who knows how to avoid getting electrocuted and can fix most basic problems with audio gear. I've got a NAD 3020 on my repair bench that I'm fixing for a friend that I could use some help figuring out. I'll give $20 to the first person who gives me the tip that leads to this thing getting fixed. (for realz!) I know it's not much, but I'm not making much on it either, so that's the deal. 😉
Here's the service manual and schematic.
Here's the clues:
If you need more clues, just ask and I'll do further testing or take pictures or measurements if you need me to. I just want this thing fixed and OFF my bench! I really will send the money.
Thanks guys!
Here's the clues:
- I checked it over for loose components and cracked solder joints. There were a few loose connections, but otherwise (I think) everything's connected properly now.
- I just put 4 brand new power transistors in it (Q615,Q616,Q617,Q618)
- FUSE 3 and FUSE 4 were blown and I replaced them with new 3A fuses
- It turns on
- It passes distorted garbled audio
- Turning the volume control up results in more distortion, but not more volume
- after a few seconds, R643 and R644 start smoking and charring
Thanks guys!
DC voltages usually tell a lot.
In order of probable cause...
1) Check Q609, Q610, D605 and D606 for shorts.
2) Check Q613 and Q614 for shorts.
3) Check Q607 and Q608 for shorts.
4) Check for bad solder joints.
Bah Nrik, you beat my post by SECONDS! 😛
Cheers!
Cheers!
Well, in these bjt-output stages usually also the drivers get fried when the outputs go. This fits also well with R643 getting hot as there is excessive current coming from the rail.
I would check everything south of Q605, means Q607, Q611, Q615.
What worries me is where all this current goes to without blowing up more resistors. Does Q613 get hot? Likely the bias generator Q609 is also not properly setup, so check that as well (R641).
Have fun and good luck, Hannes
I suppose you could make a 1/4" jack input and have it as a guitar fx box...
Anyway.
It sounds like there's not enough power to the main chip thing - the usual reason for distortion is the PSU is being pulled down, meaning there must be somewhere else all that current is going to, but it's not meant to. I'd look for shorts from the PSU capacitors onwards - clearly, there is a leak somewhere.
Anyway.
Here's the deal...
Here's the clues:
- It turns on
Thanks guys!
What are the power supply voltages. I know it says +28/-28 . Is that what they are? Without a load on it, what is the DC output voltage? Were the power transistors you took out actually bad? What is the +29.9 voltage really? Did you check Q611, Q612, Q613 and Q614?
G²
Check the dc offset there is an adjustment procedure in the manual you posted. If it's way out it could explain the distortion if the output is always being clipped in one direction and the resistors getting hot because of constant current flow
Without having the unit to actually work on it's quicker in the long run to do several tests first.
1. First fit a 60 or 100 watt bulb in series with the mains to limit damage while testing.
2. Concentrate on one channel, so remove the outputs from the other together with the drivers... in other words, get that channel so it doesn't smoke 🙂 and you can concentrate on just one.
3. On the channel you are working on... make sure everything is connected... no load... and switch on. I'll assume you are working on the "top" channel.
4. If R643 smokes and the bulb lights brightly remove Q605 and test again. The bulb should be dim and no smoke. The voltage on the outputs (emmiters) will be -28 (rail)
That's a first step...
Gut feeling with this... if you replace those burnt resistors and check the 6 transistors in the output side of the amp you will find the fault. You can add a wire link from base of Q611 to base Q613 to short out the vbe bias generator to help fault finding too. That will remove bias from the output pair.
Are you certain all the transistors are OK and fitted correctly.
Shorts in Q609/610 and D605/606 will cause a class C output stage bias condition, but won't smoke anything. This just increases distortion and you can measure the voltage between the bases of Q611/612 and Q613/614 to see if it's shorted. If not shorted, you'll get a voltage around 2.3V. You need not worry about this until you have the smoke problem sorted.
If R643/644 are burning, something is pulling too much current on the negative side of the amplifier's output stage. If Q607/608 were shorted, you'd be unlikely to get much audio at all and the output offset would be astronomical (speaker cones trying to escape their baskets). It seems more like Q613/614 are having problems and the error amp is doing all it can to hold the output near zero and nuking the upper part of the circuit in the process. Try replacing Q613/614; at least test them for shorts. (If you're really fast, measure Vbe on them while the power's on).
Also measure the voltage across R651/652 and tell us what it is; it's supposed to be around a volt (1.1V based on schematic numbers).
Other than the above; are you certain you replaced the output transistors with the correct types and installed them in the correct places?
Please tell us what the output offset voltage is too (volts DC on the speaker terminals).
Cheers
Cheers
Also check that D605/606 aren't blown and gone open. Check the same for Q609/610.
Check R645/646 as well. If they are blown, the bias transistor will turn off and the output stage will try to cook.
It's been a long time, so I may be misremembering, but your description sounds like no B+ voltage is getting to the collectors of the output transistors. Early versions of the 3020 didn't have emitter resistors, and had a jumper connecting the positive rail to the output transistor. The bias was set by opening up the jumper and putting a resistor across it then measuring and adjusting the bias. Even in your manual, the schematic has no emitter resistors but they are listed in the parts list and the component layout (R653-656). Also, make sure screws connecting collectors to the PCB are making good electical contact. Good luck. Steve
If you replaced the output transistors with modern ones, and there are no emitter resistors, you need to add them. The original design relied on the original hometaxial construction of the devices - new ones will be epitaxial and need the emitter resistance to avoid thermal runaway.
Make sure the bias devices Q609/610 and the diodes D605/606 are intact.
Regarding the title of the post: Why not make a monetary contribution to the DIYAudio forum, regardless of who may end up helping you.
I plan to do exactly that, when I get my well deserved 20 bucks. 😀
Given that's what I was going to do with it anyway... I'll "fourth" this motion 😀
Cheers!
Yeah, I vote for donate too.
I suppose this is what I'll do if I need something fixed right away... 🙂
- keantoken
- keantoken
I have a NAD701 with a very similar output stage that blew up twice, I fixed it thanks to advice from others here and learned the basics of amplifier design in the process.
As H_A said - when the outputs go, the drivers usually follow. In my case the bias transistor (Q609/Q610) went too. That probably took the VAS (Q607/Q608) with it. If R643/R644 are smoking, then it is likely that Q607/Q608, Q609/Q610, and Q613/Q614 are shorted, leaving a path from B+ through R643/R644 to B-.
Remove, test, and replace as necessary Q607/Q608, Q609/Q610, Q611/612, and Q613/Q614. Also R643/R644.
If you wanted to be extra careful after replacing the transistors you could test it by removing the outputs and R651/R652, then temporarily replacing R651/R652 with a pair of 100 ohm resistors in series with the junction connected to the feedback point. Don't try to drive a load with it, just look at the junction of the two resistors with a scope to see that you have a clean output. That will show you if the VAS, bias, and drivers are all working correctly. Once you are certain of that then replace R651/R652 and the outputs.
As jaycee said - with modern output transistors you will need to add emitter resistors. Even with the older devices I don't think this design was thermally stable, my 701 blew up once, then again after a shop fixed it. After I fixed it myself it was not thermally stable without emitter resistors.
I've always disliked the lack of emitter resistors in the output stage of these NAD amps as well.
You can 'get away' without them, but it means things can get out of hand quickly.
- $20 to the first person to give me the tip that gets my NAD 3020 working
