Hi Harry,
maybe you're right, but I think it's an interesting question why some amplifiers or op-amp's sound bright while the bode-plot seems absolutely flat between 20Hz-20KHz....
any ideas..
gr,
Thijs
any ideas..
gr,
Thijs
Thanks Harry
I actually spent hours formulating a detailed response in wordpad outlining all the things I thought might cause different sonic affects. But when I looked at it later I saw there were obvious exceptions, to every one of them. I'm also beginning to understand just how differently we all hear too, so whilst my percertions of a particular 'distortion' mechanism might be valid, how would someone else perceive it? I mean I've never seen two people hear a pair of speakers the same way, and their characteristics/deficiencies are <i>at least</i> 1 or 2 orders of magnitude greater than an amplifier. So trying to answer definitively would really be doing people a disservice.
Cheers
Cheers
Topic to vague
Bright
* FET or MOSFET
* Dome tweeters that uses any kind of material. Dome tweeters are too concentrated on one location.
* Horn tweeter are concentrated
Warm
* haven't gotten to this point
Neutral
* Haven't yet set a neutral zone
This topic is too vague. A whole novel of his or her own opinions won't cover this topic.
It is best to accept his or her own psychology of sound. In simpler terms how different people hear sound.
A good designer should take some polls to see if his or her goals on a particular project meets or exceeds their expectations.
In conclusion, there is no perfect amplifier or speaker driver.
Bright
* FET or MOSFET
Warm
Neutral
It's very hard to quantify alot of this even the above comment about MOSFETS is biased .... in class a/b mosfets are harsh, bright and misty but in highly biased SE Class A they can be beautifully warm.
AudioFreak, remember this post. Its yours.For SE Class A output stages MOSFET's are SWEET
I try to stay away from any Class-A/B amplifiers, but if I don't know what the AV reciever is bias at. I have to live on what I got.
I have a Class-H AV reciever. With Class-H amplifiers there are sub-classes such as Class-A, Class-A/B, and Class-B. If I'm due to be elecuted. I'll try to poke around in my AV reciever.
Yes i remember that post well and i stand by it.... highly biased SE Class A mosfet output stages can be wonderful to listen to. Sweet is slang for great/awesome/beautiful/wonderful.
Harry might be right?
Only might?
OK........10 to 20 years probably isn't long enough.
Bode plots will only tell you if it will blow up. Not how much RF will muck up those teeny-tiny BJTs in the front-end. I would hope the Bode plot is flat from 20-20,000 Hz.
Jocko
Only might?
Jocko
Sheet rock eh?
... perhaps you meant to use rockwool? Several years ago, while I was studying metals and materials engineering at university (before seeing the light, and switching to electrical 🙂 ), I did some research into affordable acoustic damping materials. I wanted something other than the professional acoustic treatment products which can cost an arm and a leg... It turns out that ordinary rockwool is one of the very best - better than most foams, with a flatter absorption spectrum and better low frequency absorption properties if I recall correctly. Anyway, rockwool is often used as an office cubicle wall / partition material not only for it's acoustic deadening properties, but also for it's great fire resistance.
What you want in an acoustic damping material is a large porous surface area. Sound absorption in general works by utilizing the viscous shear flow losses (aka "friction") of air volumes in contact with a surface, as the air attempts to flow past that surface. Hence, materials which posess a greater distributed surface area are most effective. This is also why acoustic damping materials work best when suspended out from the wall, as they rely on the movement of air past their internal surfaces. At a fixed boundary you have the peak of a standing pressure wave, or the null point of a velocity wave, depending on how you choose to look at it. With a little thought, you may now also understand why, as you increase the thickness of damping material attached to a rigid boundary, you will begin to absorb lower and lower frequencies better...
If you want some rockwool, you can buy it as a base/ rooting material for hydroponics. Of course, if you intend to outfit an entire room with rockwool acoustic damping, the lads at the hydroponics store might be a little suspicious of someone purchasing such large quantities of the stuff... hehe, perhaps you'll get to meet the local police constable?
Just thought I'd interject with those few random thoughts... 😉
Re: Sheet rock eh?
Hi hifiZen,
You are definitely correct in saying that viscous sheer flow is the primary mechanism for absorbtion in fiberous materials, however, it's not the only mechanism. Particle movement is also significant and especially in foam, you get helmholtz absorbtion.
You can tune absorbers to deal with particular frequencies by altering the thickness of the absorbing material and moving it 1/4 wavelength away from a solid wall to maximise the absorbtion at a particular frequency. Altering the thickness will tend to spread the frequency range of absorbtion (the thinner the absorber the narrower the absorbtion peak) as well as increasing the amount of attenuation. When you move the absorber out from a wall, what you are doing is moving it into the region of highest particle velocity for a particluar frequency, allowing it to do it's job. There is a slight comb filtering effect with this type of absorbtion as the wavelength changes with frequency, but as the high frequencies tend to be diffused and absorbed very easily in normal rooms, it's seldom even noticable.
Good builders suppliers should have rockwool in sheets of 4'x4' and in various thicknesses. It's a pain to use though, dusty and sheds bits everywhere so it has to be enclosed. If you can't get rockwool, or decide it's too messy and want to use foam instead, make sure it is open cell foam. Closed cell foam is for furniture only. You can tell by pressing a sample against your mouth and blowing hard. If you can blow through it reasonably easily, it's open cell, otherwise keep it for sitting on or packaging.
DocP
hifiZen said:... What you want in an acoustic damping material is a large porous surface area. Sound absorption in general works by utilizing the viscous shear flow losses (aka "friction") of air volumes in contact with a surface, as the air attempts to flow past that surface. Hence, materials which posess a greater distributed surface area are most effective. This is also why acoustic damping materials work best when suspended out from the wall, as they rely on the movement of air past their internal surfaces. At a fixed boundary you have the peak of a standing pressure wave, or the null point of a velocity wave, depending on how you choose to look at it. With a little thought, you may now also understand why, as you increase the thickness of damping material attached to a rigid boundary, you will begin to absorb lower and lower frequencies better... 😉
Hi hifiZen,
DocP
I achieved the best sound by now by using a class A amplifier with internal computer drive system, my speakers are own build:
2 x 3 way, using:
1 dome tweeter (80W 8ohm) (SEAS)
1 midrange speaker (no horn, but closed design) (60W 8ohm)
1 woofer (120W 8ohm) (JAMO)
(unfortunately I don't know the dB/W/m of the speaker)
and just simple cheap filter (I think 6dB/oct)
box dimensions:
30 cm width
57 cm height
22 cm depth
2 pipes d: 5.5 cm; length = 11 cm
all boards 8mm thick
fill the boxes with rockwool for warmer sound
ideal sound when placed on the floor or in corners (!!!)
2 x 3 way, using:
box dimensions:
30 cm width
57 cm height
22 cm depth
I have the BOSE Spatial control receiver from the late 70's and early 80's. This baby is Saaaaweeeettt Sounding. Well, at least the nicest sounding solid-state amplifier that I've heard. I've also hear a denon and Marantz, however, the speakers connected had terrible shrill so I couldn't really listen to the amp, just shrill.
Adding higher harmonics is what they describe in maths fourier analysis, visit this site to hear and to have an idea what upper harmonics can do to your signal:
http://www.jhu.edu/~signals/listen/music1.html
related to fourier:
www.univie.ac.at/future.media/moe/galerie.html
related to fourier:
Which component, components, or circuits make an amplifier "bright", "warm", or "neutral"?
Basically everything !
For my guitar work I prefer a good overdriven valve amp.
For disco work I prefer a SS amp for a clean powerful sound.
For guitar work I use a 4 by 10 inch cabinet.
For disco work I use a 2 by 12 inch full range plus an 18 inch woofer.
Its MOSFET not MOS fet. MOSFET are mainly used in digital circuits. MOSFET may look good on graphs but they a far from being linear. They waste to much energy to produce the given wattage. Transistors on the other hand are linear and very predictable.
Mosfets are not a drop in replacement for BJT's, they are fundamentally different and don't work in the same way. Many people don't like them because they don't know how to use them. I once felt the same way. Mosfets, especially the hex type used for switching are exactly what you want to drive a motor, transformer, speaker, or any other reactive load. When it comes to SOA, effective bandwidth, and high conductance, the BJT just can't compete. The issue of a few extra watts from the little bit higher bias requirement is negligible. Of course they are quite non-linear by comparison, especially around the cut-off region but that is really the only drawback. The lack of linearity can be nullified by using error correction techniques. If done properly, the result is better linearity and SOA than any BJT. The downside is a having a bit more complexity.🙄
My EC hexfet amp sounds ******* wonderful. Not harsh at all, but full and crystal clear. Even as a single monoblock, it is easy to hear the separation of instruments in the music. Having low overall distortion, particularly PIM and IMD really do the trick when it comes to "sound". IMVHO, a bandwidth of >400KHz and very high damping (by-product of the EC) really helps too.😀
Sorry, i have not readed the entire thread.
But really, serious, the speaker can make that..not kidding.
of course there are other reasons, but i think, mainly the speakers can do that, some of them have better trebles, or mids, or bass.
There are things in this life that we go searching for sophisticated and complicated reasons, when the real thing, the real answer for our needs, is easy to see..we are addicted to complicate a lot.
I am making some experiences here and i could see i can make any amplifier brigth, warm or everything you want, only tweaking passive crossovers
Simple that way.
regards,
Carlos
Simple that way.
regards,
Carlos
Sheetrock is better known as Plasterboard (in the UK), or Drywall in the US.
Drywall - Wikipedia, the free encyclopedia
nigelwright7557, I think you may have set the record for dragging up an old posts - seven years six months. 😀
assuming that the speakers are matched to the amps outputs,
an amp will be warmer than another if even order harmonics are
favoured...if odd harmonics are favoured, then, it will sound bright..
a musical instrument produce both even and odd harmonics, the odd
one give brillance...
- What makes an amplifier "bright", "warm", or "neutral"?
