Hello,
A few months ago I posted here looking for help designing a subsonic subwoofer for use in an art project. I wanted to create intense pressure that could be felt rather than heard. After getting great responses back (thanks to all, especially Mark Seaton, GM, and Just A Guy - so much great info), I made a simple ported 15" tempest subwoofer using formatube for the 340 litre enclosure and monstrous stormwater pipe for the port - just to get an idea of what I was up for....
Those poor vienna acoustics speakers look so dwarfed....
The formatube is 500mm, 1900mm long, capped at either end with 32mm mdf routed to fit, all held together with sikaflex adhesive. The port is 225mm pvc pipe, about 1200mm from memory, with 50mm radiuses of mdf either end.
I am driving it with an old Perreaux 6200B (300W per channel) using both coils of the tempest separately (is this wrong?) When I dial the Perreaux all the way up the windows shake at 16Hz and the driver gives quite ridiculous excursions, with virtually no distortion. I realise that 16Hz is plenty low enough for me. Pure tactile sensation is what I am after, with overtones carrying up into the audio range (unavoidable and not bad).....
But, IT IS SIMPLY NOT ENOUGH PRESSURE. I need a driver and enclosure, or multiples of, that will provide a felt pressure wave in a room. I realise that this depends on the room size, material, what is in the room, etc - but the room will change (unavoidable), and I need some advice to start moving in the right general direction - extreme amounts of air moving, high spl, like what you get at a concert venue, but at 16-20Hz. I am reading up a little on acoustics, but it is hard to get the practical experience when equipment is so costly....
The audio I propose to put through it will consist of a series of 16-20Hz pulses, like heart beats, perhaps 1- 2 seconds long each, with a quick attack and a fast decay of around 2 seconds, the pulses spaced 8 seconds apart - so it is very intermittent. I do not need musical sound - I need it to push against your skin. The idea is that it will accompany projections of slow-motion colliding boxes (but that is another long post) that I want the audience to experience in a tactile way as well as visual.....
So, the output does not need to be particularly musical.
This is my trial run, and it has helped me work out what I need to do. I still have the tempest no matter what I do, and the enclosure building has given me an idea of what I am up against. I am probably needing a few more drivers and amps by the sound of it though. I just need a recap and any suggestions of where to go from here....
Questions -
How many drivers should I play with?
What would be the best sort of enclosure - sealed high transient punch, or ported/PR high spl?
Do I need a much higher spec amplifier?
Should I be looking at something like a Servodrive Contrabass like Dangus originally mentioned?
Mark Seaton had an interesting idea of a bass cardioid system - is there any more info on anything like this around? (http://www.diyaudio.com/forums/showthread.php?t=121543&page=5)
Am I a stupid crazy artist who has no idea what he is doing?
Thanks again for all the help that has been dished out - it was incredible to find such detailed help and support from people here - it is such an arcane area of knowledge and it was most appreciated!
I have had fun thus far, and I am just beginning.....
Questions -
directivity
After scouring the net looking at cardioid subs (not setups) and servodrive, it seems that directionality would be a great thing.... I will try to research more, but it is difficult finding the needle in a haystack as I am no acoustician or audiophile.....
Interesting project.
The challenge of producing 16 Hz to 20 Hz signals at the levels you're suggesting is that you're going to need to move a lot of air to achieve that. That usually means big boxes, big drivers (and many of them too) and lots of power.
Or you can "cheat" a bit 🙂.
Where is this display going to be hosted? Do you know the dimensions of the room? Do you have access to it?
Here's what I'd be considering if I was in your position - I'd settle on driving the room at one of its lower resonant frequencies (these are dependent on its room dimensions), and designing a sub that has a massive peak at that resonant frequency. This suggests the use of an vented, bandpass or even tapped horn with a peak in its response that corresponds with the chosen resonant frequency. Furthermore, I'd place the sub in the room at the location that makes the most of that resonant frequency.
This is similar to what the car audio SPL guys do, 'cept of course the resonant frequency they settle on is a lot higher (smaller room = higher resonant frequencies).
You're likely going to need more than one 15" driver driven by 300W, but it's a start.
Brian, cheers for your response. The problem, and this is fundamental, is that the room will vary and I am never going to be able to get a perfect fit to what I want. I am looking at warehouse galleries - large solid places, low ceilings, concrete and brick. But I have not got a specific place yet, and cannot until I have finished the filming and made the speakers, etc....
Your idea of using the inherent room resonance is great - something that I will have to play around with....
And this, I guess, is the crux of the matter - I need to play around. I do not have experience in this field, so I need starting points. How does this sound - two tempest or maelstrom enclosures, a decent amp and a behringer DCX2496 (as suggested by Mark Seaton in a previous thread), and start playing around and trying to see what I can do in the room, as you both seem to suggest?
Does this sound like a good next step?
Cheers again!
Cheers again!
Cheers again!
You need to be able to move a lot of air to achieve what you want to achieve. I think two Maelstrom vented subs driven by as much power as you can afford would be a good start. Make the enclosures big enough, and vary the response peak by varying the port length (or, if you go with PRs, the weight attached to the PRs) to match the room resonance mode you're trying to excite.
I think you're going to need a corner-loaded horn to get the required SPL unless you want to buy and power 50 of those 15's. If the venue is big and open enough that you don't have a corner handy, you can make a "corner" fire it into out of 2x4's and OSB and make it part of the display.
Hi, I remember you and your project quite well, although I don't remember anything that was said except for a few details. Thanks for the update.
Anyway, if I remember correctly, at that time you did not have a rock solid frequency response or spl goal, but from the sounds of it now you do - 16 to 20 hz bursts at concert levels. A very clear goal will help a great deal, so that's a step in the right direction, even if the goal is going to be very very hard - or impossible - to achieve. 16 hz at concert levels isn't going to be easy.
I'd prefer not to add any additional ideas before at least going back and reading what I said in the first place (which I can't do right now), but I do clearly remember telling you to look into the safety issues involved, especially for staff that will have to experience this over and over all day long. I'd like to remind you of this above all else, just in case you forgot. A LF effects machine like this has the potential to make a lot of people very very sick, damage the building (and contents) and it will be almost impossible to contain the "sound" in the presentation room. That is where Mark's cardiod solution could help, but then you trade specific localization with sub optimal sub placement locations.
I'll go back and reread that old thread when I have time to see if there's anything else I can contribute, but I think we covered all the bases fairly well the first time around.
Just as a refresher, repost the estimated average room size these will be used in (huge IIRC), max size per enclosure, max total size, budget, any equipment you already have that could be used, etc.
You are going to want to stay away from sealed, unless you have a massive budget for subs and amps and all your presentation locations have a LOT of power on tap.
just a guy, thanks for the reminders!
i have looked back at the previous thread and need to soak it all in - excuse me if i miss points - this is a stretch for me - i am learning (and this seems a steep curve to do it on, but hey - no pain no gain....)
i hear what you say about the safety issues. this is becoming a priority now that i reliase what I am doing. this is another reason Mark's idea of the cardioid setup appealed to me - controlling the flood of bass at least a little would be great....
several things you asked -
the installation will be in an average room 8 x 16m. hypothetically.
the maximum enclosure size is governed by what i can fit onto my trailer, and get into a normal door (just in case there are no doubles or roller access)
budget is rolling and escalating - I do not have much funds, but I just received a $20,000 grant from the government - not that all of this would be spent on speakers by any means. I would put the budget at around $5000 for the audio. I have one 15" tempest and a few old perreaux amps.
other things -
the audio pulses, 1-2 secs every 8 secs or so, will last for 3 minutes, after which they will be silent for 3 minutes. this is part of the audio-visuals fading to reveal the actual crashed boxes (read "art" with a lowercase a) in the gallery. so it is intermittent in that respect. ALSO, the whole thing is triggered in the gallery by a motion sensor, so it will be off when there is no audience (expected 70% of the time - hypothetically)
and i realise that i am asking for alot in this exercise, so i want to get as much as i can and learn as much along the way also. the idea o setting up something flexible for trialing and trimming within the space sounds good to me - two enclosures, as Brian said with PR's with weights to play with the resonance, perhaps a behringer DCX2496 to play with cardioid placement of the two enclosures....
you are all right - i need to play, but that is expensive, and i need to find a flexible system that i can learn with and use to give me some hopeful possibilities TOWARDS what i want.
so i guess that is what i am asking.
why has it taken me so long to work that out? no wonder i was so confused and no-body could help me!!!
apologies and thanks again.
other things -
oh, and another thing - the audio is sourced from recordings of colliding hollow copper boxes, which i then manipulate in soundtrack pro and other programs - so i have maximum flexibility in what the audio actually is - i can trim and notch to make it whatever it needs to be for this (subtle?) effect of pressure on the body.....
Build a clone of the Danley 221 ...
Or just lease a real one ... or the mattter horn!
Air cannons ?
Or just build a false floor on top of some servo's.
Side note.
Built some BIG McCualey 6174 (is that correct? ben awhile)
that did 20-31 Hz at 95 db. Had 6 of those on a 5 way system as center fill.
In a 15K square foot room you couldnt be at the back (facing subs) as your eye balls wouldn't focus and your testicles would bounce around.
SO if you did get this done
remember you will make people sick. ALSO that **** travels a LONG way.
You wont be playing it very long. And hell at what point do you start to cause structural damage? If not ton the building your in, then the other art work?
Air cannons ?
Side note.
Greets!
You're welcome! Don't remember your original thread, but even a pair of SD CBs will just be '******* in the wind' since a live concert's 'punch' is in the BW above 60 Hz, so for equal loudness at 16-20 Hz requires at least 140 dB at the furthest listening position, ergo those in front are going to get hammered if the crowd is fairly deep and/or the subs aren't elevated, which in turn will require a higher SPL to offset the lack of sufficient floor loading.
Note that two SD CBs made short work of trashing my stick built/floating floor house, so your venues are going to need to be suitable for a stadium concert's 'wall of sound' output capability to handle repetitive concussions.
Anyway, consider for example that for a speaker with a 115 dB peak SPL @ 'x' watts will require a 17 more plus 17x more watts to get to 140 dB and you'll need more if there's not enough room gain, so unless your trailer is pulled by a diesel tractor I'm guessing that you can't haul enough speakers, amps and associated paraphernalia to do what you want to do plus I doubt that even 20 grand will be enough to fund it. This is why large concerts typically are already > -24 dB/40 Hz referenced to 60 Hz.
WRT health, etc. issues, read and heed lest you maybe wind up in court: http://ntp.niehs.nih.gov/ntp/htdocs/Chem_Background/ExSumPdf/Infrasound.pdf
GM
GM
GM and FlipC - thanks for the thoughts.
Perhaps I am getting a little too wound up in metaphors of concerts and stuff.
You know that feeling of awe as the low pipes on an organ kick in? It is a felt wave, it is not wrenching the building apart or popping bloody eyes from sockets - it is a much more contemplative grandeur. Perhaps I have no idea what spl's are really like at 16Hz and only need 100dB of less?
I want audience involvement with the visuals through a tactile pressure wave - not necessarily bowling you over, but definitely felt.....
Cheers GM - i will read my way into infrasonic litigational paranoia again! i remember reading this last time we discussed the matter on the previous thread - will be good to refresh my memory about it.
Thanks again.
Thanks again.
You can't make 16-20Hz directional. It simply won't happen at any normal scale.
Creating a "corner" won't work ether as the wall size will be enormous.
You could however create kind of a pressure zone with multiple subs in a "ring" with the right distance to get added loading.
Outside of it the pressure will cancel somewhat to bring down the volume a bit.
This was a tip by Ingvar Öhman that he told in regards to localized bass. It was some time ago though.
I have not done any calculations but I have no reason to doubt him.
Should be 1/4wl in diameter I guess so it cancels out at 1/4wl outside.
If I got it right.
I wonder if 4 bass towers would do it.
A big organ usually plays at 90-100dB but the feel if it filling a giant hall is something else. 90-100dB at home does not sound the same.
I don't thing you need a tremendous amount of SPL as long as you get creative with setup and waveshapeing. Add some well tuned content higher up into the 30Hz range, if done right it will not sound much but add to the rumble feeling.
If I got it right.
I'm a long term lurker on these forums and I just had to comment on this thread.
Sometimes unusual needs dictate unconventional approaches. I was thinking a about an unconventional transducer - specifically the Tymphany Linear Array Transducer - in particular the LAT 700.
In WinISD I modeled up 4x Tymphany Linear Array Transducers (LAT 700) driven @ 600W in a 21 ^ft ported relex enclosure tuned to 17 Hz which overall nets out to about 115db with a f3 of 16Hz.
I would suggest a Butterworth 4th order HPF @ 16Hz for very smooth LF extension and a LPF LP at around 50Hz
The thing about the LATs is that they are both light and powerful for their size and due to their design virtually vibration free - they simply push air...
Just a thought
Just a thought
re 'low pipes on an organ ' - that might be easier & cheaper, an organ type pipe powered by bursts of compressed air? (Awesome sub BTW)
You're welcome!
Then you're back to choosing between mine and others original BP recommendations in which case the infrasonic health, etc. issues don't apply.
GM
Maybe multiples of the new 21" Maelstrom?
Alternatively, a couple Danley TH-50's--but first try a higher frequency and see if you get the same effect you desire. Maybe very high levels at 30 or 40Hz will do the trick--much easier to accomplish than 16Hz.
some interesting reading on infrasound (large grains of salt req'd):
http://en.wikipedia.org/wiki/Infrasound
http://www.londoncircle.com/soundofdeaths.html
http://crab.wordpress.com/2008/01/14/a-short-history-of-sound-weapons-pt2-infrasound/
perhaps what you need to do is hire a 'wall of sound' - enough PA gear to get the levels you want. check out the Mythbusters 'Brown Note' episode
Thanks all - I will keep on searching from the links and suggestions you have given me.
At the moment, I need a setup to experiment with, and Mark Seaton's suggestion from the old thread seems a go - flexible. So I will make up another sub and get some electronics that allow me to play with arrangements of them in a room.
I also want to do a quick experiment to see if I can make up a long stopped air-driven pipe (pipe organ style), and whether it will give me the effect of pressure, which I could supplement with more musical notes from subs. This is art, after all, not hifi!
Getting more and more complicated.... And fun!
Thanks again for all your suggestions!
- Subwoofers
- Help needed with new subsonic design, trial pics enclosed....
