Inspiration for future ZEN Versions - basic description of Italians 400.000 $ Amp
Hallo Mr. Pass
The Ultrasound design group wrote follow (about their integrated amplifiers) concerning the three basic driving methods of loudspeakers
1) VOLTAGE driving
The output impedance of the amplifier is very lower than that of the loudspeaker. In this way, we keep constant the voltage, while the current varies. It is the simplest system, used by all the solid state amplifiers, but it is the worst from the point of view of the musical result.
2) POWER driving
The output impedance of the amplifier is equal to that of the loudspeaker. The maximum transfer of power is achieved; such a system is used in tube amplifiers (through the output transformers).
3) CURRENT driving
The output impedance of the amplifier is very higher than that of the loudspeaker. In this way, we keep constant the current, while the voltage varies. It is a system never used because his complexity, but it is the best in absolute from the point of view of the musical result.
This very interesting statements you can read about the weblink
The revolutionary Ultrasound amplifiers
also the output requirements, output peak current: 30A, output impedance 1 Meg-Ohm
(sroll down to the commercial integrated amplifier "Parsec") also to read by the above weblink
Current driving basics of this design group you find about the weblink
Current driving
This could be also a revolutionary approach for ultimate sounding single ended amplifier, based one of the "ZEN" circuits. A variation of a nearly clean current controlled output stage version.
Instead of the tube based input-resp.driver stage I would even here prefer a solid state variation, perhaps a double cascoded voltage gain or buffer stage like the french brand Larvadin - for the weblinks about this go to
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph?
Amazingly for me is the great simplify of the whole circuit of "Parsec" - i. e. only two stages, I think one buffer stage (tube based) and one voltage/power gain stage like the ZEN var. IV (Penultimate Zen) about the pdf-link
www.passdiy.com/pdf/zen-v4.pdf
But I don't understand, how the Ultrasonic design group make a output impedance of 1 Meg-Ohm by output peak current of 30A. However I think, that considerations could be helpful to create new projects
The explanations about
sounds very interesting.
But is the follow explanation true ?
CURRENT driving:
I would like to know the exact topology.
Everyone is allowed a little "puffery" (actual US legal term) when describing
their product.
There are occasions (more than you might think) when a higher output
impedance brings something to the table, but I find as a rule that having
an output impedance greater than 16 ohms or so is too high for even those.
Keeping it at 16 or below also has the advantage of giving greater stability
in the real world.
just for educational purposes
:clown:
