How far you want to go?
If not too much you may try the cheap Audio GD clock, it has the DAC and Servo output at the same time so for the price it ay be worth it. It's not the best but it's dirt cheap for both Servo & DAC reclocking.
http://www.audio-gd.com/enweb/pro/diy/JZ-1.htm
Thanks guys! 😉
According to all of You.....the winner is LM4562! 😀
@Malefoda:
Don't know but I'll see.....
,....and again, thanks for advices and suggestions!
Also I'll be free to ask any help related with mods of 67SE.....and thanks for that guys!
Hear you soon!
P.S. I'll inform You about any progress in sound!
@Malefoda:
Hear you soon!
jhmee9 said:Actually, noise is audible when you got ear right on the tweeter,
and as I said, sounds like "less noise" phono input.
Maybe.... that's the reason why is now sound so "open" 😀
Thanks again,...to all of You!😉
That noise has always been present, only it was muted by the muting transistors during stop and pause. It is residual noise of the DAC. Like Brent wrote: if you want to get rid of it, install a muting relay to restore the muting function.
Some players also generate clicks and pops when switched on or off. This is normal, and was also covered up by the muting circuit.
My vote: pls. do not use OPA2604, your player deserves better
Ray
Talking of dacs Ray have you ever looked into fitting a different dac to a 63/67 to replace the NPC using the existing decoder etc
I've had a brief look in the past but never really pushed it any further.
Brent
Brent
I have a spare ezDAC PCB here that's partially built. I already did some experiments and hooked it up to a CD72 through the I2S lines. It works perfectly!
So now i'm thinking about fitting it permanently, and using the variable output for the ezDAC. It's a future project. I'll leave the fixed output intact for the TDA1547, that will make a nice A-B comparison. It will be the first CDM4 based player with 96/24 upsampling 😀
Ray.
Ray.
I tried a TDA1543 on the I2S lines, just for a taste of NOS.
Sounded very romantic and real with stuff like Norah Jones but complex music did not sound good.
Apart from old multibit DACs, any DAC that supports I2S and 384Fs clocking should work fine.
It might be interesting to try one of the Twisted Pear boards as they take I2S in and are easily configurable. Not the ESS Sabre ones, but the WM8741 and PCM1794 ones. They are quite cheap (very if you get the PCB only).
Cheers Ray but I do have a EzDac and I had it running in the cd17ki I had on the spdif but never got round to getting it working with the i2s. The 17ki was sold to help fund the ATC amp.
I was thinking more of not fitting a pcb but hard wiring the newer dac chip to the pcb. I may have a mess around with the 63se I have here (if I get time 😡 )
Brent
Brent
Jhmee you should take advantage of sample programs around (LME49720HA included (top version of the LM4562)) to get parts. For cheap'n fast fitting get 7805 else get some LM317 and 337 for powering you player for free (ex. resistors or caps).
Thank you TI 😀 (LT are far less generous...)
Hey Brent, received the C2 today, thanks man! 😎
I have to wait until my 33.8688MHz XO arrives from Tentlabs, and then I can get out the 'scope and do a 1:1 comparison
Ray
Ray
Hi Ray
Excellent. Are you going to try it in your sacd player to run it in first and give your impressions.
hope you like it
Brent
hope you like it
Brent
Malefoda said:Jhmee you should take advantage of sample programs around (LME49720HA included (top version of the LM4562)) to get parts.
Hi Matt
Would you please explain how do you do that ?
As a particular DIY modder, I could never get a positive answer from any OEM regarding samples.....
Ricardo
rowemeister said:Hi Ray
hope you like it
Brent
I only examined it very briefly, because I was home late last night. The PCB looks very good. I see you assembled it by hand, that must be very time consuming. And the LEDs look very cool 😎 😀
Dunno yet what i'm going to do first. It's not very busy here at work ATM, due to the summer holidays, so maybe i'll measure it first. I think i'm objective enough not to let the results influence the listening test
But before that happens, i'll power it up for a few days.
Ray
Hi Ricardo,
right now with my mail adress I can't have National stuff for free (wich I can with my former job corporate mail) but with Texas Instrument there is no problem, just register and fill things as "company name" with fancy info, like you were near to create a company and are doing a prototype. I think this is a very common issue in sample order's profile.
I wish I still have a corporate mail...
Talking regs, is it worth making LM317 based 5V for digital ICs? I'll do it for analog/dig DAC, clock ref., analog/dig filter but don't think it's worth it on µcon and servo... is it? Oh man I've also to do 4 for the DOS... I'll defo open a business 😉
Ray
I get them assembled for me but yes by hand, I fit the oscillator and the 6 elco caps so that I can change freq etc. The leds do look cool yes 😉 the one on the 3.3v rail also acts as a load.
cheers
Brent
Lucky you don't have to do ALL the soldering then...
I think i'm going to leave it powered this weekend and start measurements on monday. Tomorrow i'm going to confiscate the scope 😀.
Ray
Ray
Hmmmmm.....strange!
Talking about "noise" mentioned before.....I found what causing that!
After I replaced fixed power-chord with IEC socket and connect ground wire to chassis......that kind of noise getting amplified, in fact when ground wire is disconnected from chassis, "noise" just disappear!!!
Also I connected another "non-tweaked" CD player and do A-B comparison.....BINGO!...same level and usually "kind" of noise.....what means, everything is OK!
Really strange......what in case if I want to have IEC socket,...like I had? Just forget about it or solve it to be in function?
Does anybody before, had the same situation?
Any suggestion guys?
Thanks a lot!
@Malefoda:
Thanks for suggestion my friend.......I'll see.....😉
Thanks a lot!
@Malefoda:
You have caused an earth loop problem by earthing the mains to chassis gnd. I had a similar problem many years ago when all my equipment was connected to earth. My sky receiver was causing the problem due to its switch mode power supply.
Fit a 27ohm 2W resistor between chassis gnd and IEC earth. This isolates the two gnds but still allows the improvements. More than one item may need this doing
Brent
Brent
Thanks Brent,
I suppose that...........power LED on my Onix OA601 is off when I connect ground wire on CD67 chassis! (and noise becoming audible)
When I disconnect ground wire from CD67 chassis, power LED on Onix OA601 is ON! (noise disappear.....)
I'll try with resistor but currently, I'm on "stock" power-cord.....
Cheers!
Cheers!
Hi guys,
may someone confirm or give better location for 10V regs as U161 for +10V and U162 for -10V?
Matthieu
Matthieu
U161/162 are fine😉 . Or you could use 6 regs. 2 on each chip soldered direct to the V input pins 😀
Brent
Brent
- Digital Source
- Marantz CD63 & CD67 mods list
