Ok have another amp broken by my nephew, this one is a Rockford punch 200x2.
Its a 2 channel and one channel seems to work ok, and the second channel doesnt put any music out but it does punch the sub cone out all the way! (if that makes sense) Seems like all it does is push power at full only, and adjusting the gain does nothing.
On a side note: I told my nephew not to use his stereo until we replace the wires.
the first pic is of the resistor that looks bad, on the second channel.
The second pic is of a resistor on the good first channel that looks like it has a bubble - is this normal??
back side of channel 2
mor pics to come.
mor pics to come.
top side of channel 2
top side of channel 1
bottom side of channel 1
pic of channel 1 resisstor with bubble
The channel 1 components are likely OK.
Pull the 0.1 ohm source resistors in the blown channel and check all of the resistors marked 100, 200 and 620 (should be one 620 resistor for each source resistor) in that channel. List the ones (ex. R125, R150...) that are out of tolerance.
At least one of the output transistors in the blown channel has failed. You should replace all 6 in that channel. You should also replace all of the source resistors in that channel. Mouser:
LVR03R1000FB12
LVR03R1000FB12
i have this exact same amp on my bench right now . similiar problem as i have a blown channel but it took out the power supply as well.the power supply fets are MTP50N06 , does anyone know if RFP70N06 or HUF75337P3 will work in place of the blown ps fets. just trying to get it going with what i have on hand
Either of those should work. Before you power it up fully, connect only remote and ground and confirm that the gate drive voltage on the leg of each of the power supply FETs is ~5-6v DC. If you have one or more that's significantly higher or lower, the driver transistors may have failed.
this is going to sound like a super noob question but i've been idle as far as repairs go for so long I have to ask. The gate drive signal is going to be measured off the leg of the fets connected to the 68 ohm resistors correct?if thats true i only have 4.7 volts.Is this too low?
spooney said:also wanted to say sorry to the original poster.all further questions will be posted in a seperate thread
hey no prob, been tired and busy with other stuff for last few days, still have to chech some #200's on the board.
Perry Babin said:Those all appear to be within tolerance.
What would be the next step??
- General Interest
- Car Audio
- Rockford Punch 200x2 amp - needs repair
