RIFA PEH169 Caps?
RIFA PEh169
At this moment we can offer RIFA PEH169SV488Am at very good price, it's only USD20 per piece, but i am in Shenzhen China.
PEH169's
I've got a bunch of 2005 stock (non-RoHS) PEH169's:
4700uF @ 450V 2pcs
1000uF @ 200V 2pcs
5600uF @ 250V 2pcs
4700uF @ 63V 32pcs
22000uF @ 63V (Screw Terminal) 2pcs
Let me know if any of the above would work. I'd be happy to see these go to a good home, so a few dollars each (for handling and packaging) + postage at cost.
Giovanni,
I'll try and get you pricing for 120 pieces of PHE169 @ 22000uF tomorrow.
What is your preference on temp? 85 or 105? 85 will, of course be a little cheaper.
Also, what voltage do you need. Evox Rifa do up to 100V at this capacitance in this range.
At 100V capacitor case is 75mm diameter x 115mm height.
Matthew
Just checked, and you are correct.
Manufacturing of Evox Rifa large can electrolytics has now been moved to a low wage / weak currency location - Weymouth in England!!!
Seems that BHC are now making them under the Evox name.
Guess it's all part of the Goliath that is KEMET (TM)....
I suppose now I'll have to be patriotic for Evox Rifa instead!
