Doxa 70 Se Schematic??
I'm not sure what the difference is between the Doxa 70 models, but if possible go for the Doxa 70 Signature. This is the most expensive of the 3 amp's. It would be interesting to know the exact differences too.
To my knowledge there are different versions too. The last version of 70 Signature has better bass control.
Doxa 70
Hi There!
Did You get scematics? (If not i have it)
Do You or anyone know what BIAS current normally is on a Doxa 70? On my Doxa 70 i measure 3,5mV over emitter res.(After 1/2 Hour,without any load)
Emitter res is 2 x 1R in parallell giving me around 7mA!!.
Please advice me as i need to know :)
I am draw schematic doxa 704. Maybe i made mystake. Resistor on th eemiter of input transistor have wrong connection. I put, i think corect schematic.
schematic clarification
do you know what should be the output on the transformer? 32V AC? also I would like to know What each T(*) means as a connection. There is also a missing connection on the right between Q26 and R49. And a floating connection D6, D10, E3, E4( is that ground?
thank you,
Cristian
