I started another thread regarding midranges, and from some of the answers I got and quite a bit of frantic reading up and investigation, I made some observations which might be interesting to bounce of the forum...
it really started with an interview with Joachim Gerhard of Audio Physics, posted on Troels Gravesens web-page: http://www.speakerbuilding.com/content/1039/
Here Mr Gerhard comments that many new drivers are very heavily damped in order to give flat frequency response, something which is characterized by low Qms. He then goes on to say that many of the older drivers with much less mechanical damping and high Qms were much more dynamic.
In my previous midrange thread, a surprising many people recommended using pro-drivers for good dynamics and response.
Looking at the data for many of these drivers, I found that most of them had very high Qms, typically 4-8, whilst msot Hi-fi drivers seem to be in the 1-1,5 range.
What I also found was that most of the pro-drivers seemed to have rather ragged frequency response, perhaps a result of poor damping?
It is within this context I find two drivers very interesting as candidates for 200-3000Hz midranges for my active speaker project;
The Vifa WN 17 255 suggested to me by Calvin and the Focal 6W 4311B, which I found on the Zalytron web page.
Looking at the efficiency, suspension compliance and the Qms of these drivers, they seem to have relatively low mechanical damping, yet the frequency plot is very flat, at least compared to a lot of the aforementioned pro-drivers.
The Focal driver has a Qms of over 8, a number many times higher than for any other hi-fi unit I have seen. The frequency response is perhaps not as smooth as that of the Vifa unit, but still looks OK.
So, what I'm thinking is that these drivers represents examples of drivers which are actually reasonably linear without relying to heavily on mechanical damping, which to the best of my understanding is conductive to good dynamics and transient response.. (?)
Or am I making totally stupid conclusions here??
Of course, drivers with low mechanical damping will still need to be controlled somehow if they are not to resonate and flap about uncontrolled so to speak, but an amplifier with good damping factor should contribute towards this i suppose?
Anyway, some viewpoints,and by all means corrections, on this topic would be very interesting!
Usually, I just look at Qts, beacuse it is what is used for simulators & and is a combination of Qms & Qes,
Qts = Qms * Qes / (Qms + Qes)
and I think this is what most people look at when deciding the suitability of a driver for a particular task.
However, I think a discussion of how the individual Qs affect the performance would be interesting and enlightening.
From http://web.media.mit.edu/~meyers/mcgill/papers/loudspeakers.pdf
(looks like a not-to-well-written undergrad paper, but it’s a starting point)
“Electrical damping relies on magnets to act as the restoring force in the speaker. Cheap, small magnets result in multiple resonance’s in the diaphragm because they are too slow in restoring the vibrating mechanism to its equilibrium point. This causes a poor transient response”
http://www.speakerplans.com/index.php?id=faq1 says “low values of Qts give a tight and punchy sound but with little weight or low bass and high Qts values give a slow and heavy sound that will give you lots of low frequency output”, yet ” Drivers with a very high mechanical Q can sound more open, cleaner and have a better dynamic range. This is because they have less loss. The surround is more flexible, the spider is better constructed, they have better air flow and usually have higher sensitivity. So a high mechanical Q is a very good indicator of energy storage behaviour”
I wonder how real these generalizations are in practise, and what they’re leaving out
more discussion here: http://www.diyaudio.com/forums/showthread/t-44570.html
as Ron E says in that discussion, there is an apparent contradiction.
I’m thinking that High Qms drivers will resonate more because the damping is not well controlled, i.e. the output does not as accurately follow the input as lower Qms drivers because of the suspension. (Of course, some may prefer that...). I suppose there must be a point of compromise between lack of damping and over damping, and the box needs to be taken into account...???
Pete,
Some very interesting links you posted, enjoyed reading those and it certainly inspires further investigation.
As I don't really understand the Thiele Small parameters properly (yet), this is all fairly speculative yet on my account, but it is interesting to try and make some deductions.
Hopefully, other more knowledgeable forum members will chime in..
The fundamental concept of damping and harmonics is fairly understandable concepts.
If there is no or little damping, mechanical swinging and uncontrolled oscillation is free to occur, and in the context of loudspeakers, this will result in cone motion not called for by the input signal.
This can of course never be good, so some degree of damping is obviously a must.
But can we get to much damping, or damping of the wrong kind?
Lets think of a car suspension. There is a spring for allowing motion of the wheels independent of the car body. If the dampers are bad or missing, the car will bounce uncontrolled after the suspension has absorbed energy after hitting a bump.
So we need dampers to absorb and control this excessive energy so the suspension can be brought back to its normal state.
But what will happen if we apply to much damping? The dampers will then prevent the suspension from responding quickly enough, thereby allowing the energy of a sudden bump to pass straight to the chassis of the car. That's why a sportier and more firm/ stable suspension often gives a harsh ride.
So what would be ideal then? That would be a damper that was firm enough to give stability over undulating road surface, yet compliant enough to respond quickly to sharp bumps and minor road imperfections.
In real life, there is often a compromise involved. The ideal would of course be a suspension system that was adaptive or active. (and these do exist, the damping is actively and continuously adjusted to suit the real-time requirements)
It is also known that cars, and in particular motorbikes, with relatively heavy wheels and suspension components (unsprung mass) place higher demands on the suspension, it is more difficult to damp the motion of a heavy wheel than a light one.
So we need damping, I'm not gonna argue against that.
But what I find interesting is that we have two components in the damping equation, Qms and Qes.
As I have understood it Qms is mechanical damping in the form of suspension stiffness and inherent energy absorbing qualities of the cone and its suspension parts. and the higher the Qms value, the less these factors contribute to dampen the cone and bring it back to its neutral state.
then there is Qes. Now, this one is a bit harder for me to grasp at the moment. As far as I understand, this describes the degree of control the motor can exert on the cone. This degree of control is a function of the strength of the motor BL, and the mass it has to control, lower mass and higher BL equals greater motor control.
The total Q, Qts, is a resultant of Qms and Qes. This means that two drivers with similar Qts, can have any variation of ratio between Qes and Qms. The Qts is important for selecting the correct enclosure, as the system damping is the sum of the acoustical damping of the box and the total damping built in to the driver it self.
but what about the ratio between Qes and Qms?
What would the ideal loudspeaker look like compared to the car suspension?
From what I have understood so far, I'm inclined to compare the mechanical (or passive) damping of a speaker with the shock absorber of a car. a degree of passive damping would reduce oscillations and resonant modes, but at the same time resist sudden, i.e. transient responses. The fact that many linear and heavily damped (to damp out resonances and achieve linear frequency response) are often described as dull and engaging is worth considering.
I have also listened to small heavily damped studio monitors with +/-1 dB frequency response and they DID sound terribly dull although the tonal balance was perfect.
Too little mechanical damping, well, there's the church bell...
But what about the electrical damping then?
A weak motor might be able to push the cone in to motion, but it might be hard pressed to exert enough force to overcome the momentum of the cone and reverse it as the polarity of the signal waveform reverses. this will become especially noticeable if there is relatively little mechanical damping to brake the "runaway" cone.
But what if the motor is strong?
Ideally, the motor should be powerful enough to exert absolute control of the cone, an electromagnetic fist slaving it to the signal waveform, be it a "slow" sinuous low frequency or a sudden transient detail.
In my mind this sounds like the active damping I outlined for the car suspension.
Now, I've so far assumed the cone being a "perfect" piston without any internal resonances. All cones and diaphragms have internal resonances and these are obviously beyond the control of the damping a strong motor can provide. Hence any cone resonances must be taken care of by mechanical damping inherent in the cone material, or the driver must be operated outside the frequency range where these resonances occur. (like with some metal cones)
But back to Qes....
A strong electric damping not relying on efficiency sapping and transient flattening mechanical damping must be very good then?
Surely, this is to simple to be true, or is it?
In my somewhat simplistic view of this issue, I can only find one culprit.
Ultimately, the control (and damping) provided by the motor system, depends on the amplifier and its damping factor.
What is the damping factor of an amplifier? To my limited knowledge, it is the amplifiers ability to exert control over the driver.
As current is fed in to the voice coil of a driver, it sets up an electromagnetic force in the coil which reacts with the permanent magnetic force of the motor magnet, thereby causing the coil to move. Fine.
But as the voice-coil moves in the magnet gap of the motor, the opposite also takes place, the permanent magnetic force induces current in the voice coil! Just like a dynamo. The amplifier will have to counter this "back-current", and its ability to do so determines how well the amplifier controls the motion of the voice coil.
Try this experiment.
With your amplifier switched of, gently tap the cone of the woofer with your fingertip and listen carefully.
Now switch the amplifier on and try again. You are likely to notice that the tapping sound is now much more damped. this is your amp trying to keep the voice coil in position against your "input" like it would also try to counter the unwanted "input" originating from resonances and uncontrolled cone-motion.
I was quite fascinated the first time i tried this!
This could perhaps go towards explaining why so many manufacturers build drivers with relatively high Qes and low Qms.
A driver with a high Qms would rely highly on good amplifier control and damping in order to work well, i.e. rely on high quality amplifiers, beefy low resistance speaker cables and crossovers which would not compromise the damping factor of the amp.
This means that if you and I, the consumer, buy a mediocre amp and spindly speaker wires, the loudspeaker manufacturters otherwise excellent product could end up sounding s**t.
The other way around, in a active speaker where a high quality amp module (which is of course what we build anyway), hooked straight up to the driver with a short length of beefy wire and no x-over network with nasty inductors and resistors, a high Qms/ low Qes driver might provide the best compromise! (?)
From my rambling deductions and other snippets of info found on the web so far, this is the direction I seem to be heading at the moment.
So unless someone comes along and puts me right, I am for the time being very much inclined to go out and source a midrange driver with very low moving mass and high Qms for my 3-way active speaker project!
But back to Qes....
Elbert,
While I think you’re correct, most modern SS amplifiers have damping factors low enough that it doesn’t matter. Active xovers are probably better because the effects of back EMF are negated, but active xovers still cause phase variation. And low mass cones will respond faster, but at the expense of mechanical strength, i.e. less rigidity > higher distortion.
Reading around the net, (and this is getting away from Q), for best transient response the driver needs to be able to reproduce a square wave as close as possible – for this, flat frequency response and flat phase response are necessary. This means the effects of the box Q, crossover and time alignment need to be taken into account, although there is some debate about the audibility of time alignment: http://sound.westhost.com/ptd.htm
Ignoring the external factors, perhaps the best we can hope for is to buy the most linear motor we can afford, with a frequency response as linear as possible outside the passband of interest? In the end it probably comes down to personal preferences and the compromises one is prepared to make e.g. metal cone vs. paper...
.. and reasoning one self out of a position one has reasoned oneself in to might be even harder!
You probably have a good point about most amplifiers having a good enough damping factor, so that might not be such a significant point after all..
However, I had one very interesting experience once...
In a studio, we had a pair of (i believe it was acoustic energy) 2-way monitors, vented boxes with an 8 Seas driver and a seas aluminum dome.
Very nice speakers, in fact better sounding than a pair of active Meyersounds we borrowed. (the meyers were about 10 times as expensive)
We ran the monitors of a fairly standard Sony amp, and were then we were given a Crown 300 studio amp on trial.
In terms of thd, etc., the Crown was probably not that much better than the Sony. The difference in these parameters are usually much smaller than the distortion generated in most loudspeakers anyway.
But what an amazing difference! the sound became so much tighter and detailed, not to mention dynamic! I actually found the difference quite astounding at the time.
Could it be that the hefty crown amp (you could probably use it for TIG welding) somehow just exerted better control of the drivers? Just speculating, these things are hard to quantify...
Again, interesting link, I'm probably gonna be late in bed again!
I absolutely agree on the cone weight issue, something too thin and flimsy will inevitably start to flex and play its own tune, I guess this is where frequency response plots come in handy! I would expect a driver with diaphragm of insufficient rigidity will be revealed by a ragged frequency response?
You probably have a good point about active crossovers and phase shifts and I should look closer in to this as it is something I'm not to familiar with. My assumption up until now was that you get phase shifts in both passive and active filters so that it wouldn't really make any difference at the end of the day? looking at the cost often involved with good passive filters, i figured I could just as well go for an active solution with all the other benefits that has!
Anyway, trying to get a grasp on how to select a good midrange... it's just like red wine, you just can't taste them all!
Taste them all or die (from liver failure) trying!
Read the last link you posted...
Although in many respects a theoretical excersise, some food for thought regarding time and phase.
My belief is that interference, due to phase shifts and reflections is inevitable, when one considers the nature of sound, it is actually unavoidable and unless excessive, a perfectly natural imperfection?
Having said that, I hope to keep the problems to a minimum by keeping the tweeter and the midrange reasonably close together (less than the wavelength of the crossover frequency as recommended in some literature), and by using electronic filters with relatively steep slopes.
But regarding the time aspect, this is something I agree on the importance of! In the 200-2000Hz area, spatial information is mainly based on the arrival time differential between the ears, and this time domain is the same where early reflections are most pronounced.
One way I intend to minimize this effect, is to use absorbing material on the baffles. I'm also going to use the new diffraction/ waveguide controlled DXT tweeter from SEAS which should minimize baffle effect on the high frequencies.
Anyway, Ordered a pair of Access 6A's (focal) from Zalytron.. with high Qms, so I guess I'll soon find out if it has anything going for it! .)
Hi Elbert,
i tend to agree, that speakers with high mechanical resistance
(mostly due to the surround material chosen) tend
to have poor dynamic behaviour, especially at low signal
levels.
20 Years ago i measured some woofers with a very resistive
surround, i think it was made from PVC .
By the way: The stiffness of the surround was very dependent
on temperature ...
The woofer had very different parameters at different signal
levels. As far as i remember fs was shifted about 25% .
At low signal levels fs was higher than at high levels near Xmax.
(How to properly design a BR cabinet for such a speaker ??? )
Such a speaker tends to sound dull at low levels and wakes
up when played loud. Speaker with high Qm are to be preferred, because of better performance at low levels. But this is just a tendency, it depends on the materials used to achieve mechanical damping.
If you build surrounds with low resistance it is more difficult to control resonant modes of the cone. For woofers of small size however this is not such a big problem, for fullrange speakers it is ...
levels.
on temperature ...
Allthough a 20 year old woofer with a PVC (!) surround is perhaps a bad example of a bad example.. (uh..).. it is interesting to hear your general views and observations.
Considering the reduced ability of high Qms driver suspensions for controlling resonances, this would just mean that cone and motor design becomes even more critical, something which is perhaps more demanding and costly than just adding mechanical damping?
Really looking forward to getting my drivers now, better start building a test box so I can determine the optimum enclosure size and port dimensions (if i go for a vented enclosure).
Elbert said:Allthough a 20 year old woofer with a PVC (!) surround is perhaps a bad example of a bad example..
That was a misunderstanding, the woofers were new
at that point in time. But i did that measurement around
20 years ago ...
But nevertheless it IS a bad - but instructive - example.
Elbert said:Allthough a 20 year old woofer with a PVC (!) surround is perhaps a bad example of a bad example.. (uh..).. it is interesting to hear your general views and observations.
Drivers that incorporate a lot of cone damping drop some of the efficiency that is sought with a high compliance suspension. But in some cases, this means superb performance. Take the heavy coated woofer in the JBL L100 (the driver is 123A, a lansaplas damped alnico 12"). It's got a well damped driver diaphragm with Qms of up near 7. Usually a motor as powerful as it has would be very low Qts due to a low Qes combined with a lighterweight cone, but they chose to damp the cone (giving it exceedingly well-controlled flat response- Troels Graveson tested it flat to 6k).
That's a counter example, most higher Qms suspensions are looking to get the most out of their motors (meaning the most efficiency) and thus generally are lighterweight cones with breakup resonances either accepted or optimized depending upon one's point of view, and the specific driver.
As with anything else, it's impossible to view high Qms in isolation, but for me, it's a desirable trait in a loudspeaker, I prefer the sound of corrugated cloth and foam surrounds over rubber anyday.
Hello badman,
i also think that a damping coat can improve quality, if
the cone's base material lacks damping, like e.g. paper.
So if there is less damping in the surround, we need damping
on the cone itself. But coating the cone does not affect
Qms directly (only indirectly by increasing the mass).
So a heavily damped (coated) cone does not conflict with
high Qms, a resistive surround (or spider ?) does.
I've heard people modify the suspension by cutting the spider, but I don't see any picture and can't imagine how they do it.
I think of the suspensions of Axiom 80 and Super 12.
Anyone know what would happen if we cut the modern corrugated fabric spiders into the shapes of those ancient phenolic cantilevers? Maybe no enough radial supports and causes side to side rocking of voice coil?
Elbert said:i.e. rely on high quality amplifiers, beefy low resistance speaker cables and crossovers which would not compromise the damping factor of the amp.
It would be a mistake to say that a qigh quality amplifier needs to have a high damping factor (ie FirstWatt F1 & F2, and many VERY good SE tube amps).
Low resistance speakr cables are not always the best, and as a generalization, crossovers are evil.
There is way more to it than just considering these numbers.
dave
LineArray said:The woofer had very different parameters at different signal
Far too people know that this is not an isolated result, TSP are not single numbers that are a curve that is a function of input level.
BR boxes alway sseemed a bit off to me. When i groked the nature of TSP i realizes why... as music plays the tuning of the box moves... can be very disconcerting.
dave
dave
would be interesting to investigate how far even the
tuning frequency of a BR Box moves with signal level.
I have not done that up to now. I would expect, that
a box with high Qb having port area large enough to
circumvent turbulent air motion in the port will not
suffer from that ... but who knows.
If the driver parameters move with signal level, the
alignment of the box gets level dependent.
This would be the case for every box design like
BR, Tuned Pipe, Closed ...
To me BR alignments are preferable which have a smooth
roll off at the low end, using typically low Qes drivers < 0,38
and a tuning ratio fb/fs far below 1.
Those alignments integrate better into the listening room
by compensating room gain due to placement and have
better transient response.
Those alignments are not over sensitive to parameter shift
of the driver, another reason to prefer them IMO.
LineArray said:This would be the case for every box design like
In a closed box the parameters move in such a way as to make little difference, TLs (particularily classic aperiodic leaning TLs) tend to be quite tolerant -- there is essentially a big R in series with the posrt, and the vented Onken-style boxes i favour also add an R to the port making them much more tolerant of shifts.
dave
My understanding of transient response has nothing to do with square waves. High Q notches and particularly high Q peaks in the frequency response are signs of energy storage phenomena, and sources of ringing and localized group delay, and the main sources of transient response degradation.
Please consider the following articles from German DIY magazine about Rms (Google translation included below)
Rarely observed but very important for the sound:
The mechanical losses
Anyone who observes the Thiele-Small parameters of a woofer, turns his attention first on resonance frequency and Qts: These two parameters determine the achievable lower cutoff frequency. The second view is the equivalent volume - Vas: It reveals what cabinet size is necessary to achieve this goal.
These parameters say little about the sound character : whether the finished box will sound quick or slow, betrays - apart from the key priority of course crossovers and housing - the inconspicuous parameter Rms.
Nobody can imagine something concrete - mechanical Ohms, measured in kilograms per second, are something very abstract.
But that's not bad: the number alone before the unit counts. The lower it is, the lower the mechanical losses in the transformer, and the more vigorous result promises to sound. Why this is so, it is conclusively not (yet) explained - just the experience confirms this rule repeatedly. One promising approach is that the mechanical resistance in the speaker chassis, as opposed to an electrical resistance neither linear nor timeinvariant - it is changing its value as a function of signal level and frequency, and also shows a more or less distinct hysteresis behavior.
The cause of the mechanical losses are in the flow resistance, in all corners of a speaker chassis, for example, in the spider or too narrow Polepiece. Therefore, ventilation openings at all possible parts of a Speaker are so important. Also eddy currents, especially in voice coil carriers, increase the mechanical losses. This is the biggest advantage a Kapton-against an aluminium former.
Unfortunately, currently there are no usable investigations performed, so until further observation applies: Rms - The smaller the better.
Mechanical losses
One of the crucial criteria for the quality of bass are the mechanical losses, expressed in parameter "Rms". Experiments repeatedly show a remarkably good correlation between low Rms and subjective as dry and accurately perceived bass reproduction. Rms is in relation to the membrane surface to set: As is a moving mass of 30 grams "a lot" for the 6 inch woofer ,and for the 12 inch woofer a "little", so is an Rms of 1.0 kg/s perfect for a 12 incher, while this would be only average for a 6 inch woofer.
Current experiments even indicates that the Rms factor has a qualitative impact to all frequency ranges - up to the tweeter. To keep this parameter low, two important design criteria must be met: The coil carrier must consist of an electrically non-conductive, or at least bad conductive material, so that no eddy currents may arise, which carry high mechanical losses for the biggest responsibility. Moreover, the mechanics of friction designed chassis, especially the vented side openings behind the spider are important in this context.
(not a perfect translation though)
Mechanical losses
Energy storage is key
More mass requires a bigger spring and more damping, whereby Qms and Qes come to play. For example midranges/fullrangers (lighter cones were it makes a difference) tend to have a higher Qes letting Qms (Rms) have a larger influence on the total damping Qts, mostly because the mids crossovers and resistive networks tend to isolate the amplifier damping factor.
http://www.linkwitzlab.com/frontiers_2.htm
- The significance of high Qms..?
