Ok, I have this friend... let's call him Joel Ahrens.
Now Joel has 2 subwoofers stacked on top of each other. Both are 10-12" subs. One of them is a MK brand sub. He uses the system for both home theater and music. As far as I can tell both subs are fed the same under 80hz signa from his Rotel multi-channel preamp/processor.
Now I keep telling him of the joy of DIY speaker building. And he scoffs at the concept.
He says he'd consider a DIY sub if it was 18" and could hit 10hz. He says he'd use it in ADDITION to his current 2 subs.
Ok, so how silly is Joel being? He says if I build him an 18" sub that can hit 15hz he'd be all over it.
So is there an 18" driver that can comfortably hit 10hz and costs less than $1000. Also, is there ANY real movie or music content down that low?
Greets!
Well, you don't say at what SPL and you quote both 10 and 15 Hz, but here's some info to mull over and while he chose 14 Hz, some will be good to 10 Hz, especially the Aura 1808: http://www.baudline.com/erik/bass/bass_list1/index.html
Yes to both, though there's little in recorded music that I'm aware of:
http://www.smr-home-theatre.org/Sub-woofer-Set-Up/How-Low-2.html
http://www.svsound.com/questions-faqs.cfm
http://www.hometheaterforum.com/htforum/printthread.php?threadid=144887
GM
GM
Anything from Dayton or Peerless or TC Sounds that can achieve sub 20hz bass? I see the Peerless XXLS line has some passive radiators that will go down to 18hz.
Can you ever get useful base below Fs even with tuned lines?
As for SPL, he likes it loud.. but I'd say 100db is plenty loud. I'd prefer under 90db since I watch movies frequently over at his place.
I'm sorry Daveis but you wont be able to hear sub 20hz. And even at 20hz it will take 120db for you to even start hearing it as that's the threshold of human hearing.
For normal music there is practically nothing lower the low E string on an upright bass which is 41hz. Very few mainly classical works will have organs or even live recording of canon fire going lower than that.
The need for subbass in home audio has grown out of the mistake of trying to recreate earthquake-like tremors in home theaters.
There's a couple of things people seem to forget though, it takes enormous sound pressures for frequencies below 40hz to be even audible and that human hearing is adaptive in the sense that if the harmonic overtones off the base frequency is reproduced correctly then we will hear and feel the base frequency even if it's not there.
So in order to answer your question, no, 10-25hz is absolute not necessary for HT or music. If you absolute want the tremors then buy a bass shaker instead.
I agree for music under 40hz doesn't do anything for me.
My buddy loves his home theater and likes hearing the big monster thuds and special effects.
I mentioned a couch bass shaker which I think he'd love.
If I compromise and just try to achieve flat to 20hz. I think he'd go for that. What is the best (low distortion, output to 100db) bass driver in the 20-40 hz range?
Adire Audio is gone. TC Sounds is no longer going to sell to DIY from what it sounds like. ALthough I could pick up a TC-2000/TC-3000 at the last minute for a bit longer. The Peerless XXLS and Scanspeak 10" Revelator might work. And then there's the wonderful Dayton 12"/15" reference drivers.
My buddy just talks about BagEnd infra subs. Is there any DIY effort that could equal or top that? I notice they say they operate below resonance. Does that work well? I've heard various contradicting things about the Linwitz Bass transform.
From their site...
The Bag End INFRASUB-18 is a self powered subwoofer system employing a direct radiating 18" cone loudspeaker in a sealed enclosure and a 400 Watt power amplifier mounted to an aluminum plate on the back of the enclosure. The amplifier also includes a built in INFRA dual integrator providing a flat acoustical response down to 8 Hertz, well below the audible range of human hearing.
The INFRA driver is operated below resonance and flattened with an electrical boosting circuit, the INFRA dual integrator. Below resonance the INFRA system exhibits predictable, uniform response and reproduces each note with the same emphasis, reducing the influence of the resonances found in conventional above resonance bass systems.
By extending the frequency response down a full octave below what is considered to be the lowest musical note, low C on a pipe organ (16 Hz), we improve the phase response and reduce the delay throughout the entire audible bass range.
But they go on to say you can't feel it and its not audible.
So what's the point? I have to conclude that below 20hz is just not useful even for home theatre.
While the INFRASUB-18 will reproduce 8 Hz, it is not audible nor does it have enough acoustical power for you to feel it.
From their site...
Ok, was just following Zaph's information on low Xmax woofers.
http://www.zaphaudio.com/lowxmax.html
I have experience with the 12" Dayton RS sub and have listened to the other Dayton woofers.
You are sacrificing musicality to some degree to get 20-40hz versus a good large woofer.
Can anyone recommend a woofer that has excellent bass output F3=20hz and low distortion up to 100hz?
Would the Scanspeak 10" revelator woofer do that?
Or would I be better of looking at Peerless XXLS, Aura, Dayton, TCSounds?
For music I'd say flat to ~25Hz is fine - I've got plenty of electronic artists in my collection with synth bass down to at least 30Hz (I have an RTA inline all the time so can see where the bass is at)
For dvd's ideally I'd want extension down to ~10Hz. I used to use 3 15" tempests, each in a sealed 200L enclosure flat to 12Hz. Now I use 2 labhorns that are eq'd flat to 20Hz. The extra extension of the tempests made a difference and it's only lack of space right now that has stopped me putting in some 'big stuff' to give me big output down to less than 10Hz.
Even if you can't hear a 10Hz wave in your room you'll still feel it
For your friend, I'd suggest a ported 18" driver tuned to ~12Hz in a big box.
As he's going to run other subs above this one maybe something interesting could be done with a bandpass box, tuned to give output in the 12Hz - 25Hz region. Have a look at Dan Wiggins of Adire's suggestion here
Rob.
Rob.
Rob.
So, what 18" driver would be up to the task? Every big driver (like the TCSounds stuff) has an Fs=23. My own Dayton 12" has an Fs=23. Does this mean I need to find an 18" driver with an Fs that's 15hz. I'm not see any (available to DIY) with specs like that.
Dan Wiggins idea (which sounds cool) requires 14 cu feet of box.
What is the smallest box/driver you could build on average and still hit 20hz flat?
Should I be looking at Pro/PA drivers from Pioneer, JBL, etc?
PA drivers are not for really low frequencies. Many 15"ers have Fs' around 35 Hz and an Xmax of around 6 mm. They are intended for music only and are very efficient. Everything's a trade off. Personally, I don't need anything below 30Hz to keep me happy. Even for movies.
Looking at this
http://www.htguide.com/forum/showthread.php4?t=18218
I see lots of people used Adire Audio drivers. But as far as I know Adire Audio is out of business now.
Here's a 18 with good specs and a excellent price.
http://www.mach5audio.com/product_info.php?products_id=56&osCsid=33146c1b4f08ea35652e5a12aa8034b9
Prices quoted include shipping. It needs a box around 12 cubic feet.
Try some searching on EBS designs. The output drops slowly down to the tuning frequency, then plummets below that. The idea is to tie in with any room gain available and give in room response flat down to the low teens.
If you put a 'flat to 20Hz' sub in a typical room it would sound 'boomy' due to room gain boosting the sub 30 / 40Hz freqs.
Have a search and read on room gain too.
I'm not clued up on specific drivers right now, but can tell you to stay away from pro gear and look more at home gear or even car subs.
the avalanche 18 driver used to be popular but I don't know if it's still available.
Rob.
Rob.
Oh Cal,
Re: your sig.
I always thought 'sub' meant 'below', and a 'sub woofer' was a speaker used 'below the woofer'. If you called a subwoofer an infra woofer then it would imply that it produced frequencies we couldn't hear. Most 'subs' cross at 50 - 120Hz, and thats easily in the audible range.
Rob.
Re: your sig.
Rob.
forr, what you're saying matches Rob.
Apparently, most rooms have gain from 30-60 hz. I should go for a oversized/tuned low/EBS vented such as referenced on
http://www.danmarx.org/audioinnovation/theories.html
forr said:To avoid to build speakers un-necessarily going too low, this is an average room response published in the JAES paper,
"Subwoofer performance for accurate reproduction of music"
by Fielder and Benjamin
That pretty much equals my room, but the gain stopped at 12Hz so I guess room construction plays a part.
Hi Rob,
I used to think 'sub' was short for subsonic but subsonic means below the speed of sound. Not related to frequency.
Infrasonic is the area below 20Hz (apparent threshold of human hearing). Daveis was asking about about 10Hz.
You need a 'sub' to go 'infra'
I'll never figure it all out. Better just change my sig line
- Subwoofers
- 10-25 Hz, is it necessary for HT or Music?
