Cheap simple class D amp circuit to build.
its a simple selfosz. amp, "ucd" style...
here test with 5khz,1w ,8 ohm:
P=U*U/(2*R) , for U=Umax, so 200w /4 ohm = +- 40v supply
dont worry, if currents are not 100% like ideal theory, this is a sim,
in real world , for optimum performance, you have to tune the gate resistors anyway, because depending on the c-gate of your actual mosfets timing will change;
with 100v mosfets, you should not go up to the +- 50v limit, some safety margin is ...good for long life of mosfets...so +- 40v is maximum
for power calc you need to have a secret element in the circuit, i use the lt1076, with is doing nothing useful otherwise,;
start run, then go menu->simulate-> eff.calc. -> mark start
let it run some time, stop or run hole sim.time
then menu->show-> eff.report -> show on shemat.
you see eff calc in circuit
