ADCOM GFA-5500 Motorboat sounds / Remove MOSFET Stuck to Heatsink
Hi All, have an ADCOM GFA-5503 where I am getting some strange "motorboating" sounds randomly video here: Login to view embedded media .
I isolated it to one of the channel amplifier boards and figured to toss some new electrolytics in there, however to get to them I need to remove the board from the heatsink, but the MOSFET's are really stuck and not wanting to budge from the tape.
Anybody have any tips on how to do this? Am I going about this the wrong way?
Push-Pull 6L6 or EL34 Schematic, Mullard 5-20 vs. Ampex 6516
Hello Everyone,
Sorry to post what may be something of an opinion-poll type thread. I have decided to build a Push-Pull amp based on either 6L6GCs or El34s. I was pretty much set on building the slightly reworked Mullard 5-20 presented on the Lundahl transformer site (see below).
But then I found a schematic for the Ampex 6516 (see below). This amp uses 807s in the output stage, but I think it could easily be adapted to 6L6GCs--if needs be. I used to own a pair of these in the late 80s/early 90s and have always regretted letting them go.
I am hoping for ~20-30 watts @ 8ohms. Any advice concerning these schematics? I am thinking that the first 5879 on the Ampex schematic could be left off and start the circuit at the 250ohm pot (or leave the pot off and start just after).
Mono AB amplifiers using two separate heatsinks?
Many monoblock power amplifiers have two heatsinks, one to each side. This appeals to me: it could allow either more total heatsink area or two lower-profile heatsinks (instead of one tall one), or some combination of both.
I can see how this would be valuable for class A, or a sensible choice for bridged stereo AB. But for a straight mono AB amplifier, two opposing heatsinks would presumably mean quite some distance between push and pull output devices or output pairs... and I've read threads where having even short fly-leads between the amp's PCB and output devices was said to compromise the performance (or stability).
So of course I'm wondering: would this be a valid concern, do special measures need to be taken, or am I misunderstanding something?
Thanks, Kev.
DRC users: What is your DRC measurement workflow?
I use linux on my living room PC that's connected to my active speakers. For a long time I used DRC room correction with a set of hacky scripts based around pulseaudio and ffmpeg. I had hardcoded my DRC settings, my mic and output gain and my input and output devices so that I could recalibrate by SSHing into my living room PC and starting my script.
Recently pulseaudio has been replaced by pipewire and I replaced my sound card. My scripts have therefore become non-functional. After running all the steps needed to set up DRC manually from the command line - with mixed results ("aargh the mic gain is too low again!") - I think it is once again time for some automation, I'm just not sure how I should go about it this time. I'm looking for some best practices, ideas and inspiration.
My question to all the DRC users is: How do you capture and process your sweeps and generate your filters?
please help the T.amp TA2400
Hello everybody, today i want to discuss a certain case i encountered in my work that left me wondering where could the problem be.
I bought an amplifier "The T.amp ta 2400 mkx professional" with a broken right output hoping to fix it, i found the 8 output power transistors of the right side broken along with one of the two drivers "A145" slot to be specific, i replaced the broken Amiercan driver "ca1837" with a chinese alternative "2sa1837", and replaced the output power transistors with new ones, just for the same problem to occur.
Both the new driver and the new output power transistors were broken again.
So i replaced the driver again, and removed the output power transistors complitly, and the amplifier worked properly (the green led lights up and rolly works), but the problem still priciest when i put new ones (power transistors)on.
I tried testing and these are the numbers:
Emiter & base -/+70v
Collectors 0 gnd
These numbers are correct according to the datasheet.
So i ran out of theories and so I'm here to ask you. What could the problem be in this case?
  • dap_audio_palladium_p-1200_sch.pdf
  • Schaltplan_T.Amp2400_aehnlich_0.1_Messung.pdf
Adding material to full-range cabinet?
Hello hello,
This is my first post here after spending a few late nights on the forums and imagining my first speaker build. Apologies in advance for any errors of diyAudio etiquette. Let me know if I should be moving this thread to another forum!
I'm an audio/music fan (but far from an expert or audiophile), and I'm planning a speaker build with my brother who is an artist and furniture designer. We'd like to make a (hopefully) simple pair of single-driver/full-range loudspeakers. We'd like them to sound good, with a decent frequency response, but we don't need them to sound exceptional. Better than a little Sonos unit, I'd hope, but no need to compete with £5000 audiophile speakers. HOWEVER, we'd like to get quite creative with the aesthetic design. And I'm struggling to find much info on how specific aesthetically-motivated changes will affect sound, so I thought I'd stick my neck out and ask the diyAudio experts!
I have loads to read and learn, especially if not following a pre-existing build plan. But before we go further, I have two big questions which will affect our approach:
1. What are the important considerations when fixing additional material to the outside of a speaker cabinet? For example, could we build a tried and tested speaker, and then glue/screw another empty box on top of it in order to change the physical proportions for aesthetic reasons? Another example: could we glue/screw little details onto the side, top, or bottom of a cabinet, such as a small carved wooden sculpture?
2. Are there any limitations to veneer materials, assuming an mdf enclosure? In particular, we are interested in using a thin aluminium veneer, as well as burr walnut and white melamine (not all together!). It would be great to know if there are any 'no-go' materials for veneers?
For what it's worth, my current plan is to use the Mark Audio Alpair 10p, which seems to be well-regarded. Depending on answers to the above, I'm imagining we'll use one of the build plans on the Mark Audio website (e.g. https://www.markaudio.com/wp-content/uploads/2022/08/Despina-Alpair-10.3-10P-RTL.png OR http://wodendesign.com/downloads/simpleReflex-103-10p-plan-100214.pdf), at least to give us a basic structure. As a bonus question, I'm wondering to what extent we could change the positioning of the driver and port holes on tried and tested transmission line and vented designs, as long as the volumes and circumferences remained the same? E.g. putting the driver in the middle of the box rather than towards the top.
Thanks in advance for your patience, and for any help you're able to offer!
Lewis
Dayton 408DSP vs Behringer CX-3400 electronic crossover
I love experimenting with loudspeakers. The big bugaboo is always the crossover expense and having the required devices on hand to experiment. I want to try some type of electronic crossover. I have a number of amplifiers available.
Currently I have a MiniDSP. Very complicated to program and the unit I have sometimes causes distortion that is not tolerable.
Dayton 408DSP which looks like a much easier to use device ($220 with USB dongle).....or just go analog with a Behringer CX-3400 crossover (On sale right now for $126 shipped from Sweetwater)
Is anyone using either of these units? Comments?
Monsoon Planar Media 14 Audio System
Hi everyone/anyone, I am new here and glad to have found a possible source for help. My speakers and the sub-woofer/control module all work fine! It says 2002 on the bottom so I guess I've had them since at least then. I loved them while they worked well, but when the small control pod began to malfunction I had to disconnect them. This would have been about two to three years after I got them. What happened was that the bass control on the pod began to cut sound off altogether when I tried adjusting. It also introduced a lot of noise when turned at all. Sound would cut out altogether, would get louder or softer and have a lot of static too. On occasions when I was able to finally get things adjusted to where they seemed to be just right, volume level would soon self adjust up or down or off, accompanied by static. I had to remove the speakers. Of course, by this time they were no longer being made/sold and I could fine no help anywhere. Searched the web on a whim recently and found this site and am hoping someone can help me get them up and running right again. I have no electrical skills, although I can wield a soldering iron as a result of working in stained glass for a few years. I have looked inside the pod and have no idea what to do. I have shot up the switches inside with Micro Care contact cleaner a couple of times but to no avail. I'd be glad to include some pics if they would be helpful. Sorry this is so long, but I didn't want to forget anything. Thanks in advance for any help/suggestions. Dunolde
advice on Unity mod to 1" horn for PA
I'm spitballing a plan for adding midrange taps to a B52/QSC clone waveguide using a Faital HF10AK, with Faital 12PR320 as the woofer, direct radiating.
This will be used for PA service. I'm already happy with the sound of this cabinet but I want to take it to the next level.
I have some Celestion TF0410MR and I'd like to use them. I've read many, many posts about this driver, but I am still undecided about whether I should be using 2 or 4 of them in this design.
No doubt 4X would be great but is it overkill? Fitting them on the horn will be a challenge but 2X looks to be much simpler, and of course less holes in this lovely sounding horn.
Then again, they are only 1mm Xmax and won't be seeing any horn loading at their low end. I'm imagining a 350-400Hz XO, 4th order.
Also I want to make a bare-bones passive XO for the mid/high transition to conserve amp and DSP resources. Would that be a fairly simple task for this particular setup? I sheepishly admit I've never built a passive crossover before...
Thin backplate material for 24" x 24" 3-way speaker
I am building a thin 3-way 24x24" wallspeaker, and the backplate can only be 1/4" (6mm) thick. Only 1/4" MDF acts as a drum and resonates violently (even with some internal stiffening construction) at these large dimensions for low frequencies, so what material/construction should I use ? I even considered cork, rubber or vinyl.
Any ideas ?
2.0 vs 2.1 for pseudo-subwoofer
I'm currently experimenting with bi-amping setups. I use the a/d/s/ 642ix automotive electronic crossover as an active crossover. It has a feature which allows the subwoofer signal to be fed to the main speakers when played in 2.0 stereo mode in lieu of 2.1, that is why I called it “pseudo-subwoofer”. The subwoofer signal is filtered at 100 Hz with a slope of 24 dB/octave. The issue is that the main speakers are playing in stereo, but the subwoofer signal can be selected between stereo and mono. Which one should be used?
In desperate need of help finding capacitors that will fit.
I’m repairing a NAD M3 which requires a full recap. I’ve replaced pretty much all of the caps and came to the main filters, pulled out the filter caps I bought about 6 months ago and…. They don’t fit. I really should have paid more attention to the physical measurements.
The filter caps that are in the amp, which are all quite buldged, are snap-in and 40mm in diameter and 83mm in height. They are 22,000uF 80v. The caps I purchased are 27,000uF 80v and are 40mm in diameter, but 105mm in height. I’m so bummed.
I’m having trouble finding 40mm dia snap in caps that are 22,000uF (or higher). I could use the ones I have until I find some that are 80-90mm in height, but being at 105mm I won’t be able to put the top on the amp.
Anyone that might be able to find a good quality cap that will work, I would be eternally grateful. I’m stuck on this project until I find some and I have no choice, they have to be replaced.
Thank you,
Dan
For Sale Dayton Audio DSP-408 4x8 DSP Digital Signal Processor w/DSP-BT4.0
Purchased new and installed in my Tacoma in early 2021 for PE; removed to sell the truck.
Simple-to-use unit I used to control 6 speakers plus a subwoofer. Tuned using REW.
Includes the DSP-BT4.0 USB device to connect via phone app. Some scratches on the case during installation under the driver's seat.
Decided to go with a different amp/dsp for my new vehicle.
$125 plus shipping.
  • Locked
Investments/Stocks/Funds
Hoping for some tips on general investment etc.
I'll get to the point shortly, but first:
I just recently got enrolled in a education program run by the government that seeks to further educate people with a mainly practical background.
Decided to go for a engineering degree in Electronics as that's basicly the only thing I'm able to apply for, and it's also one of the few things I have interest it.
After I got my acceptance letter not long ago they told me I was eligible for a loan, parts of this loan may turn into a sort of scholarship allowance of sorts upon passing the studies.
This loan has a very low interest rate of currently 1.67%, and is a reliable low interest solution that the government uses to make sure people get a proper education.
I am seriously considering taking that loan, and putting all of it in various stocks and funds. The market is at a low now, but even if it starts going back up a bit before I get the first sum in mid-august I should still be able to "hitch a ride" a bit further up. The plan: If I am able to plan my way in the market "just so" it is possible I could repay a reasonable bit of my mortgage and still have a bit left after fulfilling my education in 3-4 years time.
Even though I am not guaranteed that the loan will turn into "school funds" I am still guaranteed a very low interest rate, so my thinking is that a well-planned portfolio should be well worth it.
Is this a bad idea?
I am concidering spreading it over a few specific tech companies, some stable dividend stocks and something in agriculture.
Thoughts and opinions are welcome.
Marantz SR5300 Amplifier, unusual digital volume display readings?
Hi All.
I'm cleaning up a Marantz SR5300 AV Receiver I acquired and discovered that it displays unusual digital volume readings.
I find AV Receivers can make good value Stereo Amplifiers.
The SR5300 pumps out a claimed 80 rms per channel in Stereo mode.
The problem with this one is that at zero volume it displays -75db.
Pumping up the volume I can get to around -12db at which point it's quite loud.
Is this normal?
Is there a way of displaying a more conventional format.
thanks C
Monsoon speaker parts
A while back I picked up some unused Monsoon Mh-500 2 way satilite speakers and
2 pairs of the Panels from the MH-700 . I was thinking about using those larger panels
from the MH-700 in a MTM with the smaler panel from the MH-500 as the tweeter
but neverf did so if anyone here needs these for parts just let me know and no I don't
have the autio contgrole box that went with these oh the panels from the MH-700 don't
have the plastic feet. If by chance tou can pick them up in zip code 30290 you can have
them free. Or other wize the cost of a USPS flat rate box + $20 packing fee, I know I
should have posted this in market place but thought people here would be more likely
to want these and ask a lot less questions.
Tool For box design.
Anybody here is aware of box design software that will help design box of my own shape? rather I am interested in the one that will give me Xplode view ( hope I said it right) that is give wood cut dimensions for its fabrications. I found google sketch is a good tool and easy too. but it does not maintain ratio when you change dimensions.so unable to get the real look of it.
Hitachi HA-1, can I replace 4558?
Hy,
I will be using mentioned amplifier for a while as a phono preamp, input selector and volume control. Just until I can buy something good.
I am wondering if I can replace 4885 with NE5532 or TL072?
Any other quick mod I can do to it except refreshing some capacitors?
I had attached the schematic, 4558 is at the top left part of it.
Thank you
What 8-channel DAC's are available suitable for active speaker setup as of September 2022
Have been thinking already for quite some time putting together a DIY active speaker, so far probably based on CamillaDSP running on a RaspBerry Pi PC, and for that a multi channel DAC solution is needed, there's the excellent Okto dac8 or Topping DM7 but it's price tag is a bit too much, and I am not in need for the absolute bleeding edge DAC, rather the emphasize is on budget and preferably as much DIY as possible.
For instance, this could be a good 8 ch DAC candidate from DiyinHK, I assume..
https://www.diyinhk.com/shop/audio-...c.html#/dac-xmos_and_dac_pcb/fifo_option-null
but the disclaimer part says:
ES9038pro can playback multichannel DSD and 8 channel 384k PCM, but the current xmos firmware only playback 2 channel DSD and 8 channel 192kHz PCM. User can wait for the newer firmware from XMOS or user can modify the firmware themselves to support multichannel DSD and 8 channels 384k PCM immediately.
I must also admit that I am not very well acquainted with all aspects of digital audio, such as, is DSD connection really needed and when, such as, will I come across a situation where it is needed for an active speaker setup?
Or what features should a DAC come with so we can use it for active speakers?
Another candidate I have been looking at is ESI Gigaport eX 8ch DAC, not so much DIY here but attractive price and a good solution (I believe?) to just get by with.
https://www.esi-audio.com/products/gigaportex/
It is currently sold by Thomann in Germany for ~160€ as far as I can see, seems rare as I can't find it in Finland where I am, but not a problem though.
https://www.thomannmusic.com/esi_gigaport_ex.htm
Measurements:
https://prosound.ixbt.com/interfaces/esi-gigaport-ex.shtml
Besides 8ch DAC's, are there any other possible solution using 4 pieces of 2ch DAC's instead of a single 8ch DAC, and how would one sync them together if any such thing exist at all?
What other 8ch DAC's or other solutions out there would you suggest me looking at?
Thanks everyone! :)
Rodek 2150i no regulated voltage
I received this amp which has been through the repair ringer - looks like previous repair was a frantic non-complete job.
I saw one of the ANW7 modules had been cut and so I replaced both modules with discrete components. The amp powered slightly with only 0.15A draw, though the PS was producing and amp had +-17v Rail.
No regulated voltage.
I then replaced both 470uf 16v caps with new 25v units in the regulated side, and the amp powered produced +-17v rail and +-16v regulated, draws 1.1A and passed audio unloaded. Right channel passed audio under small 4-ohm load. As soon as I put a small 4-ohm load on the LEFT channel the amp went into protect.
From that point, I could no longer get the amp to produce regulated voltage.
I then replaced several other caps as well as rebuilt the two ANW6 modules. I also replaced R4 and R5 with 1kohm units but still no regulated voltage. R4/R5 are connected directly to rails and are servicing the regulated voltage supply to the 470uF caps... Theres only about +-0.3v on the regulated side of these resistors.
I checked everything I could - again this amp has some service wear from tech troubleshooting so - it could be anything.
Any thoughts?
Photo one moment
Unwinding/Rewinding inductors
Hello,
1)I'm building a crossover and have some inductors that have too much inductance. I need (6) 6.6 mH which are kinda pricey for air core. I unwound a couple 9s to 6.6 mH. When I was unwinding them, some of the enamel has come off the wires as pictured. Should I apply some sealant on these coils?
2)Additionally, I have (2) 15 mH coils that I want to use to get the other 4 coils I need. When I unwound the 9 mH, I just let the wire lay on the floor and kept measuring until I came to around 7 mH before I cut it and then continued to 6.6 mH. Since I want to reuse the wire, I want to wind it up on a spool as I unwind it. I should be able to get pretty close by measuring the diameter of the coil as I unwind it, since I won't be able to measure inductance as I'm making a new coil as I unwind it. Can I scrape off some enamel and measure when I get close and not be concerned?
3)It's the last 2 coils I'm worried about. Since I'm fairly certain I won't be able to wind them as tight, I will use more wire and have more resistance. I'm already at 1.5 ohms on the 6.6 mH coils. Additionally, I will have a spool of wire that the enamel is compromised on from unwinding it. This concerns me as well. There is no specification for inductor resistance in the crossover, but I thought I was supposed stay under 1 ohm and preferably .5 ohm.
Thank you
Hitachi HA-330 dc offset - help needed
As the title says, I have a ha-330 with quite a lot of dc on the outputs. It has 215mV and 250mV. I’d like to be able to identify the problem without replacing a lot of random parts until I get it. The amp still plays music "fine" but obviously not at its best right now. Could somebody help/guide me through this ? I verified a couple things but there’s not an obvious problem that I can fin. What would be a good procedure to follow in order to find the problem ?
I checked the voltages at all the transistors following the schematic. Most of them are a little off but nothing seems completely wrong. The voltages coming from the power supply are like 1V higher than what they should. All the electrolytic caps are new and good quality.
Thanks !
Feedback in PA systems
Hi there, I’m looking for any info on reducing microphone feedback in PA speakers.
As I understand it inductance plays a role in amplifiers (as vague as that is- I don’t know in which part of the amplifier inductance is an issue). I’m hoping my ICEpower 125ASX2 has been designed with this in mind.
The thing I may be able to change, however, is the drivers I’m using.
Are there TS parameters which relate to feedback? The ability of the suspension to arrest the driver? Voice coil inductance?
Tweeters seem to have the worst problem with feedback, I’m guessing this has to do with the frequency range they cover (which is increasingly directional as the frequency rises). But are there other factors? I’m guessing 1.4” exit 3” diaphragm drivers are a bit more feedback resistant due to their higher diaphragm mass and greater mid range capability, but not sure.
Any ideas welcome as I have tried various Google search terms and found nothing relating directly to this question.
New QUAD design Qs
Prototyping Eico ST70 quad upgrade posted below-
Can the 3 triodes be combined into one 6U10? The 2 low mu triodes replace the 6SN7, the 1 hi mu replace the 1/2 12AX7?
I've compared voltage rec's and max's.. also curves... they seem similar... but wanted to ask opinions here. Koda has posted using the 6U10.. what are your opinions on these design subs? Will there be a trade off in sound quality ??
Thanks,
Jim
  • 6U10.pdf
    6U10.pdf
RIFA PEH169 date codes
After reading plenty of good news here about the PEH169s i’m considering to give them a try. Most of the older ones that have “Evox Rifa” witten on their labels clearly indicate the date of production stating first year and then week of production.
I also see them with different labels that look like the one in the attachment:
They have a date code that consists of numbers and letters. (The ones in the attachment say BX9.) Data sheets that I came across do not provide the key to this code. (That is, they only explain the date code described above, i.e. 0015 meaning the year 2000, week 15.) Does anyone here know how to read it?
Prototype baffle and FRD Measurements
I am ready to make measurements of my drivers for a new system (3way). I dont have the actual cabinet yet, only a design. How accurate o representation does the temp baffle have to be? My design is for a 40x14 inch front.
Also since it is a 3 way do I take measurements of (tweet and mid) or( woofer and Mid) etc I dont connect all 3 together do I (as in a 2 way system??)
  • Locked
Screwed over by Infineon Technologies / Cypress
This may not be the best location to complain Infineon Technologies / Cypress have screwed over a friends company.
They used chip CY27410FLTXI on a test PCB But datasheet is wrong, so you can’t program it, which they admit. But required a NDA for the real datasheet. NDA was signed months ago. But still they are refusing to give out the data. So now there are dead expensive test PCB’s and customer commitments failing. They still hoping to get data from them so I will not say who friends company is.
I am so pissed off, I hope someone will pass this on as a warning not to use them.
Dirac3 and SVS Micro3000 Sub
What's the best way to integrate my MiniDsp Flex8 DL with my SVS Micro3000 sub? MiniDsp advocates bypassing the sub's internal controls and setting everything up in the Flex but this is with all subs, not necessarily the Micro which has extensive DSP controls in its own right. The question, in my mind, is how to best set it up so Dirac3 is including it in measurement or should I let Dirac only run on the main speakers and setup the sub outside of Dirac using SVS's DSP controls?
Thanks for the help and opinions!
Apogee Rosetta 800 +
I've built my 4 way horn loudspeakers and been playing with REW & a Behringer DCX2496 to establish crossover points, slopes, time delays, etc.
The opportunity to buy an Apogee Rosetta 800 192kHz has come up and I'd be grateful for comments on my proposed system configuration.
Majority of music listening is from NAS drives, but I'd also like to be able to listen to vinyl, blurays & TV.
I think miniDSP is the weak link, but all suggestions welcome.
Barry
New enclosure and crossover for Stephens Trusonic speakers 120FR woofers and 5Kt tweeters
I am thinking of building new enclosures for a pair of Trusonic 120FR and 5Kt speakers. Originaly they were in the diy Jensen bass reflex corner cabinets with sherwood SX36 crossovers. In a relocation I left the cabinets behind and kept the speakers. built in 1960 maybe there is a better enclosure option than bass reflex, after 30 years of listening I felt the bass was overpowering, although I enjoyed them when I was young. The Crossovers need to be replaced, passive or powered? I like the idea of the Pass diy store powered crossover, although I also like the simplicity of a passive unit Space is an issue, so I'm looking for something with a small footprint, height is not a problem. Any response will be appreciated.
Undecided D3A - NE5534- LM394 phono preamp - my road to 24K gold porn audio
Preparing for my fourth " russian " winter in a row, I'm trying to make my third iterration of a d3a phono preamp, but as usual , I can't afford mc step up transformers or I just don't want to have such things...not sure about it.
Here's the thing: I have lots of D3A tubes , lots of NE5534 of all manufacturers and again lots of 2sk117.
I want to make a phono preamp that I can easily sell if the russians invade my country and pay for my flight ticket to New Zealand.
Thus it probably must be the best phono preamp ever made on planet Earth...That's easy to achieve from a purely technical perspective.I only have to throw in all the best components and try to get utterly useless SNR figures like -110db for MC inputs ignoring all physics laws...I could probably claim it anyway with no real effort...
But I'm sure it needs to look cool too. Thus, I'm sacrificing my second Transbridge TBM4 amplifier.I could use their INA110 op amps for a purely balanced input and the other goldish INA102 for dc offset-ing something that's usually utterly unnecessary to be offset...Anyway if I use 4 x d3a tubes on the input in balanced mode I will keep the INA117 only for their 24 k gold appearance. I can throw even more gold in it and create a front end tapestry composed from about 20 golden 12 Bit DAC... By the way I have the E810F since2012 and never paid them so I might need to buy two flight tickets to New Zealand to pay my debts...
What would a guy with $$$ perspective say I should choose or do?
Pete Millett 50W Monoblock Amp
Good day, I am new here and this is first post. I am a newbie and have been extremely enamored with tube amps. I am in the process of building the Pete Millett 50W mono engineers tube amp. I am looking at the printing on the PCB with the pin breakout. The PCB (original version) with the solder in tube sockets in all of the images, has the tube sockets soldered in on the back side of the board. What I am finding confusing is that when you place the socket on the opposite side of the board the pin configuration gets reversed. I am imagining that this has been thought through and operation will be correct. Can anyone clarify this for me please. My apologies for asking such a simple question. As I frequently read the boards there are truly many brilliant minds here and I feel I may be asking a simple question. Thank you again for any info and I hope to continue learning as I go here. Here is link to page. http://www.pmillett.com/DCPP_MB.html
V-FET amplifier repair (Southern, California)
I would like to avoid shipping this for repair unless it's absolutely necessary. Is there a recommended repair shops page here? Looking for repair shop recommendations within a 200-300 mile radius of Los Angeles, CA?
I picked up a Yamaha B-2 VFet amplifier last year and it sounds wonderful, but sometimes I get distortion on 1 channel and sometimes the sound takes turns between the left and right channels for a second or two. This latter problem is normally at softer volumes, while the distortion is more at higher volumes, with for example, chords on a cello, that may have a hint of dissonance.
My Yamaha B-2 was slightly damaged (casing) when I received it due to the shipper's poor packaging, but everything worked fine at the time, but as I use it more, I am starting to notice that it does need some love soon.
I've called a few repair shops and some are very honest about whether they have worked with this particular amp, while others seem to use some sort of fear tactic. They keep me on the phone and make feel like if I don't bring it in right away to THEM, it's going to blow up.
I know this is a DIY site. I have built 2 of the ACAs, but I wouldn't be able to do that without the amazing step by step instructions on the site. I have the Yamaha manual, but I just don't trust myself with this. If I break something, I just broke my wallet.
Thanks! Any help is appreciated.
DAC switching Amplifier
Hi All,
I have started this thread to post circuits and block diagrams for this project.
This what I am thinking the amplifier layout will look like, the size of case will be base the size circuit boards.
The Power LDMOS Transistors I thinking of using are the MRF101AN and the MRF101BN made by NXP, therefore the cost to start with will be high as device are somewhat expensive. But it is possible to run them at 10 MHz switching speed, making it possible to pass through DSD 64 and DSD 128 without conversion.
Tested basic PDM ADC, using a 74HC74 D type flip flop, I will need to improve its performance by adding in a negative feedback loop.
As you can see there is nothing to it, as for the 1.8432 MHz oscillator goes, it was what I had available to use at the time to provide the clock signal.
Wave forms:
  1. is the PDM Q output from the Flip Flop
  2. is the Clock input
  3. is the sine wave from the output of the low pass filter
  4. Is the 4 kHz input sine wave from the signal generator
From the block diagram this would make up part of the ADC 2 input stage to the FPGA, with a few improvement.
This is a project that will take some time to develop as there a lot more to workout before I even start to think about a PCB
Replacement for VIFA drivers
Hello everyone,
I got a pair of elipson Melodine 4 from a friend. One of them is fine, but the three drivers of the other one are out.
I have a really hard time finding information on the midrange (Vifa K10MD-09), I only find the K10MD-19 datasheet, but I don't know if they are equivalent.
I found a small datasheet for the woofer (C20WG-09).
Both parts are unfindable for sale, so I'm looking for replacement ones. Do you have any idea on which could do the trick ? As my other speaker is fine, I really would like that they continue to sound the same...
Thank you in advance for you help!
Alex
  • Locked
Why does this nice custom phono preamp hum?
I'm looking at this newly custom built tube phono preamp. It has a separate power supply. It has a bit of hum.
Here's some pictures.
The first thing I'm suspicious of is how there are two ground points. Most tube amps I've seen have a single ground connection to the chassis and it is at the input terminal ground.
Does this seem like a good starting point? Does anyone notice anything else?
EDIT: no further replies required.
How to measure phase margin of an amplifier?
Hi!
How do you guys measure the phase margin of an amplifier?
I don't want to make an amplifier that risk becoming unstable, and I don't want to overcompensate the amp with a too low dominant pole. Without access to a network analyzer, how do you do this?
I found an article here that describes a method for measuring the phase margin of a power supply feedback loop, and I suppose this would for for an amplifier also. They are using a transformer to inject a signal, what type of transformer do you think would be suitable?
I suppose a good indication of stability can be made by looking at the response to a small signal squarewave. If it rings it's phase margin is probably too low, right? But is this method accurate enough?
Anyone here who can point me in the right direction?
OJG
nice Autoformers
I tried those Autoformers in my tweeter highpass and I am more than pleased with the result. They are on sale now so might be a good opportunity - I have ordered 2 more pairs already.
They eat up 2-3db more top end than expected in the 10-20k range, which must be taken into account when adapting the filter. I could not measure any distortion at 2 amps and the sound is indeed very mellow - the perfect match for my titanium tweeters.
Building a karaoke set; Condenser mic with preamp not loud enough
Hi community,
I'm building a karaoke setup with the components as seen in the image attached.
The problem is that even with the mic preamp the volume of the Mic is about half of the volume of the other channels. I'm looking for a way to get the inputs for the mixer at roughly the same volume.
The datasheet of the preamp can be found here. It says that the preamp has a fixed gain of 18dB which could be increased to 40dB if I understand well. I've removed the pre-soldered resistors and tried a few different values but this didn't increase the gain.
So now my question is:
•Should I be able to increase gain by setting different noise gate and compression values by changing the resistors?
•Is there a(nother) way to increase the gain?
•Assuming the phantom power supply has balanced xlr output, of which I now only use hot and neutral to get mono, could I increase input level to the preamp by different wiring or additional components?
•Any other solutions, like different mic-preamp or a simple way to reduce the input signals of the other channels...etc?
Sorry for the noob questions, I'm learning by building and help is much appreciated.
Thanks in advance and rspct to all audio engineers all over the world!
-Malik
The Sincron turntable
I had one of these, made here and very, very sold.
It was highly recommended by DJs in the 70's for its strength,fortress . Pulley traction. There was a little problem that can be seen in the design of the tonearm. Let's see if they discover it, there are no prizes for first place (whoever gets it right first), just the satisfaction of being recognized as an "expert" in TT. 😊
I can't really say that about the author of the Wikipedia article......I would have chosen another photo of a TT to attach to the article ! 👎
https://es.wikipedia.org/wiki/Tocadiscos
There is no English version, but GT will translate it, although it is not necessary, just look at the pictures 😉
Modelling two-way bookshelf with woofer on top
I'm looking at modelling some two-way speakers that will be placed on a 24" wide shelf next to a TV.
Normally a two way driver is modelled with the microphone in line with the tweeter and then the woofers' acoustic Z offset is determined.
At one stage Mission used to have speakers that had the tweeters at the bottom which to me seems to be logical: A mid/woofer will start to beam at higher frequencies while a tweeter has wider dispersion. As such it seems logic to me to want to listen at the woofers' height.
It also seem to me, but might be mistaken, that if the speaker is to be modelled with the woofer on top and the microphone in line with the woofer that then less Z offset required and hence results in a different crossover.
Am I correct in this assesment and are there disadvantages to having the woofer on top that I overlook?
Thank you for your input.
Eminence beta 15" in a sealed box
Hi everyone,
the 15" eminence beta drivers were happy in a OB and now I'd like to try them in a sealed enclosure. The problem I am having is for a flat response the Vas I get is ~600 L and the recommended volume in the spreadsheet is 45-62 L. If I go with a higher damping factor I can have a smaller box, but how will this influence the sound? What volume would be a good tradeoff?
to follow my steps:
decided on a Qtc = 0.707 for a flat response
Qts = 0.58
Vas = 334 L
Volume of the box (Vb):
Vb = Vas / (( Qtc/Qts )^2 - 1)
Vb = 334 L/ (( 0.707 / 0.58 )^2 -1)
Vb = 687 L
If I turn it around, for a Vb of 62 L what damping factor is needed?
Qtc = Qts sqrt(Vas/Vb)+1)
Qtc = 1.47
A higher Qtc, will mean a smaller volume and a happier wife, but the frequency response will not be flat. Is that all there is to it here? I've been reading on the web about boxy sound etc. but can't find any good resource where these things are explained. found this link below quite useful, but it also doesn't go into explaining why the sound is worse. the example for a ported box:
" A ported enclosure will produce louder deeper bass at the expense of sound quality." Speaker Box Enclosure Designer / Calculator Help
any advice and help is welcome 🙂 I can also just try it and go with the max size acceptable for the space we have ~120L and hope for the best 😀 If the speakers are not suitable for a sealed box, would be also interesting to hear before I start building sth that should not be built 🙂
Thanks,
Martin
Sansui AU-999 - Please help to improve Quasi-Complementary Amplifier (LTspice)
Hello,
As my first complete LTspice -> KiCad -> PCB manufacture project I wanted to remake my damaged driver boards for a Sansui AU-999 integrated amp from the early 70's.
I wanted to see whether there are any circuit improvements I could implement into the new PCB and I wanted to ask you guys for a bit of help in trying to achieve this.
I'm attaching the original circuit schematic for the amplifier, the F-1159 outlined circuit is the driver board I was aiming to rework.
So far, the possible improvements I have identified are:
1. Adding a Baxandall diode to the quasi-complementary output stage - could someone advise on the best location? You can see I already attempted to implement this in my schematic, I tried different configurations and this one is giving me the lowest THD figure. It was done purely by experimentation and looking at other qusi-comp circuits.
2. Changing the value of output pull-off resistors from 220R to something smaller as suggested by @steveu in another thread - The suggested 47R seems to give a good improvement in THD and helps improve the x-over distortion
3. Adding a small value resistor in series with the 15pf feedback cap - steveu also suggested adding a small resistor (100R as starting value) to the feedback cap to prevent RF from getting into the LTP input transistor
4. Adding current limiting - suggested by the same user, what and how simple it would be to implement.
5. Improving the input differential pair - this is something I wanted to investigate, would adding a current mirror/source be a simple matter with the existing configuration?
6. Adding op-amp-based DC servo - this might be too much for this project as I would need to add step-down regulators to create a dedicated bi-polar PSU rail for the op-amp to operate, I'm not sure if that would be worth the effort?
I would be grateful for any additional suggestions or help with the above,
My knowledge is still very basic but so far I've learned quite a bit from this project and I really would like to see it completed.
I'm attaching the original amplifier schematic along with my LTspice files, inc. custom libraries.
Thanks for looking into this!!
  • Sansui AU-999.zip
    Sansui AU-999.zip
Thinking of building some sealed 15" subs, value thoughts on drivers
I currently has 1x18" and 3x12" subwoofers. and assembling a second sealed 18" sub. I am pretty happy with my bass and set up, hopefully happier still with 2x18"m and 3x12". In have two BMS 18N862 subs and 3 12" Sonus faber Cremona Subs
My thinking is I can sell on my Sonus Faber subs for probably over £1k each easily, they were £3k+ new and a very good hifi sub. However building a sealed 15" with a construction similar to the 18" I have built will be more rigid no doubt, plus I can increase the cone area by 60% and focus on speed and slam by using a lightweight 30 something Fs driver and targeting 35-80 Hz with a very efficient lighweight driver. The SF subs are designed to go low in a smaller enclosure and I dont need them to hit the lows as thats for my 18's primarily. I would value views on driver options so far I am thinking of something like the Faital Pro 15PR400, the SB Audience 150B350 or even the Eminence 1525 Legend. Internal volume will be something like 90L and made with 25mm Birch Ply, heavily braced. I have the amps, so its probably under £3k all in to build 3 depending on driver cost and the number of 25mm sheets required. So its more of a swap financially !!!
The cabinet will be 90L or so and a smaller version of this, my 18" unit in assembly.
Motorola/Galvin 47b11 Capacitors
I have recently purchased a 40s battery powered 4 tube radio, Well, The chassis without the box. I would very much like to recap it, But I dont know enough about electrical engineering to make out the rating on the paper capacitors and translate them to modern values. I know not to touch the micas. It seems to be an all dc radio with no means of accepting an ac input.
The tubes are:
1A7GT Oscillator
1N5GT IF Amplifier
1H5GT audio demodulator/ first audio stage
and finally a 3Q5GT as the power amp.
The radio wants two voltages in, a 90v 12ma max tap for B+, and 1.5v .25a amp to the filament voltage or A+. With a stated max output of 250mw to a 3.2 ohm voice coil in a permanent magnet speaker.
The datasheet I found states it has 12 capacitors, most of which are paper.
C-1 Paper .1mf 200v
C-2 Paper .05mf 400v
C-3 Variable tuning cap (do these go bad?)
C-4 Paper .01mf 400v
C-5 Paper .01mf 400v
C-6 Mica 100mmf 500v (This one is most likely fine because mica)
C-7 Paper .002mf 400v
C-8 Paper .005mf 600v
C-9 Mica 100mmf 500v (another mica to not touch)
C-10 Electrolytic 10mfd 150v
C-11 Paper .005mf 600v
C-12 Paper .5mf
As far I I am able to wrap my head around the mfd is analogous to the ever present µF that seemingly everything these days uses in abundance, the mmf ratings listed are somewhat irrelevant because mica caps dont really go bad, well, Sometimes they do as is with everything eventually, But it is somewhat rare.
So my main question here is how do I read the values of the paper capacitors, and what do I replace them with? This isnt the only tube project I have, but it is the first I feel comfortable actually tackling, seeing as how the voltages are "Relatively" low.
RH84 power supply
Hello all:
I am making an RH84 version2. I have a question about my power supply.
I am attempting to salvage a used transformer for the B+. This transformer has multiple windings. The B+ winding is 630vac with no centre tap. My target voltage is +- 315vdc. I have read from the hammond site I should expect ~ 45% of AC with lots of ripple from a halfwave rectifer. So I thought this would work and have room for smoothing.
I am trying to use a beautiful 5U4gb I have in a nice ST bottle as the rectifier. For some reason I get 500+ volts DC.
I have one leg of the transformer going to both pins 4 and 6 of the rectifer. The other leg is (-). The heater transformer is connected to pins 2/8 and floating with CT not connected. B+ is drawn from pin2 into 35uF>13ohm>330uF with a 220kohm bleeder. B+ went up to +- 530vdc before I shut it down, I did not wait for it to stabilize as I am using 400v caps. Next I put a pair of 5408 diodes between the transformer and the rectifier thinking it would help, same result?
I am perplexed with what to do? or what I did wrong? Is the problem with using the 5u4 as it is directly heated? Any thought would be helpful.
Note:
I am pretty new at this so try to be gentle with your comments
I have already completed the chassis work. (I got a bit ahead of myself with that one. It looks really nice by the way.)
I am hopeful this can be sorted out with a little help.
Thanks in advance
Low Noise OPAMP NJM2122 is a new shining star
I was doing some noise measurements with OPAmp available on a market, and discovered that NJM2122 beats up any other OPA that I tryed to evaluate.
I mostly interested in low frequency end, even in 0.1-10Hz for methrological purposes (oscilloscope pictures), but it doesn't make difference - spectrum is the same up to 20 kHz and above.
Have a look:NJM2122.JPGNJM2068.JPGOPA1611.JPGNE5534_b.JPGNJM2122_2068_Y.pngSE5532_1.pngLM833.png
Reactions: kipman725
A question for Sound Technology ST1000A owners?
Hey all-
I've got a ST1000A but it's been forever since I used it. I need to fabricate a new 'detector probe' - does anyone know the ST recommended design? I have not found it.
I made this one yesterday from a drawing I found in an unrelated document - no joy. Thanks for any input you have!
FS Mezmerize B1 buffer
I'm going in a different direction so am selling this B1, it's 99% built with matched jfets purchased from the diyaudio store, all it needs are the fets ( included ) installing a volume pot, transformer and it wiring up. I will include the recommended Lorkin selector switch and optional heatsinks.
£120 plus postage at cost anywhere in the world
loudspeaker distortions measurement in matlab
Dear DIYers,
I have developed a system identification /adaptive filtering approach FSAF, which (R2.0) is capable of speaker measurements using any excitation, such as music.
The main advantage over MLS/chirp is that FSAF linearises the loudspeakers at the true working area on real signal, and produces a non-LTI (Linear Time-Invariant) residual which you can examine both visually and aurally (.wav) in "fine print".
Here is ADAM F5 on 1 min from Mozart Piano Concerto, at 80dBSPL@1m:
https://www.mathworks.com/matlabcentral/fileexchange/83363-fast-subband-adaptive-filtering-fsaf
You'll need to read fsaf.4.pdf chapter 3 for spkid.m methods descriptions.
The same chapter also contains comparisons with old MLS / chirp methods.
You don't need to understand the underlying math to run the spkid.m class functions.
The license for FSAF is GPL.
The home version of Matlab costs $75, plus sigpro toolbox.
You may be able to run the spkid.m in Octave with some modifications (I have not tried it).
Hope it helps,
MZ
PVA glue and Evo-Stik Wood Adhesive - what is the difference?
What is the difference between generic PVA glue and Evo-Stik Resin W Extra Fast Interior Wood Adhesive?
I get the impression that PVA glue is more "watery" than Evo-Stik and it is certainly cheaper but is it better / worse, more or less suitable for speaker cabinet building? Since it is more watery I guess that PVA glue may spread better? Evo-Stik is water soluble before setting, can it be "diluted" before use?
Also, many speaker cabinet DIY instructions strongly advise you to use PVA glue, some advise you to "glue and screw" - should one just glue or glue and screw? Would screwing distort / buckle panels or battens?
EDITED - Just answered my first question (LINK):
Q: Is your wood adhesive based on PVA?
A: Yes, both Wood Adhesive Extra Fast (Resin W) and Evo-Stik Wood Adhesive Weatherproof are based on modified PVA emulsions
I am still curious as to whether one can "water down" Evo-Stik and whether one should "glue and clamp" or "glue and screw"?
  • Locked
Power cables. How much copper is too much copper?
So I've been having fun building some braided power cables recently after listening to Paul 'PS' McGowan extolling the virtues of a good braided cable. He's right, the braid mitigates/reduces RF.
For one of the cables I'm using Lapp ÖLFLEX CLASSIC 110 CY 3G (1,5mm² DIA) in a 3 cable-run braid geometry and combining the individual conductors in each run into a single one to give an overall conductor diameter of 4,5mm².
Why waste any copper by only using a single conductor from each run, right? Or wrong? Is this going to facilitate too much current draw and cause any issues? I'm assuming not and that conversly, having too thin conductors would cause issues, especially if used for hungry amps etc.
i.e. I suppose I'm looking for a confirmation that there are no disbenefits to combining all the conductors into a single thick conductor for each pin of a power cord.
I'm also using a slightly thinner gauge cable for a different model giving an overall 2.25mm² diameter for each conductor.
Thoughts?
Some pics.
This is the cable with 4,5mm² dia conductors.
This is the cable using slightly smaller 2.25mm² dia conductors.
For Sale Pulsar clock 49.152 MHz / dual LT3045 reg.
Pictures are showing what's for sale.
Price: 250usd / euro
Best regards. Bengt Dahlberg
PM if interessted 😎
Edit: I finally found all documentation that came with it as well. 🙂
Edit again: Dropped the price at another site to 250usd, same here as well of cource.
What are the acoustic principles behind a Karlson/Karlsonator speaker?
I am building a Karlsonator 8 with fostex fe206en at the moment. I read many articles and threads discussing the benefits and drawbacks of this design and discussing the suitability of certain drivers. But I am still not sure I understand how it works.
Am I correct in my understanding that it is a double bass reflex with a front chamber with an aperture that functions as an acoustical lens that improves off axis listening.
Am I right or wrong....or partially right but are there more acoustical principles at work?
NAP140/NCC200 Clone with PSU
NAP140/NCC200 clone with onboard PSU.
Clone of NCC200, but without output inductor.
Schematic doesnt contain the correct values yet and not all the caps/transistors are the right ones. But I wanted to get most of the layout done first to get a feel of the size of it.
Size is about 22 x 12 CM.
Mark audio Pluvia 7PHD After 150 hrs
I Just want to express my gratitude for how great this driver plays into my TL that was designed for eikona. Time ago eikona was replaced by tang band and now with Pluvia. Not designed for the pluvia but i am speachless how good It Is developing in terms of nuances and delicacy.i use them for vocals+Guitar music and i dont Remember a driver giving me such a pleasure .next week a wood builder Will delivery a pencil speaker to accomodate maop 11.2.
Not sure It can sound Better thanx this pluvia but Hope Is high.only then i Will know if the actual pleasure come from the special voicing of the pluvia (jazzy?) or what..Will report back of course...enjoy and as a disclaimer i am not connected at all with MA team
Reactions: LeifB60
Yamaha A-S501 vs Marantz PM6007 vs ...
Hy,
I'm looking to buy new amplifier for living room (around 20m2).
Currently I have a pair of old Pioneer CS-770 speakers, those will also be replaced a bit later, so they dont play a big role. But I will likely get something in similar size and power rating.
I listen mostly 80s & 90s rock, hard rock, pop. I used to listen to alot of electronic music, but as I'm getting older I'm moving away from it. But I still do like to shake the house from time to time.
This will be my first newer quality amplifier and I'm not sure what to expect. I want rich sound and bass cannot be sacrificed.
I'm looking at Yamaha A-S501 and Marantz PM6007. I'm also open to any other suggestions in this price range, but I must see if I can get it localy.
I like the looks of Yamaha better, but that is it for now...
I know nothing will be "the best of the best" in this price range, but I would like to hear opinions.
Thank you
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
508,504
Members
7,922,436
Messages
Filter
Forum Statistics
Threads
407,891
Messages
7,922,436
Members
508,504
Latest member
Samadhana
