I have Roland Cube 60 bass (orange, older version) on my bench.
Power amp is good, no noise, healthy.
Power supply caps are replaced with new, all voltages are correct.
Problems are located in preamp, scratchy pots and hum of around 150Hz.
Hum dissapear if I switch preamp off and use power amp only.
Hum is not Volume pot related, it is there after amp is ON.
Preamp is built around three transistors (Q1,2,3).
-voltages in preamp on Q1 (2SK117) are OK
-all 4 pots in tonestack are replaced- new -no change, no DC anywhere.
(Vol pot is especially scratchy then treble and Mid + Bass less)
-all tonestack capacitors and resistors arround Q2,Q3 are new
(Q2 is 2SK117, Q3 is 2SC2240)
-voltages on Q2+Q3 are not OK, according to schematics
(Q2: G= close to 0, D= 28,2V, S= 0,33V; Q3: B= 28,2V, E=29,6V, C=37V)
-it seems there is also problem with L1 (measured 10H and 270ohm DCR)
-Q2+3 were tested outside PCB (no shorts or leakeage)
-grounding is tested and checked a few times, all OK
There isn’t any data about L1, it is marked on the body: 5R.
It looks L1 is part of series filter with R16 (1,8k) and C8 (1uF).
L1 is tied to ground with one end.
If I ground the other leg of L1, hum dissapear, sound is a bit changed.
If I ground it at the input, hum is completely gone.
Any ideas regarding scratchy pots, L1 and voltages on Q2+3?
I don’t have spare transistor Q2+3 to try, must be ordered.
What would be value of inductor at this location for bass amp?
Thanks in advance!
