Streamer / Pre-amp Analogue Unbalanced Output Inductor to Ground?? Fault Hum / Buzz
Hi 🙂
Wondering if anyone may have an idea what burnt out and what I may need to solder in place, yes I am a beginner and don't understand much but always ready to have a go to learn :-o
I posted on a different forum, for advice for the fault as the item is quite old and has quite a narrow / specific use, compared to modern things these days.... but I seem to have found the fault with help! and I now assume it is back in the general analogue output area of tech knowledge...??
Any thoughts much appreciated! 🙂
Link to the forum where I posted for help:
https://forums.slimdevices.com/foru...porter-fault-any-suggestions-much-appreciated
2A3 PSE amp with interstage transformers - Venue
Over the last few months, I've been working on a project inspired by Eddie Current amps. Since those are becoming more and more difficult to find (and I like DIY), I decided to make my own. Uses Monolith Magnetics nanocrystalline interstage transformers, Electraprint silver output transformers with custom tertiary winding, Wein bridge oscillator circuit for a high-frequency filament supply (~44khz VAC for the 2a3 tubes). Case was custom designed by me in Fusion and then Protocase brought it to life. PSU box has the B+ supply using EY500a rectifiers, Toroidy power transformers, Neurochrome soft start. Overall a really fun project and it sounds incredible.
Need help with a sub choice
What I have is a Polk XT-12 with -new box and woofer. It is 60L Vb minus my port and toroid (@ 55L). Port is 10cm X 30cm long. I found a good web calculator ....
http://www.mh-audio.nl/Calculators/BRH.html .
I don't know the T/S parameters of the Polk XT-12. It works , but I heated up the VC - I was a dummy and Xmax'ed it with my DIY plate amp. (photo 1) .
Amp worked TOO good @ 14hz , I smelled the VC after 20 minutes. I just wanted to see the worst case load for the new amp.
Using that MH-audio calculator with many Parts-Express drivers and suggestions , it seems to be valid (very close) as far as box tuning.
The NEW driver I want looks cool (a piston) and fits the box - A Dayton LS12-44. https://www.parts-express.com/Dayto...ofile-Subwoofer-Dual-4-Ohm-295-253?quantity=1
In (photo 2) I plugged in all my T/S parameters and get roughly a 32hz F3 (with the smaller Vb). I actually get gain between 40-60hz. Is that normal ?
I would not mind some free output at 45hz , I listen to classic rock mostly.
The Dayton can also be wired as a 2R in parallel , I have a 30-0-30 trafo , I'm sure my REAL amp could drive that with this lower voltage. Would running
at the lower Imp. change my T/S params ?? Running in series (8R) , I'm not too displeased . The original XT Polk driver does not seem to have much output below 30hz
with actual in-room testing, Polk says the OEM sub is usable to 26hz .... I'm not sure I even trust Polk , they make junk these days .... the original amp was a joke (failed).
Thanks...
PS- I know my port is barely sufficient for that 10mm Xmax , but the amp might not push the dayton much more than 5-7mm.
The Dayton = 250W .... my amp is a 4 output device 125W unit,
Reactions: Whelkie D
Driver serial connection
I found old German amplifiers; Braun Atelier series; A1, A2, R1, etc. have speaker set A and B wired in series when they operate in A+B mode, instead of parallel connecting like most amplifiers.
I wonder if I connect the multi-way speakers — no matter 2-way or 3-way — in “Bi-Wiring” configuration in serial connection to traditional amplifiers, are there any disadvantages compared to parallel connection?
Attached is the illustration of a view from amplifier to a 3-way system connecting in bi-wiring setup in serial connection.
Restoration of Golden Age audio amplifiers
rayma has suggested that we start this thread with some guidelines to choosing a good (or bad!) candidate. Usually the choice is made when something falls into your lap, but if given a choice, what brands and even models are most promising? I'll start by saying that the only thing I'd recommend for a beginner to avoid is an amplifier with 7591/7868/other last generation output valves. These were made in a time when manufacturing was at its peak and the horsepower races were too. Output valves were run hard and put up wet, and current manufacturing is unable to make really solid replacements. Other folk may differ, of course.
Hopefully, if this thread progresses well, we can include topics of safety, troubleshooting both general and specific to these old parties, test equipment including DIY and modern DAC/ADC plus software methods, and best practice dealing with aged capacitors, etc.
So, safety first last and always. There's a very lengthy sticky thread on safety that covers a lot of ground, but I'll add mine here. Keep one hand in your pocket. Better yet, attach test leads with power off, then keep both hands in your pockets. Current hand-to-hand goes through your heart, and you're a dead peckerwood. Make something to bleed down voltage AND have a dedicated DC voltmeter connected across B+ at all times. Cost about $15 - $20 and a cheap layer of protection. Keep kids, pets and impulsive friends on the other side of the door. For soldering, wear eye-pro. Make a strong habit of looking AGAIN at the unplugged end of the power cord every time you approach the patient.
Maybe enough to begin, Next!
All good fortune,
Chris
21st Century Maida regulator doesn't regulate heavy load.
Hey everyone,
I just returned from my workbench so this is a spontaneous post, I didn't prepare it very well. I'll do my homework better if this one lacks info.
Here's the thing: I'm breadboarding a tube amp. 6550 push pull pentode monoblocks.
I used a 21st century Maida 300V regulator for the output tubes G2 (20 mA +/-) and the preamp (30mA).
All worked fine, got a nice voltage range on the trimpot. The input voltage is 370V.
Then I decided to go fully regulated i.e. also the output tubes plates.. Settled for 350V. The regulator had to cough up 280 mA. And it said 'no'.
Reg output drops to 325V, turning the trimpot has NO effect.
I went back to the earlier situation and it worked fine again.
Somehow the reg can't handle a few hundred mA, and I have no idea why. Could someone please shed a light on this?
Thanks!
16V - 5V LPS Conversion
I have a high quality Swageman 16V LPS that I would like to convert (if possible) to a 5V output for use with either the LHY or PD Creative LPS upgrade for the Bluesound Node 2i. Is there a way of doing this easily? 2 options that I have researched - (1) a bucking conversion - I've seen multiple schematics from simple (a few resistors) to complex (diodes, additional filter caps etc.) or (2) what would seem easier - just purchase a new 5V transformer and replace in kind - but would this not work because of all the other ancillary components are spec'd to the current 19VA toroid.
I'm comfortable with an iron and multimeter, but not much beyond that, so any instructions keeping this in mind would be much appreciated. Thanks
Kamu M1 powered speaker
I was making a tws bluetooth speakers for my travels with Tectonic TEBM36S12-4/A rectangular bmr driver and JBL charge 5 oval driver.
I noticed that the bmr sounds really good crossed over at 300hz and i mean they sound incredibly good so why not make a bigger speaker using the same bmr?
I had some reckhorn d 165i 6,5" sub drivers still in their package and I was pleasantly surprised that the sensitivities match.
While I could build fully passive set of speakers from these drivers, I rather make an active pair to give out as a xmas present.
I chose arylic plate amp to make these an active setup.
It's a two channel amp, but it has dsp. aux, bluetooth, wifi connectivity for spotify connect airplay and multi room capabilities so it might be super handy.
Power output is a bit low at 40w@4ohm, but I can suffer -3db reduction on the max spl.
Project goals:
45-20000 frequency range with max +/-2 db deviance between 100-10k
Enclosure shall be 3d printed with wooden side panels
Passive crossover
Edge difraction compensation and other eq handled by the plate amp to minimize xo cost
Project cost to stay under 500€ total
I'm currently testing the drivers in a repurposed enclosure from an old kit speaker. I just printed an adapter for the reckhorn subs and a waveguide for the bmr.
Wait a waveguide on bmr? Why?
Well it's mostly cosmetic, but it also evens out the dip at 5-7k and I tried to model it in hornresp so that the increase in sensitivity is right in the middle of the bsc correction. Also it raises the +10k region quite a lot while the driver itself has -7db slope from 10k to 20k.
Currently I have passive xo at 330hz, but I feel it's too close to the driver fs that is around 200hz when enclosed so I ordered more components to make another xo @ 500hz.
Simulated response at 330hz 12bd/o
Measured response in the repurposed enclosure.
Only passive xo and bsc as an active filter. Notice how the previously attenuated top end is now +7db emphasized. The bass boost is a characteristic of my living room acoustics.
The response is great for unfinished product! The sound is also really pleasing. It's not harsh and analytic like in gennies, but soft and pleasing. Even the reflected sound is much cleaner than on conventional speakers and that is mostly thanks to the waveguided bmr.
Render of the enclosure.
Parts used:
Tectonic TEBM36s12-4/A
Reckhorn d165i Subwoofer
Arylic up2Stream Plate amp
Coils from intertechnic
Caps from mundorf
Tools used:
Hornresp for wg and enclosure design
Vituixcad for xo design
Ender 3v2 dd modded 3d printer
XTLW Climber 8 IDEX printer
minidsp umik-1 with rew for measuring
Dayton Dats v3 for ts parameters, impedance inductance and capasitance sweeps
Handheld router for wood panel work
I will finish the cad work tomorrow and start printing these out. Hopefully they'll be ready before 25th 😀
Will keep you posted!
Cinemag S217D
Gang,
Got a pair of the CineMag S217D and they look pretty nice and looking to build a line preamp with them.
https://cinemag.biz/output/output.php
So basically a 12.5K primary to 600 ohm output. The tertiary is throwing me for a bit of a loop. I see 22.2: 4.96: 1 ratio and I take it 1 = 600 puts the primary a bit higher than the specd 12.5K, (13.32K) so is the tertiary 4.96 or ~3K?
I would imagine the loading of the tertiary would effect the primary.
The Pultec seems to be the only schematic I can see using this and this is a balanced usage all the way through.
I was thinking of using a 220H loading some med mu tube and feeding back through the cathode with the tertiary with like 1-2dB of feedback. Parafeed 1.5uF blocking cap.
Thoughts? Help?
Thanks,
Gordon
constrained layer damping with MDF and Ply
I am looking to bond 8mm HDF (HD3) with 17mm Ply (BB) using green goo. Has anyone else done this? And would this provide me with constrained layer damping for my projects? (OB and sealed bass cabinet)
Once I bond the boards I will be treating it as a 'single' board and use it for cutting, routing & CNCing where necessary.
All thoughts on this are welcome, thanks 🙂
show us your hacks
If you take a universal tool then turn out another use for it, you know?
Or make an existing tool function better that it did otherwise, a hack, you know?
As long as its mostly safe. You can sign the optional disclaimer back there <<< 😉
I turned a belt sander into a perfectly straight 90 degree bench sander with as few as a couple 2x4's and scrap plywood. But that's easy, I want to see some better ideas.
I don't have much experience with routers, but that's partly why I'm here. To learn cool router tricks 🤔😀
active/passive 2-stage RIAA with integrated HPF/servo
Whilst looking at some typical architectures for 2-stage active/passive RIAA preamps, I noticed that if the stage order [shelving gain (3180us/318us pole/zero) --> LPF (75us pole) --> gain] is chosen, the final gain stage can be configured as a 2nd order state variable filter (SVF), with the high-pass output used to implement a rumble filter, and the 75us pole incorporated into the SVF input resistor (R1 in the picture below).
This allows the rumble filter to be implemented without adding an additional stage (typically a Sallen-Key HPF) after the RIAA equalisation, and as the DC offset at the HP output of the SVF is controlled (equal to the input ofset of the SVF second opamp), no output DC-blocking capacitor is required.
State Variable Filter. The first opamp becomes the second stage of the RIAA preamplifier:
The complete circuit:
The main features are:
- The first stage implements the RIAA 3180us/318us pole/zero pair using the values originally proposed by Baxandall, which give impressive accuracy with common values. DC gain is 40dB falling to 20dB above 500Hz, so with an opamp such as the OPA2134 (characteristics shown below), the closed loop bandwidth can be seen to be >200kHz with an excess loop gain of ~30dB at 20kHz, giving good distortion attenuation.
- The RIAA 75us pole is incorporated into the input resistor of the SVF by splitting R1 into two sections, giving the exact time constant using common values. This can be done as its 2122Hz LP corner frequency will be more than 2 orders of magnitude above the <20Hz corner frequency of the rumble filter, with the inverting input of the opamp tending to a virtual earth at frequencies above this.
With a fixed gain above the HF cut-on of 19dB, again the excess loop gain is ~30dB at 20kHz.
- All resistors are E12 (if we slightly cheat and form R1 above from a pair of 1k5 in parallel - R4 above is already split into a series pair of 1k5), and capacitors E3.
Total gain is 39.2dB @ 1kHz, with a rumble filter HP corner frequency of 17.3Hz and Q = 0.71 for a Butterworth response.
Simulated frequency response (with inverse RIAA compensated input):
This has been prototyped, installed in re-purposed tuner chassis:
Measured frequency response (inverse RIAA compensated in ARTA):
Measured output noise, input shorted with 100R (measurement noise floor shown in yellow-ish):
Step response, 10mV step, and overload case, 50mV step:
1kHz sine, 6v RMS output, and overload case:
Stripboard PCB layout of one of the prototype channels:
Reactions: Chris Hornbeck
Peerless XT25SC40-04 tweeter in SEOS waveguide, distortion and compression measurements
Hi All! I'm working on a home theater project and am trying to reality check myself as to whether this performance stacks up, and if I ought to stand by this tweeter combination or move on to something else.
My goal is to be able to exceed 105db at one meter, allowing me to approach reference levels at about three meters. I have attached a small Peerless XT25SC40-04 ring tweeter to a DIYSG SEOS-8 waveguide, and have mated it to a Peerless HDS-830869 woofer with an active crossover for testing. The crossover on the woofer is a 4th order lowpass at 1400hz, and the tweeter has a 1st order highpass to shape the response and a 4th order highpass at 1200hz.
Overall, I think I'm getting somewhere but need better cabinet design to reduce some diffraction issues. I'm not a great woodworker and that does not come easily to me, so I'm second guessing a lot at this stage. The Peerless woofer is no longer available, so I'm looking for other options. The other options tend to cost more, so I set out this morning to answer... can this combo hang?
Here's a graph with 1 meter gated measurements stepped in 3db increments.
Here they are again with 3db offsets to lay them all on top of each other. I can't figure out how to set one as reference and the others as deviations from that- I've seen some people do it, can anybody point me in the right direction to do that too?
It seems like it comes up just short of 105db before compression is significant. Perhaps that's OK.
Now here's distortion at about 86db:
Mostly 2nd order, and over 40db down. Looks alright!
Now at about 95db:
3rd order is starting to come up, but is that level low enough? I see reviews of commercial speakers (not even very expensive) that can do better.
Finally, here's how hard I pushed it. About 107db:
Second order is pretty high, and higher order products are starting to show up, though still at fairly low level.
So, is there a better way to go? Any feedback is welcome, thanks for your time.
QUAD 405 updates and clones
Hi, I've been into Quad 405's over the last 30 years or so.
I'm not saying they're the worlds best amp - but the originals are/were exceptional value, and the Chinese clones are too, with a bit of work.
The traditional criticisms of these amps are very easily overcome to make a great classic amp.
The current limiting was the major one, and lots of work rounds have been proposed. The simplest and best of which, in my opinion is to just throw the components in the bin.
I use them because I think they sound good, and have a 3 way active system with dual bass drivers. So need 4x stereo amps for my main speakers.
I've got 2 original ones, 1 original refitted with chinese boards, and 1 which I made as a student in the 1980's from boards I etched myself.
All of these, I've modified in what I consider a 'sensible' manner.
1) using recognized improvements made on later amps
2) deleting the current limiting
3) not redesigning the amp into something different
4) easily done on the existing boards, Quad or clone; don't need new boards.
The diagram is my summary of it.
Please bear in mind I'm not an Elec Eng, just a hobbyist. But I have done these exact mods to about 10 boards, and had them running well for years.
WTD: DIY AD1865 NOS DAC for Raspberry Pi
I'm searching for this RPI dac hat. I wan't to use it for a second set-up in my office. So nothing real fancy. A recaped Naim Nait 2 + some Britsh bookshelfs.
I have a RPI and a Allo Kali that i wan't to use and no need for extra power supply's. Just a simple set-up.
I have try to contact the designer, but he is not responding.
An other good option with te Kali wil be fine to.
https://www.diyaudio.com/community/threads/diy-ad1865-nos-dac-for-raspberry-pi.345225/
Baby Huey EL34, 6550 and KT88: my own take on optimizing them
I've recently upgraded my BHEL34 in order to test a special NFB loop I'm workin on.
I started by the last working point suggested on Mullard datasheet ( https://frank.pocnet.net/sheets/129/e/EL34.pdf ) for maximum power, slightly adapted.
I now run them at 460V and 44mA, on a Raa of 6.6kOhm and 23% ultralinear taps.
To improve the loadline of the phase splitter (so making it flatter) still being able to keep a good local feedback on the EL34, with the plate voltages below 300V and the cathode voltages above 0.9V even at maximum power, I've modified the 220k + 47k + 39k combo into a 330k + 33k + 27k combo to supply the two triodes.
The reduced UL tap increase the available power, lowers the driving requirements and also the input capacitance of the EL34, but the higher swing compared to the EL84 pushed me to increase the current flowing through the power drive, so to reduce the bias resistors of the PD CCS down to 100 Ohm. This allows to have more current to be able to swing more volts on the grids of tghe EL34.
I wont' repeat the calculations here, you can find them in my EL84 thread.
I have old boards, with PSU onboard like for EL84, so I worked on the dropping resistors to set the voltage of the powerdrive and phase inverter CCS.
I set them to 100V and 30V for EL34 and 120V and 25V for 6550.
I've played the EL34 amp (without the new feedback) all saturday afternoon and I liked it alot.
It has alot of definition and it performs very well on many kind of music.
It pushed my Klipsch to very high levels, far beyond previos versions.
I hope to have one evening during the week to test the new feedback and report the results.
The new feedback will use an OPAMP to amplify the difference between a scaled down version of the output of the amp minus the input signal, so basically only the distortion. Simulations give ppm distortion at 1 Wrms and a Rout of 0,09 with that specific feedback, and a maximum power above 50 Wrms.
I need to find a load to test the full power in real conditions.
6550 version has only been simulated until now, and with an Raa of 4k with UL at 23%, with the same 460V B+, will give around 80Wrms.
Here below you can find the modified schematics.
Focal FPP5300 5 Channel amplifier
Good day to all. I hope all is well and good and having good repairs this past days. I have a Focal FPP5300 5 channel all in one amp. Been troubleshooting it for a couple of day now. The issue was it is in protect mode , after troubleshooting there was an input capacitor 10uf 25volts going to the sub driver ckt. output section which was deffective, after replacing I can now see the signal after the capacitor going to the sub driver circuit but does not go through the output terminal of the sub, that means no signal coming from the sub amplifier section output, and still in protect mode. But when I connect a sub woofer on the output terminal. The amp is good and goes out of protect mode. Make an audio test and all channel are working perfectly. Removing the subwoofer from the terminal then again it goes protect mode. Can anybody have an idea why this happens? Why it needs an impedance connected to the sub output terminal on order for it to work>
Solid state replacement for EL34 in power supply application
I am restoring a 1966'ish vintage lab power supply that uses 5x EL34 in pentode mode for series regulation of separate plate and screen supplies up to 500Vdc (using a 620Vdc raw feed). I may well end up using valve alternatives to the EL34. I don't want to modify the existing circuitry, which is likely similar to HP’s 712B from 1954, and Fluke’s 107D from 1964, although I won't have a full schematic for another 2 weeks. I am interested to hear if anyone recalls any effort to make a solid-state equivalent (ie. valve pin compatible) of a power pentode. I think the most well known low-power ss alternative was the Feltron from the early 1970's. At the moment this post is just to reconnoitre the scene in case I've missed someone's effort.
Good compact 4 pin amp connectors?
I'm currently designing a set of compact two way desktop speakers that are bi amped, and want them to have a detachable cable.
Does anyone have any suggestions on connectors with 4 pins that might work? I was looking at the mini din connectors but it looks like they are only rated for 2 amps at 12v. I'm worried they won't handle the power as the chip amp is 24v and outputs 30 watts into each channel.
Looking for a cheap driver for bookshelf speakers
I have a good friend wanting some new bookshelf speakers. He appreciates good sound, but he primarily listens to 80's punk rock so we're not talking about bass or good recordings. He will listen to folk and other stuff occasionally, but is not an audiophile in the sense of demanding the best from his gear. These will be for bedroom/small room listening, max 10 feet away and likely placed on a shelf close to a wall.
I'm thinking something up to maybe 5" size and a potentially one of the BabyLab cabinets. Is there a reasonably priced driver with decent performance in this size? I'd like to keep cost under $100usd not including the wood for the pair.
Marantz CD63ki
New to the forum but visited a few times and know there’s a lot of knowledge here.
I’ve got a Marantz CD63ki and I’ve got 2 issues with it. The first is that sometime when the tray is opened it shuts immediately without anything being pressed. The second is that the laser sometimes skips and this has slowly got worse. I know the transport is east to swap over but can’t seem to locate a genuine unit. There are plenty on AliExpress etc but these all look aftermarket as the motors seem smaller than the original.
Any advice would be appreciated.
Mo
One Power Supply To Rule Them All
So... lately I have seen with some consternation that the new "amp racks" I recently bought are already stuffed with big black boxes with a blue light out front.
It came to me that in the lab we use big programmable metrology quality power supplies. We don't put power supplies in our stuff, instead we rely on external units with voltage and current controls.
Already in some components, particularly low level and Big Pass Irons, the power supply is on a second chassis.
The next step would be to separate the power supply from ALL components... why rebuild the power supply every time the amplifier boards get redesigned?
After all, the job of the power supply is to provide a stable voltage with very little noise. We could add some current limiting as well as the cherry on top.. and for that, I can't think of anything better than what we got in the labs (or your own bench). The power supply doesn't much care if the drivers are tubes, VFETs, bipolar.... well, yeah, a tube power supply is a different thing... the amp itself might need an internal transformer to bump up the ~100VDC to ~500VDC...
How about using an instrument grade power supply instead like an HP6010/15A with ~1000 watts:
https://www.testequipmenthq.com/datasheets/Agilent-6015A-Datasheet.pdf
Sure, it will look like we brought the bench to the living room and it will require a cheat sheet not to burn up the amps... but, but.... if would be nice if it could look like this:
https://www.usaudiomart.com/details...output-tungar-dc-power-supply/images/4433276/
Something retro that looks like the stuff the Traitors Of Earth used to communicate with Ming Of Mars. Will fit nicely with the danish mid century furniture.. sort of.
NAD3020 problem on output transistors power
Hi guys,
I'm new to this forum bit I've post the process elsewhere is anybody is curious to see.
I have change fews part and now just installed new output transistors from ON Semi(new motorola). The problem is the +30.5Vdc and -30.5Vdc from BD901 and 4 mains big caps. When I probe it to the board I have +60Vdc and -2Vdc...
I getting near to clueless about this.. when I pulled out the old output transistors and verify voltage at caps and had the +-30.5Vdc.
Left channels looks alright all over the power amp that I chech yesterday and it was before the replacement transistors. Right channel was now okay and I have to check that with new transistor.
Could the soft-clipping could make that weird voltage?
I've put attached the diagram I have put together from the manual.
Thanks for all the help in advance!!!
Taramps MD5000.1 stuck in protect mode
Hi, this is a friends amp Im trying to help diagnose. The amp powers up and fans spin then it shuts down and the protect light comes on the remote. Also, the red light on the amp flashes fast. I opened it up and looked with a magnifying glass. No signs of damage and no smell. Is anyone familiar with this amp and/or problem? Any help would be greatly appreciated. Thanks
Sealed driver in ported box
Hi everyone,
I have a pair of 5.25" mid-woofer drivers. Their parameters are as follows:
fs = 68 Hz
Vas = 0.23 cu.ft.
Qts = 0.45
Xmax = 6 mm.
Imp. = 4 Ohms
Power = 65 W
According to Loudspeaker Cookbooks, a rule of thumb suggests that drivers with Qts of greater than 0.4 and high voice coil overhang (Xmax) be used with closed box. Nevertheless, I wonder if I use these drivers with vented box, what will be the results?
Actually, I'm going to use them in passive radiator system. But, AFAIK, the PR system gives the same result as vented system, doesn't it?
Philips CD650 NOS mods - switchable between NOS and SAA2770 OS
Hi There,
I built a daughter board circuit that sits at the current location of SAA2770 of my Philips CD650. With it I can switch between NOS and OS mode by flipping a switch. There's no circuit modification. You can convert it back to the original hardware configuration simply by removing the daughter-board and re-inserting the SAA2770 back to its own socket.
The daughter board:
System running together:
Front Panel NOS indicator:
Mode control switch and NOS indicator wiring:
With the quick A/B listening test results, I prefer the NOS sound. It is more transparent and musical. But it's more susceptible to disc scratches as it's missing the SAA2770 interpolation to cover up the missing data.
A3K
Diatone P610 versions on offer
I want to replace a FE103 in a 110 cm TQWT and understand from reading around this Diatone speaker is more promising for a relaxed sound than a Fostex FE166.
Right now in 2017 I see two versions of a Diatone P610 clone on Alibaba (davidlouis store), the classic one having a magnet labeled Alnico.
1) a copy of the original with an inside small alnico, a rond piece of metal, a pair costing about $ 250. Open magnet structure.
Fres = 52 Hz
Qts = 0,64
Qms = 11,9
Mms = 4,1
Vas = 68L
Spl = 93,3
Bl = 3,6 newton/ampere​
2) A copy with a different flat ferrite-like magnet, a pair costing $ 130.
Fres = 49 Hz
Qts = 0,47
Qms = 8,7
Mms = 6,4
Vas = 48
Spl = 91,9 dB (the less efficient of the two)
Bl = 4,7 newton/ampere (the more forcefull of the two)​
The membrane and suspension look exactly the same on the pictures. Still there is a significant change in Mms. The frequency response curve are virtually the same for both products (I mean it looks like a carbon copy; this test was made in 2015/09/01)
Such a different in the measurement of Mms surprises me, seeing the same assembly. Mms is the moving mass isn't it? 😕
The second claims a higher BL but seeing the sensitivity, this fits the first one more (1,5 dB more). Chinese ads?
Anyway,
  • which version is better for open baffle (for sure #1, the classic)
  • which version is better for TQWT (I would expect #2)
FS: Hicoco alternative-supply for UGS muse Preamp
Hello !
i have bought from the forum user "Hicoco" this alternative power supply for the UGS muse preamp project.
Due to a direction change on my project, i no longer need it. so i am here to sell to someone else that can benefit from it.
Uses 3 Hammond PCB transformer. 110-220v selectable.
Integrate 2 unregulated low-voltage output, and 4 ultrabib 1.3 regulated ones.
bipolar configuration.
all independents. So it can be useful also for other kind of projects... not just the muse-preamp.
The board is pretty big 287x287mm. 4 layer.
can accomodate all sorts of output connectors.
Asking 40€+shipping (to be calculated)
For 10€ more i can also include the 110/220v selector switch + all the needed heatsinks for the shunt's
All the docs will be supplied to who will receive the board.
Thanks !
- Michele
First Watt F4 Mockup Question
Giant 15lb heatsink would be cut in half at machine shop to make two.
Any reason I shouldn't cut these boards and do this???
DIY F4 board is too wide for my heatsink. Cut off ends to fit.
Place ends under main board and jumper together with just 4 short leads.
End result would look like this (wrong transistors shown)
Another view
Cardboard represents "1/4" Aluminum faceplate 12" x 5 7/8" (top portion of heatsink will be cut off). The total amplfier width is 17 1/2" so rack ears could be fitted. Should look great with the short fins on front and rear!
Inside area view. I'm not sure if I'll go capacitor board or screw top cans. Leaning towards screw tops. Also, one 500VA trans or two 250VA transformers?
Very large 3" heatsink "uniqe double sided"
Another view (note: double sided heatsink).
What say you?
Gary
Transformer P/N: Building (1) box PS for dual mono ACA 1.8 using DIY Universal Power Supply
I really need your help.
PTSD and post ChemoBrain confused on Dual ACA for mono p/s
Attempted ordering one or two AntTekl or other transformers and spacing issues.
Attempting to build one power supply chassis for both.
- struggling to use Mini Dissipante 2U --> maybe 'possible or impossible' to fit? (would be nice if anyone knows from experience)
- 3.5" x 1.5" internally available if I use the current chassis.
First question: What transformer should I purchase to power these p//s boards and two ACA mono configs; even if it will not fit in my current case?
Second question: What chassis should I purchase if I am really unable to use the 2u Dissipante?
I appreciate your seat-knowledge expertise.
John
6N1/6DJ8 - 6N6 WCF headphone amp.
So as a follow up to the 6N3/6N6 line/HP amp I created, I finally built a version using a WCF as output instead of the simple active load.
The results are nice.
Pout is 180mW from 32R to 470R.
2.4V volts out with 32R load, 9V out with 470R.
I have four boards available at the moment. 5$ each + post because I left off the 1000uF caps - just solder them across the resistor leads.
Here's the schematic. Copyleft as usual. Same dimensions as the old board.
The schematic says 6N3 because I was originally going to use them - the board is 9AJ.
Different box tuning, playing the same signal
I'm designing floor-standing speakers. They contain two separated chambers as depicted on attached. The upper chamber is passive radiator system, and the lower chamber is sealed system. Note that the midrange labeled in the picture is actually a woofer in upper chamber -- No high-pass filter applied to it.
There is no problem with the lower chamber because it's simple sealed design. The problem is the upper chamber. I tried playing with online calculators, they suggested that the PR chamber is tuned at 33Hz, while the sealed chamber is tuned at 58Hz. If they're played the same music signal, will it cause any problems? However, it's similar to car audio system where the front and rear speakers may have different tuning frequency, I think.
Preamp and amps getting warmer when listen to FM tuner
Hi !
I have noticed a strange behavior of my hi-fi set-up.
When I listen to the radio through the FM tuner, preamplifier and power amplifiers get warmer than when I listen to CD/SA-CD/DVD-V or LD. In fact, in the latter case, preamp and power amp barely heat up from ambient temperature, whereas in the former, temperature of the cases is noticeably warm, especially just above the regulated power supply of the preamp.
I should add that when I listen to digital discs after the preamp+amps have got warmer after tuner listening, the case temperature of the downstream equipment cool down.
Any idea which could explain such a behavior ?
Weird crack(l)ing sounds coming from my Rotel RSX-1562
Hello peoples of the internet from a new member! :wave:
I have a problem and hopefully this might be the place where I could get some insights from someone smarter and more experienced then myself in these matters.
If yes; thanks in advance, if not; apologies in advance! 🙂
So, my "old trusty"® Rotel RSX-1562 has lately started having some issues. Not sure exactly how old it is, I bought it second-hand a bit over 3 years ago.
Some minutes after turning on (typically 10-20), some crackling noises start coming out of speakers, and it lasts for a good couple of minutes, then they disappear altogether.
However, noises are most audible when HDMI inputs are used (for some reason), and also most audible from center and rear speakers (I have 5.1 setup and typically use 5ch stereo audio mode). My front mains are 4ohm, all other speakers are 8ohm. Also, when audio is switched to stereo mode the crackling noises seem to down a bit, but again it might be to different impedance of the speakers.
To me it sounds like there's some static building up and then being released. It's typically higher frequencies crackling.
From other inputs (analog, coax or optical) noises are much much more quieter and harder to observe (I had to sit on the floor next to the front speakers waiting for crackling to occur) and I only heard them from HF unit (which means they are above 3kHz).
After RSX has been turned off for at least (cca) 30mins, and then turned back on, the weird sounds will reappear.
So far I've tried different computers via bunch of HDMI cables, no difference. Same issue is from my TV box as it also connects via HDMI. Since there's a 7.5m HDMI cable from my PC to RSX which passes by several other power cables and speaker cables, I thought maybe some static can accumulate in it, but wasn't able to prove it so far.
So now I think that something in RSX produces those noises when heated up. I'm in the process of obtaining a different AVR that I can connect instead of Rotel so I can take Rotel apart and check inside.
Any idea as to what might be culprit for these problems? Something inside the RSX or something completely unrelated? My plan is maybe try to replace some of the power caps?
Sorry for the maybe-not-so-coherent-text and rambling, I wrote it as things kept popping in my mind.
Thanks for any suggestions!
https://www.rotel.com/sites/default/files/rsx1562_guts.png
Markaudio 11ms problem
Markaudio MS 11 problem?
I built a pair of rough all be it in ply mid size nostromo's to run the drivers in, gentle for first 10 hours now have 20 hours on them.
The problem being they sound flat/ lifeless my chr 70.3 in a planet mini tower are running circles round them. Is it a break in issue? Company states 10 hours only for the MS, is it the cabinet? Want to get them in a MTL cabinet as they feel restrained in this box almost suffocated if that makes sense.
Bass seems fine but the mids seem stifled and no sparkle up top.
Class D Crown ?s
The question is for their later Drivecore2 amplifiers with crossover. The stereo mode offer decent flexibility, for one example you can independently set the crossover between the L and R channels. Useful with active set ups. https://www.crownaudio.com/en/products/xls-1002
Further more it will handle 2ohms in stereo no problem at all. But what if the ohms were mismatched between the two stereo channels? Meaning the Left sees 4 ohms the Right sees 2 ohms? And while doing parallel meaning two subs on one ch vs. one on the other simultaneously, equaling 2ohms ch1 4ohms ch.2. I'm thinking its okay to do so, but double checking is safer sometimes. If need be it can be in series, there should be enough useful current there to satisfy needs.
Broskie five tube EL84 PSE question
I'm hoping someone can help me with two questions on this simple circuit...
1) To parallel these grids I have two choices, 1. a simple series string like what is shown with one stopper or 2. each tube with its own grid stopper all terminating at a common star at the input. I'm assuming this wired series string is ok with just a single grid stopper at the beginning. (series stringing grid stopers isn't an option because the stoppers would sum across the five tubes progressively different per tube). Which would you do, like its written or star-join dedicated stoppers?
2) Do I really need 1000 uF bypass capacitors? What is the smallest Ck value do you think I can use here where the difference is inaudible from using 1000 uF? Is there a simple computation for Ck without simply always just "making them big"?
TL072+LM1875 improvements
Hello!
I would like to ask for advice, regarding any improvements to these chip amps designs from the 90s. It may be that this design is already as good as it gets...
I am using these (schematics attached) amps to drive Horn mids and Horn tweeters, which use little power due to their very high efficiency. I am using max of 1-3 w/ch into 6 ohm loads at the highest listening levels. I'd say usually staying under 1 watt!
1. I need balanced inputs (already included)
2. I am willing to try different dual opamps that are designed work in this configuration. I believe it is unity gain differential application.
3. Don't need headphone out, ignore this section
4. I there are other things to try, please share your thoughts. Is anything a clear deficiency?
Happy to keep this amp "as is" but also willing to try obvious improvements.
Thanks!!
Armstrong 621 and 625 complete rebuild
Hi All
Like many others on here i have some armstrong audio love to rekindle, i remember as a child my uncle playing his 625 receiver through some kef speakers, at that time it was so lovely to hear and look at, this was my first introduction to hifi.
Even today the looks of these amplifiers are brilliant! So i went and searched and bought these two units, the 625 and 621.
I want to rebuild the integrated 621 amplifier, the 625 was thrown in for the deal as it was damaged in transit. For me this was great as i can use it for spares, they share the same makeup right?
So this is my plan, i would love to upgrade the boards with better components such as doing a full recap of all the boards such as the preamp, amplifier board and psu etc
I also want to change any transistors and diodes which i have read can go faulty. I would like to build this amplifier to be like brand new and to last another 20-30 years.
So my questions are:
Is it worth replacing resistors? What resistors were used (type carbon?Metal film etc) The amp board would be easy to do i could replace all the components with new parts (not to sure about the bias resistors) they look odd and special heat disspersation types.
The amp board has other tiny driver transistors, do these tend to go and would it be a good idea to replace these?
I am slowly going through the circuit diagrams to understand it all better, i also know over the many years they changed components and always upgraded or made changes.
I will start with the 621 by just replacing all the capacitors, diodes and small transistors to get it working and running as it should. The 625 will be where i play around with it and try to upgrade the components.
Any advice would be appreciated such as what the bias should be, where to measure the bias, known things that should be checked, changed, replaced etc.
One other thing is the potentiometers on the 621 are very stiff unlike the 625 which feel smooth to turn, the input selector on the 621 takes quite a bit of force to click into place, where as the 625 is smooth and doesn't take me to squeeze my fingers hard to turn it. Wondering if spraying detox in there will solve this issue.
From what i have read the 600 range were modular and share the same boards
C28 input board
A17 power board
Z20 power supply
which means i could actually swap boards from the 625 to the 621? The 625 seems to be more modern.
Also can anyone tell me good replacement parts for these parts
BC267 & BC297
BC384L transistors (would like similar or better i.e lower noise)
The bias trimmers seem old and risky to use would like to replace these with some bourns what power value would suffice here they come as 1/5w to 0.5w.
On the A17 power board there are some axial capacitors
2 x 220uf 50v and 2 x 47uf 100v which are polarised, could i replace these with non polarised (i have some which are of good quality and make).
The z20 power board has some tiny 1n4003 rectifying diodes could i replace these with something better like schottky diodes?
I also see many small eirie type capacitors of small values, thinking these would need replacing aswell? think these are Poly film types. Could i replace these with polyester, polystyrene or silver micas? lots in the tone control board!
The psu smoothing cap is 3300uf would it be ok to go slightly bigger? say 4000-6000uf? same goes for the DC speaker output caps which are 4000uf wondering if going slightly bigger has an advantage?
For further information!
The Armstrong 600 Series - Amplifier FAQ and diagrams
Yes its worth spending time and money to rebuild this back to its former glory! Any tips or things to look out for would be great.
Thanks all those interested!
Weird mouse noise
My sound system is a Philips set as amp...Panasonic chip amps.
It is connected to the 3.5 mm output jack of my computer, and the computer is used as the DAC, playback etc.
Core2Duo, Gigabyte 41 series board, 2 GB RAM, Windows 7 ...it works well enough for me, I left Win 10 and came back to Win 7.
VLC player for video, Winamp 5.66 for audio.
The weird issue is there is a crackling noise when using the scroll wheel on mice, or even when using the slider on the side panel.
Checked with another mouse, and the up / down keys on the keyboard. Same result...
Any suggestions are welcome, this is a bit of a head scratcher for me.
Earthing is perfect.
Roland UA S10
I got this one as a token of appreciation for my work on a reel-to-reel deck from my musician friend... The thing looks very nice and the build quality is just superb. Initial impressions were excellent, the headphones-out sound was well-balanced and extended. So... I thought why not hook it up to a CLC linear supply with some pre-regulation, followed by 4 x LT3045 final stage voltage regs... Well, as I've been saying... the sound of any piece of audio gear is 99% power supply... the end result was quite impressive.
I replaced one 5532 (just in front of that TPA6120) with my favourite... AD8066. This further extended the highs and lows, with even better spacing left - right, as well as between individual instruments. Good stuff.
Here are some photos... the mods are fairly straightforward... the result is simply amazing. I encourage other DIYers to do the same or similar... the mod can be easily implemented on anything that requires no more than 15V / 2A max (limited by LT3045). For dual power supply rails, there's LT3094...
I have a recently purchased used Yaquin MS-20L amplifier.
Fired it up for the first time and it sounds pretty nice. I noticed when I put a meter on the bias points for each EL-34 they were all seriously low. That leads me to my question. Anyone know the proper tool size for adjusting the bias. It's clearly not a flat blade screwdriver but beyond that I can't tell. Standard hex? Torx? I know the amp originally came with the tool but it's long gone now. I figures it was time to ask the braintrust.
Thanks in advance
f1jim
Obscure Peerless XLS style 8" (sub?)woofer
I saw these for sale on eBay and decided to take a punt. Very much unknown but seem to be from the XLS family although I wasn't aware of an 8". After a bit of digging I and obviously via the Mission sticker I found they are used in in some Mission active subwoofer.
Fancying trying to build a compact SLOB or just OB I thought these things might be able to be pushed a bit. If only due to the heavy surrounds.
They're were specced by the seller only as 6ohm but this appears to be a DC reading and so they're an 8ohm voice coil. Not very big a VC either...shame!
Magnet is doubled up but not very large diameter. The whole driver is quite small, only 210mm overall diameter. Effective piston about 160mm diameter. Basket is cast aluminium but quite light feeling.
So out of the box I'm a bit unimpressed with the overall sizing for an 8" 'subwoofer'. Maybe has some LT from the plate amp it would have been used with ?
Anyway I did some sweeps on it with DATS. Fs dissapointing at about 52Hz....my RS225s will probably be better! Suspension is very firm so will probably take some power there but the VC being quite small and seems a paper /cardboard type former I'm guessing heat will be an issue before anything else .
For Sale Pair of PCM1701P DAC chips
I have a board from a Luxman CD player that has TWO Burr Brown PCM1701P DAC chips on it
they work fine but the player has front panel cosmetic damage
I am selling the pair for $95 plus shipping in the USA
you get the board they are on but some other parts will be missing, you are only guaranteed to the the 1701s
you remove the 1701s yourself so you know I have not damaged them
these are highly rated DACs, see the second photo
http://vasiltech.narod.ru/files/PCM1701.pdf
Sundown
One out of the four 4.7 ohm resistors right behind the speaker terminals keeps burning after replace .what can cause that?
Drive signal on the output FETs for one channel not looking good at all.I replace the FETs but no change. Any suggestions?
Complementary-Symmetry Cascode Amplifier
A complementary symmetry all-cascode power amplifier design with no overall feedback. Local error correction for the output stage which uses low-voltage high-current MOSFETs in a cascode configuration with power darlington bipolars. Simple signal path but with elaborate support circuitry for current sources, etc.
Question: Will the output stage be stable? I never built this design but am curious to know if it would work as planned. I am self-taught with no degree in EE, so please be gentle with comments. Thanks!
Notes:
1) The active current-source load for the input differential pairs was borrowed from a Burr-Brown linear op amp applications book, the purpose of which is to reduce DC drift in the front end and improve common-mode rejection.
2) The idea for the error-correction circuit in the output stage was borrowed from an article (circa 1976 IIRC) in the Journal of the Audio Engineering Society written by a British audio engineer (I can't remember his name) and was described as "feedforward" error correction.
Stereo inter-ear crosstalk minimizing for typical stereo loudpeaker setups - can it work?
A stereo listening experience without inter-ear crosstalk can be quite amazing, and can be archieved quite easily within a really simple, but effective setup. Just grab any board and sandwich/squeeze it between your two speakers. Then, listen with your nose as close as possible to the outer rim of the board. Despite the quite owerwhelming listening experience you get from this one, nobody does want to listen like this for a longer time. Neither did I. I tried this one out with the mounted-away bathroom door. No kidding.
In a more normal stereo setup, typically you need two direct auditive paths/sectors, and for general convenience also one optical path/sector to listen to stereo in a home environment. Especially the audio paths/sectors must not be obstructed by any kind of structures, and also the visual one in case of a central screen.
Then, within this setup, there are these nasty xtalk-paths/sectors, inevitably making stereo to become xtereo. In order to theoretically avoid any interaural stereo crosstalk to the contralateral side, the sound energy within these paths/sectors to the contralateral ears should be either completely absorbed, or completely deflected away from the direct path to the contralateral ears. This might be performed by inserting obstructive structures right into these pathways:
By geometrically intersecting all the necessary and all the unwanted pathways, two aeras (or, more precisely two room volumes) will become evident, where the direct contralateral x-talk-path/sector can be obstructed, without obstructing the direct isolateral audio and optical paths/sectors. And only there you may place absorbing and/or deflecting structures, in order to be effective against xtalk without disturbing stereo. As the dimension/space of this intersection aera/volume is very limited, these structures necessarly will be acoustically small and ineffective at low frequencies. This means, that only higher frequencies will benefit from these anti-xtalk-structures:
The obstructing anti-xtalk-structures could be e.g. a hard board for deflecting sound away from the straight path to the counterlateral ear, or a woven PET acoustic absorbing board for absorbing sound energy, a combination, or anything else which might be suited. Also the shape of these structures might be quite variable and would have to be empirically optimized within a trial-and-error cycling process:
To define the the sectors in the above graphs, I arbitrarly chose to define them by the horizontal boundaries of the speaker baffle. And as said, because of the limited possible size of the x-path obstructing structures, only a frequency-dependent and partial x-talk minimizing effect will be archieved by this kind of setup. The higher the frequency, the more effective it might act against acoustical x-talk. And also, this is a first draft without proof of concept: I did not yet set up any experiments with this one for my own yet. I think an optimizing process should begin with a clean stereo geometry variant especially adapted in order to make the obstructable aera as big as possible. To allow for acoustically relevant obstructors.
If anybody already has own data about this approach, I would greatly appreciate to hear from these real-world-findings.
Reactions: deanznz and tmuikku
Burning Amplifier BA-1 PCB with attached Mosfets IRFP 040
I built this Single Ended amp several years ago, listened, enjoyed it and instead of stacking it on top of the other retired amps, I decided to refurbish the amp chassis with a different Pass design inside.
So I am selling the 12 pretty well matched IRFP040 Mosfets and the attached PCB (BA-SO V2.0 and BA-SB v2.0) ready for a new power supply and case and whatever frontend you like (not included). $120
I doubled up on the 1 ohm resistors (now 1/2 ohm) and added a pot to adjust the value of R19. Read Mr Pass' notes to see why.
I also have 10 more (3 are used but good) IRFP040 Mosfets that will go with this package. $100
Also I found a set of BA-CB V2.0 input bias boards I'll throw in too.
The boards for this cost $29, the output devices (IRFP040) are hard to find, but on eBay they go for $19.99 each. I figured I would sell the IRFP040 for $10 each.
$120 for the 12 soldered to the boards, and just giving away the boards with the devices. SOLD!
The 10 extra IRFP040are still available
I will split up the package, so let me know if your interested.
There is no case or heatsinks or power supply included, just what is shown in the pictures.
PM for shipping quotes with Zip code.
Will need a phone number to ship.
Rush
Connecting headphone amp IC into DAC IC doubts
I've made a prototype device using a PCM5102a DAC with line level output and I now want to make a PCB out of it. In this final device I'd like to have a headphone amp. For the headphone amp IC I have selected TPA6139A2
Since I'm no audio expert, I mostly went with Datasheet application notes and PCB layout guidelines. I have some doubts tho in terms of how exactly should one IC connect to the other.
PCM5102A datasheet recommends adding a lowpass filter at the line level out (red box in the schematic). It also states that "the PCM510xA devices provide 2.1-VRMS ground centered outputs, allowing designers to eliminate DC blocking capacitors on the output".
On the other hand, TPA6139A2 application note places a 2.2uF capacitor at the input (blue box in the schematic). I figure that if the PCM5102A is ground centered, these capacitors wouldn't be necessary.
Couple of questions:
1. Is the last assumption correct?
2. Is the lowpass filter at the output of PCM5102A needed or is this intended just for an actual line out of the device?
3. If I wanted to add this headphone amp AND a line out from the device, could I just branch out from the DAC output into a line out with the lowpass filter and the headphone amp IC? TPA6139A2 input impedance goes from 10kOhm to 55kOhm depending on gain setting. I figure having both the line out and the amp in parallel would still be a high enough impedance to be easily driven by the DAC (datasheet states DAC can drive a 1KOhm load)
Cheers
Xen Audio JLH 1985 HP amp boards plus new enclosure
Two perfectly built JLH HP amp boards plus new unused enclosure. Boards have been built using well matched Sanken / Toshiba transistors with Vishay MELF and Susumu resistors.
https://www.diyaudio.com/community/threads/the-real-john-linsley-hood-headphone-amplifier.320808/
Looking for £50. SOLD SOLD
re Hafler DH101 - OK to use substitute Darlington transistors?
The Hafler DH101 I own contains what I suspect are problematic Darlington transistors. Specifically MPSA13 and MPSA63. I have read that BC516 and BC517 can take their place.
My belief was that MPSA13 and MPSA63 were obsolete which led me to look for substitutes. Consequently I shall shortly be receiving the BC516 and BC517 which I ordered.
But I have since learned that transistor manufacturers other than On Semi produce MPSA13 / MPSA63 and those are still available. Can I proceed with using BC516 / BC517 or would it be recommended to obtain non-On Semi made MPSA13 and MPSA63?
Mains power garbage in my amp
I have been plagued by what I felt was power line noise in my FFTs of amp circuits for some time.
Some have stated it was IMD, which to some degree it looked like, however I was convinced I had power issues greater than IMD.
To that end I am going to investigate power line noise from my mains, and power supply noise from simple SS rectified circuits which I was using to power a low noise (Victors) 1KHz oscillator which exhibited high background noise.
First up is a simple scan of powerline noise made using an FFT (ARTA) program, of the output of a 2.5VAC CT transformer (Triad F-6X) through a resistor divider (470R-470R) to prevent overloading the sound card front end.
Not a pretty sight, is it? This has been filtered (to some degree) by an isolation transformer which is used to separate my test circuits from the rest of the house system.
Next I will try using a line filter to clean up the mess.
Reactions: YashN and kevinkr
Audio SMPS units for sale
Up for sale 3 SMPS units with below specifications.
SMPS-500 quantity available 2
500W Continuous power 900W Peak
Unregulated Output voltage: from +-45VDC to +-90VDC
Regulated +-15VDC
110VAC or 240VAC selectable via jumper
Protection: Thermal, over current & short circuit (Permanent latch, no auto recovery) must restart SMPS and disconnect from AC line.
Maximum extra capacitance can be added to the output up to 4700uF per rail (externally)
Startup delay 2 ~ 3 seconds
PCB Size 12CM x 10.7CM
SMPS-1200 quantity available 1
Power: 1000W Continuous, 2000W PEAK.
Possible Output voltages:-
+- 53, +-64, +-78, +-93, +-104. (Unregulated)
AUX1: +-15VDC (Regulated)
AUX2: +-24VDC (Unregulated)
AUX3: +18VDC(Regulated)
ALL AUX voltages can be changed.
Separate FAN output
Maximum extra capacitance can be added to the output up to 8000uF per rail (externally)
Size: 20.5CM x 11.5CM
Protection: UVLO, Thermal, Over Current, And Short Circuit. Auto recovery every 3 seconds.
Some pictures attached, the 1200W version is still not fully populated, as I have to install the parts according to the output voltage.
For Sale Lowther EX3 pair - New in original boxes.
Asking price £980 (RRP £1452)
Postage free for UK mainland, others please send me a message first for cost estimate.
Western Electric assessing possibility of again producing tubes
This is possible the best news regarding tubes since, well, at least pre 1980, so I thought I'd best post a link here in order try to help generate as many submissions to Western Electric as possible. https://www.westernelectric.com/expand
The more submissions they get, the better chance we have of them again going into production again. As they say, they already have the tooling & machines necessary, so come on guys, get your submission in & share this around the world. Cheers
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,700
Members
7,884,880
Messages
Filter
Forum Statistics
Threads
406,066
Messages
7,884,880
Members
507,700
Latest member
Tomasz 026
