Troubleshooting Acoustic Research AR-1 powered speaker amplifier
- By WattPusher
- 3 Replies
I was visiting a friend who sent me home with a broken amplifier out of a pair of powered column speakers. It's an Acoustic Research Hi-Res Series AR1 and the Intertubes and the current website for the manufacturer haven't been forthcoming with a schematic. I can't even get a user manual to understand just what I'm dealing with (it's not as simple as line in and speaker out).
Initial complaint was, unit wouldn't power on. Internal 5A mains fuse was blown. Checked toroidal power transformer secondaries and they're all fine.
There are three boards; one is a power supply board but all it really does is rectify and filter the +-130V supply for the power amp board and route the other PT secondaries to the other two boards. There's a preamp board that gets an 18VAC secondary and the power amp board gets two other 18VAC secondaries that seem to be turned into +-15VDC or so on the power amp board. I think the power amp board is a biamp. The power amp board seems to have some sort of standby circuit on it. There are four pairs of TO-220-case transistors bolted to the metal back panel and then there are two pairs of big ol' honkers in what I think are TO-264 or TO-3P cases. I ohmed the big ones out in-circuit and discovered that one of the two NPNs, a Toshiba 2SC3281, had dropped the "semi" from "semiconductor" and was acting as a pair of jumpers.
I removed both the NPNs, established for certain which was the bad one, left it out, and soldered the good one back in. When I applied power, the mains fuse did not blow but what was weird was that the amp itself - not speakers; no speakers were connected - was making a very pointy-sounding 60Hz noise. I turned the variac down to supply about 50VAC, just enough to have the onset of the noise. I have tried but so far failed to determine what component(s) are vibrating to make the sound, but I got out the scope and saw nasty waveforms on the power transistors.
This leads me to suspect the +-18 power supply for the power amp board and sure enough, if I disconnect those PT secondaries the noise stops. But before I go any further I want to ask if the noise could have anything to do with running the amp with one of those two paralleled NPNs missing. I'm not giving the amp any audio input and as I said, no speakers are connected as of yet. I'd like to avoid making one purchase of a 2SC3281 just to turn around and order more parts separately.
