Creating Spice Models
back to diyAudio Wiki Main Page
back to: LTSpice and What the New User Should Know
back to: Models and Modeling Aids
Here is an excellent page by Andy_C that documents his modeling of the MJL1302a/3281a power BJTs. The process is described in detail so you can do it yourself (although a bit advanced).
http://home.comcast.net/~andy_c_publ...e_models_1.htm
And if you're really in a bind, what's below is better than nothing. Don't make models with this and post them here. This is only a very rough approximation of characteristics from datasheet values, so the models will be questionable at best.
References
This documents the Gummel-Poon BJT SPICE model:
http://www.electronics.oulu.fi/Opetu...UT/GP_DOCU.pdf
The BJT default in ISSPICE4 gives first order, Ebers-Moll, DC parameters; but it does not provide parameters for Transient or AC analysis. The following default can be used when minimal data sheet specifications are available by using the PARAM program to evaluate the equations in curly braces. This model will create a good transistor model from virtually any data sheet. The parameters you must specify are: IMAX Maximum collector current COB Collector-base capacitance FT Gain bandwidth product in Hz TS Storage time The equation-based model is shown below: .MODEL NBJT NPN (CJC={2.2*COB} TF={.16/FT} TR={1.7*TS} +CJE={7*COB} RC={.5/IMAX} VAF=100 IKF={.7*IMAX} + IS={2E-15*MAX} ) This subcircuit-based macro model makes use of the default model parameters so that it is not permissible to change default values without reevaluating the parameters which are given here. |
This page has been seen 3,219 times.
Created by onLast updated by on
