Scalable PSU/Regulator GB
11/12/06 - out of boards. register your interest for a potential buy of boards/kits here. Kit will include board/parts and 1" or 1.5" heat sink.
DIY User Name | PSU Boards | PSU kits |
Total | 0 | 0 |
10/04 I have some extra boards. I will have kits available again shortly, when I receive more 1500 uf caps.
To simplify my record keeping and try to improve accuracy, I've set up a
PayPal shopping cart for purchase of boards and kits. You can use a credit card even if you have no
PayPal account. If you don't have a credit card, email me to make arrangements.
Go to
https://mysite.verizon.net/vze3xvxs/audio/id19.html click on "Purchase Boards and Parts". Click on the "add to cart" buttons as desired. You can increase the quantities in the cart.
Be sure to select a shipping option. In the US, most orders will fit in the Priority Mail envelope (up to 4 PSU kits). Outside the US, I can fit 10 boards or 6 boards and a power supply kit into a small GPM envelope. Small quantities of 100 nf will fit as well. If you have more than one PSU kit, you'll need the large envelope for up to 4 psu kits. If in doubt, email me and I'll figure out shipping cost.
Pricing:
Filter Boards $5
PSU Boards $6.25
PSU Kit $28 (includes board, parts and heat sinks)
I also will offer 470 uF Panasonic FCs for the filter boards (2 required per), 100 nF/100V Epcos Film caps for decoupling, 1500 uF 35V Panasonic FCs and BC546C/BC556C.
I still have plenty of BC546C and BC556C.
The parts kit contains:
Resistors:
10 ea. 1K (natural tape)
4 ea. 10K (purple tape)
2 ea 2K (yellow tape)
2 ea 100R (red tape)
2 ea 22K (bulk - no tape)
4 ea 3.3K (green tape)
Semiconductors:
1 ea. MJE15032
1 ea. MJE15033
12 ea. 1N4007
2 ea. LM4040-10 (loose TO-92)
3 ea. BC546C (plain tape TO-92)
3 ea. BC556C (black tape TO-92)
2 ea. Green LED
Capacitors
8 ea. 1 uF (larger blue)
12 ea. 100 nF (small blue)
2 ea. 100 pF (red)
4 ea. 470 uF/25 V
4 ea 1500 uF/35V
Misc.
4 ea 2 position screw terminal
Status 4/18
I ordered enough PSU and filter boards and parts to cover all confirmed orders, plus a few spares. There are a few unpaid confirmed orders. Boards not paid for by April 24will be available.
All PSU kit parts have been ordered.
Between the time we ran the prototypes and now, Mouser decided that they didn't want to sell the chosen transistors in small quantities. There are alternatives, but they are lower voltage devices which will not have as broad uses. So, in 10 days be the proud owner of 10,000 BC546C and 10,000 BC556C from Fairchild (minus the 500 or so of each for the group buy)
So if your project calls for a TO-92 transistor and would benefit from higher gain and lower noise than the usual suspects drop me a line. These are suitable for the Leach amp front end, for example. Just watch the pin out - it is reversed from MPSA types so it goes in the opposite of the silkscreen.
These wonderful devices can be yours. $5.00 for 50 $10 for 150 plus postage. I'll split that between the types if you'd like. Higher quantities mean lower prices. Makes great stocking stuffers for your audiophile friends!
POWER SUPPLY
Discrete rectification and regulation, positive and negative supplies on one 80x100mm board. Voltage selectable by changing resistors or voltage reference. Not a "Super-Regulator" but stable, quiet power.
Discussion (
https://www.diyaudio.com/forums/showthread.php?s=&threadid=75994)
Status 4/6
Jens did some testing today in the current configuration (just capacitive input filter) and the regulator works well with just 15V input.
The group buy transformers are back to 15V.
Also there were a couple of minor changes to the layout that I will post later. They were:
Added two film capacitors to the output. (they had been dropped initially when Jens made room for the bigger output caps.)
Rotated the input and output terminals 90 degrees to allow easier access.
For ordering, please send email to robert (dot) e (dot) ellis ( at ) Verizon (dot) net with the subject line "Group Buy"
including your:
DiyAudio
?? Name
Real Name
Shipping address
telephone number (USPS wants this for international shipments)
- Number of Filter boards @ $5
- Number of PSU boards @ $5
- Number of PSU parts kits @ $20.25
- Number of Heat sink pairs @ $1.80 (if you are buying OPAs from gengis he can combine with that order)
- Number of Tranformers (Price tbd, $16.50 or less)
- Number of extra Panasonic FC 470 uf 25V 10 mm od x 5 mm lead spacing. Order in increments of 10 pieces, please.
- Number of extra Epcos MKT 100 nf 63V 2.5 mm x 7.5 mm x 5 mm lead spacing. Order in increments of 10 pieces, please.
New April 4
470 uf Panasonic FC 10mm OD x 5 mm lead spacing 10 /$2.50
100 nf Epcos MKT 2.5 mm x 5 mm x 5 mm lead spacing 10/$1.00
Contact me with your requirement.
Board price $5
Shipping will be USPS priority mail/ Global Priority Mail. Check to see if your country accepts global priority mail. So far I think this only affects the member in Greece. We'll discuss shipping in private.
Parts kit will include all parts (resistors, capacitors, semiconductors and terminals) needed for +/-15V. The parts kit does not include transformers or heat sinks.
- (change 4/4) Parts kit pricing is $20.25. Includes all parts in Jens' BOM except heat sinks and Trim pots. Electrolytics will be Panasonic FC. For trimpots you are on your own, due to the underwhelming interest shown. Two extra 2K resistors will be included in the kit to give nominal +/-15V without trim pots.
Just for reference, I ordered enough parts to build a prototype, and the total was $34, plus shipping from digkey and mouser. I didn't expect much savings from a group buy, but it turns out you save a few bucks.
Heat sink pricing is $1.80/pair for a 2" high heat sink 7.4 C/W (I'd originally proposed 1.5") Gengis has a boatload. If you are buying OPA2134's he'll ship them in that package. If you not in on the OPA buy, I will buy them from gengis and ship them with your kits. Just sign up here, Gengis and I will coordinate. If you want heat sinks for other projects, you can get them here or by contacting Gengis through the board.
Just to be clear, a pair is enough heatsinks for ONE regulator board. I don't want anyone thinking that I didn't ship what I promised due to language issues.
Avel Lindberg transformer
Y23 series (all hardware included) - dual 15 VAC 50 VA, dual primaries.
$16.50 each at 50, $13 at 100 pieces. 1.5# shipping weight each. USPS Priority mail <$11 in US.
Yes, it is overkill. It will handle 8 fully loaded active filter boards at half of rated capacity, but for $.75 more than the 30 VA version, why not?
DIY User Name | Heat sink pairs | Filter boards | PSU Boards | PSU Parts kits | Dual 15V 50 VA Transformers | Panasonic FC 470 uf/ 25V | EPCOS MKT 100 nf/63V | LM4040 | Panasonic FC 1200 uf/ 35V | BC546C and/or BC556C | paid? | shipped? | received? |
agent.5 | 6 | 4 | 6 | 1 | 2 | _ | _ | _ | _ | _ | Y | Y |
Andrewt | 0 | _ | 8 | 0 | _ | _ | _ | 20 | _ | 200 | Y | Y | Y 5/23 |
AndyB?? | 2 | _ | 8 | 2 | _ | _ | _ | _ | _ | 450 | Y | Y | Y |
argofanatic | _ | _ | 20 | 15 | _ | _ | _ | _ | _ | _ | Y | Y | Y 5/31 |
AudioLimit? | 1 | 4 | 2 | 1 | 1 | _ | _ | _ | _ | _ | Y | Y |
beaver | 4 | _ | 4 | 2 | _ | _ | _ | _ | _ | _ | Y | Y |
BFNY | _ | _ | 12 | _ | _ | _ | _ | _ | _ | 150 | Y | Y |
BillC? | 4 | _ | 12 | _ | _ | _ | 20 | _ | _ | _ | Y | Y |
BillH?? | _ | 4 | _ | _ | _ | _ | _ | _ | _ | _ | Y | Y |
bkin240 | 0 | 10 | 4 | 4 | 1 | 30 | 100 | _ | _ | _ | Y | Y |
BlackDuck? | _ | _ | 1 | 1 | _ | _ | _ | _ | _ | _ | Y | Y | Y 25/5 |
Blunderman | _ | 4 | _ | _ | _ | 8 | 50 | _ | _ | _ | Y | Y |
Bob Quick | _ | 6 | 1 | _ | _ | _ | _ | _ | _ | _ | Y | Y |
BobEllis | 25 | _ | 20 | 20 | 10 | 0 | 0 | _ | _ | 1000 | Y | Y | Y |
bobgroger | _ | 6 | 2 | 1 | 1 | _ | _ | _ | _ | _ | Y | Y | Y |
Brian Walter | _ | 4 | _ | _ | _ | 10 | 100 | _ | _ | _ | Y | Y |
Calimero | 5 | _ | 6 | _ | _ | _ | _ | _ | _ | _ | Y | Y |
cambe | 2 | _ | 2 | 2 | 1 | 10 | 40 | _ | _ | _ | Y | Y |
cbcassell | _ | _ | 6 | 6 | 4 | 50 | 100 | _ | _ | _ | Y | Y | Y |
Cobra2 | _ | 4 | 12 | 2 | _ | 20 | 200 | 24 | 24 | _ | Y | Y | y |
colwaiting | _ | _ | 4 | _ | _ | _ | _ | _ | _ | _ | _ | Y | - |
cotdt | _ | _ | 2 | 2 | 2 | _ | _ | _ | _ | _ | _ | Y |
curva | _ | _ | 6 | _ | _ | _ | _ | _ | _ | _ | Y | Y |
dabodkin | 0 | _ | 5 | _ | _ | _ | _ | _ | _ | 100 | Y | Y | Y |
DavidS?? | 18 | 6 | 6 | 6 | 6 | 16 | 120 | _ | _ | _ | Y | Y |
DewardH? | _ | 4 | _ | _ | _ | 16 | 250 | _ | _ | _ | Y | Y |
DFDye | _ | 4 | 1 | 1 | 0 | _ | _ | _ | _ | 150 | Y | Y | Y 5/19 |
dick van nierop | _ | _ | 2 | 2 | _ | _ | _ | _ | _ | _ | Y | Y |
donas | 0 | 6 | 3 | 2 | _ | 20 | 200 | _ | _ | _ | Y | Y |
EdwardWest? | 2 | _ | 2 | 2 | 2 | _ | _ | _ | _ | _ | Y | Y | Y 5/21 |
erhana | _ | 6 | _ | _ | _ | _ | _ | _ | _ | _ | Y | Y | Y 5/29 |
gengis | _ | _ | 24 | 8 | 6 | _ | _ | 32 | _ | 400 | Y | Y | |
gmikol | _ | 8 | _ | _ | _ | _ | _ | _ | _ | _ | Y | Y | Y 5/20 |
gozierdt | 4 | _ | 4 | 2 | 1 | 50 | 50 | _ | _ | _ | Y | Y |
gugi 100 | _ | 4 | 6 | 4 | _ | 10 | 25 | _ | _ | _ | Y | Y | Y 5/25 |
Hans L | _ | 10 | 2 | 2 | _ | 30 | 100 | _ | 20 | _ | Y | Y | Y |
herm | 4 | _ | 4 | 4 | 2 | _ | _ | _ | _ | _ | Y | Y |
HMenke | _ | 2 | _ | _ | _ | _ | _ | _ | _ | _ | Y | Y |
illusionxx | _ | 9 | _ | _ | _ | _ | _ | _ | _ | _ | Y | Y |
jacco vermeulen | 0 | _ | 10 | 2 | _ | _ | _ | 10 | _ | 500 | Y | Y | Y 5/30 |
jackh | _ | 4 | _ | _ | _ | _ | _ | _ | _ | _ | Y | Y |
JamesM?? | _ | 8 | 4 | _ | _ | _ | _ | _ | _ | _ | Y | Y |
Jarno | 0 | _ | 4 | 2 | 0 | _ | _ | _ | _ | _ | Y | Y |
jb74 | _ | _ | 10 | _ | _ | _ | _ | 20 | _ | _ | Y | Y |
Jbkodo | _ | _ | 6 | 2 | 2 | 20 | 230 | 4 | 8 | 50 | Y | Y |
JensRasmussen?? | 10 | _ | 20 | _ | _ | 40 | _ | 40 | 20 | 2000 | Y | 2 OF 2 |
jerishi | _ | 4 | 2 | 2 | 1 | 20 | 50 | _ | _ | _ | Y | Y |
jguyer | 2 | 4 | 2 | 2 | 2 | 10 | 40 | _ | _ | _ | Y | Y |
Joe Cole | _ | 2 | 2 | 2 | 2 | _ | _ | _ | _ | _ | Y | Y |
JoeyDD?? | _ | 3 | 4 | _ | _ | _ | _ | _ | _ | _ | Y | Y | Y 5/25 |
JohnL?? | 0 | _ | 1 | 1 | 1 | 10 | 100 | _ | _ | _ | Y | Y |
joster | 0 | _ | 10 | 2 | 2 | _ | _ | _ | _ | _ | Y | Y |
Jsprague | _ | _ | 2 | 2 | 2 | 20 | 50 | _ | _ | _ | Y | Y |
Kendle | _ | _ | 4 | 2 | _ | _ | _ | _ | _ | _ | Y | Y |
kestrel200 | 1 | _ | 1 | 1 | 1 | 10 | 80 | _ | _ | _ | Y | Y |
kimo692 | 1 | 4 | 1 | 1 | 1 | 10 | 100 | _ | _ | _ | Y | Y |
kro5998 | 0 | _ | 3 | 1 | _ | _ | _ | _ | _ | _ | Y | Y | Y 5/24 |
LuckyLyndy | _ | 4 | 2 | 0 | 0 | 0 | 0 | _ | _ | _ | Y | Y |
Methman | _ | 10 | 4 | _ | _ | _ | _ | _ | _ | _ | Y | Y | Y 5/23 |
nek0zuki | 4 | 6 | 4 | 2 | 2 | 14 | 120 | _ | _ | _ | Y | Y |
nigeljking | _ | 4 | _ | _ | _ | _ | _ | _ | _ | _ | Y | Y |
nilsomat | 2 | 2 | 2 | 1 | 0 | _ | _ | _ | _ | _ | Y | Y |
Nisbeth | _ | _ | 8 | _ | _ | _ | _ | _ | _ | _ | Y | Y |
opp | 2 | _ | 6 | 4 | _ | 10 | 50 | _ | _ | _ | Y | Y |
P-A | _ | _ | _ | _ | _ | _ | _ | _ | _ | 1000 | Y | Y |
Paul Fargotstein | _ | 4 | 2 | _ | _ | _ | _ | _ | _ | _ | Y | Y |
Phoneisbusy | _ | _ | 3 | 1 | _ | 10 | 60 | _ | _ | _ | Y | Y |
pixelpusher | 1 | 2 | 1 | 1 | 1 | 8 | 40 | _ | _ | _ | Y | Y | Y |
pool | _ | _ | 6 | _ | _ | _ | _ | _ | _ | _ | Y | P |
quickshift | _ | 4 | 2 | 2 | _ | _ | _ | _ | _ | _ | Y | Y |
RandyB? | _ | 6 | 3 | 2 | _ | 10 | 110 | _ | _ | _ | Y | Y | Y |
rick57 | 4 | 8 | 4 | 4 | 2 | 25 | 180 | _ | _ | _ | Y | Y |
rjb | 1 | _ | 2 | 1 | _ | 10 | 100 | _ | _ | _ | Y | Y | Y |
rjkdivin | 4 | _ | 8 | 4 | 2 | 40 | 40 | _ | _ | _ | Y | Y |
RogerGustavsson? | _ | 4 | _ | _ | _ | _ | _ | _ | _ | _ | Y | Y |
RuudvdL?? | 2 | 8 | 2 | 2 | _ | _ | _ | _ | _ | _ | Y | Y |
Saam | _ | 6 | 2 | _ | _ | 12 | 50 | _ | _ | _ | Y | Y | Y |
sandro600 | _ | _ | _ | _ | _ | _ | _ | _ | _ | 1000 | Y | Y |
SanjeevA?? | _ | 4 | 1 | 1 | _ | _ | _ | _ | _ | _ | Y | Y |
sklimek | _ | _ | 6 | _ | _ | 50 | 100 | _ | _ | 50 | Y | Y | Y |
skseah | _ | _ | 4 | _ | _ | _ | _ | 10 | _ | _ | Y | Y | Y |
soltari_knight | 2 | 4 | 4 | 1 | _ | _ | _ | _ | _ | _ | Y | Y | Y |
steenoe | _ | _ | 12 | _ | _ | _ | _ | _ | _ | 200 | Y | Y |
Sunde | _ | _ | _ | _ | _ | _ | _ | _ | _ | 400 | Y | Y |
SvErD?? | 0 | _ | 8 | 2 | 3 | 40 | 100 | _ | _ | 150 | Y | 2 OF 2 | 2 of 2 |
t. | _ | _ | 3 | _ | _ | 20 | 30 | 8 | 20 | _ | Y | Y |
t3447ml | _ | _ | 2 | 2 | _ | 20 | 120 | _ | _ | _ | Y | Y |
tg3 | _ | _ | 6 | 4 | 2 | 20 | 300 | _ | _ | _ | Y | Y |
The Peasant | 2 | 6 | 2 | 2 | _ | _ | _ | _ | _ | _ | Y | Y |
UrSv?? | _ | 4 | 4 | _ | _ | _ | _ | _ | _ | _ | Y | Y |
variac | _ | _ | 2 | _ | _ | _ | _ | _ | _ | _ | Y | Y |
vgeorge | 0 | _ | 2 | 2 | 0 | 8 | 72 | _ | _ | _ | Y | Y |
vladco | _ | _ | 10 | 1 | _ | 50 | _ | _ | _ | _ | Y | Y | yes |
WJH | 1 | 2 | 1 | 1 | 1 | _ | _ | _ | _ | _ | Y | Y |
Yoke | 2 | 4 | 4 | 2 | _ | _ | _ | _ | _ | _ | Y | |
Zei | _ | 2 | 1 | 1 | 1 | 4 | 30 | _ | _ | _ | Y | Y |
ZUM911 | _ | 2 | 2 | _ | _ | _ | _ | _ | _ | _ | Y | Y |
_ | 118 | 232 | 419 | 158 | 67 | 761 | 3507 | 148 | 92 | 7600 | _ | |
