Introduction
This is the (preliminairy) January 2005 Dutch Aleph-X Parts Group Purchase WIKI.
>>>THIS WIKI IS FAR FROM COMPLETE, PLEASE AMEND, CORRECT AND COMPLETE!!!<<<
The original thread that spawned this WIKI page can be found here:
https://www.diyaudio.com/forums/showthread.php?s=&threadid=47145&perpage=10&pagenumber=1
The aim of this WIKI-page is to inventory the demands for parts group purchases for DIY-projects of building Aleph-X's and similar power amps.
Although the name might suggest otherwise, this GP is open for all other audio DIY enthousiasts!
Note:
I (Byteboy) will
not be organising any of these group purchases, I only volunteerd to set up the basic WIKI and maintain it for some time!!
Parts (Preliminairy)
At this moment a number of demands for parts have been identified:
1. Heatsinks
2. Power Transformers
3. Power Supply Caps
4. (Matched-)Power MOSFETs
5. (Matched-)IRF9610
6. Power Resistors
1. Heatsinks
- At this moment it seems not feasable to order from a supplier outside of Europe (The Netherlands?) because of the high shipping cost due to the high weight and big size of the heatsinks??
- Preliminairy Specs
Preliminary specs | Heatsinks |
Type | _____ |
Construction | Aluminium, Extruded, Black anodisised, Vertical Fins |
Part Number | 1234567QRS |
Brand/Manufacturer | __ |
Suplier | __ |
Price | __ |
Weight | __ |
Dimensions |
Fin Height | ___mm. |
(Horizontal) Width | ___mm. |
(Vertical) Lenght | ___mm. |
Baseplate Thickness | ___mm. |
Thermal Resistance | ____°K/W |
t.b.s.
2. Power Transformers (Preliminairy)
- I have been busy for some time searching for transformers for myself. I took the liberty of filling in this section myself to give an idea of what I think is how this WIKI should be filled.
- From the posts in the thread I gather that there will be DIY-projects dealing with high- and with low power AlephX?'s (and alikes) and thus requiring different transformer power ratings. I suggest there will be two basic types of transformers to accomodate both?
- Here is what I had spec'ed for myself so far:
Preliminary specs | Power Transformer Aleph-X |
Type | Torodial transformer, Type XYZ |
Part Number | 1234567XYZ |
Supplier | __ |
Price | __ |
Mounting | Semi-potted, central mounting hole, M6 * 60 mm. |
Weight | __ |
Dimensions | |
Core cross section | __ * __ mm. ____mm² |
Height | ___mm. |
Diameter | ___mm. |
Power rating I | abt. 320-480 VA for "standard" Aleph-X |
Power rating II | abt. 720-1000 VA for "High Power" Aleph-X |
Regulation | max. 6 % |
Screen | Static screen between primairy an secondary windings |
Magnetic Shielding?? | ?? µ-Metal?? |
Thermal Cutout | at __°C |
Primary voltages | 2 * 120 Volts / 50/60 Hz |
Secondairy Voltages | 2 * 16 ~ 24 Volts |
Secondairy Currents I | 2 * 10 Ampere |
Secondairy Currents II | 2 * 20 Ampere |
Ri I | ___mOhm |
Ri II | ___mOhm |
Wire Diameter Primairy Windings I | ___mm. |
Wire Diameter Secondairy Windings II | ___mm. |
Wire Leghts | ___mm. |
- Preliminary Specs for Power Supply Caps
Preliminary specs | Power Supply Caps |
Type | Aluminium Electrolytic, Computer grade |
Part Number | 123456ABC |
Supplier | __ |
Price | __ |
Operating Temperature Range | ~ - 30 to +105°C |
Mounting | Stud mount, ~ M8 X 15 mm. |
Electrical Connections | Screw contacts ~ M5 X 10 mm. |
Capacity | 10,000 - 22,000 µF |
Working Voltage | 63 Volts |
ESR | ___mOhm |
ESL | ___µH |
Dimensions | ~ 50 * 100 mm. |
IRFP044N ??
IRFP240 ??
t.b.s.
6. Power Resistors
Inventory (Preliminairy)
Please enter your particular interests in the different parts in the table below.
From this information we can see if a GP is feasable for a particular part.
Remember this is only to inventory the different demands for parts,
no obligations yet.
Inventory of demands for parts per participant of GP
User | Country | Heatsinks | TrafoI | TrafoII | PwrCs | MOSFET | IRF9610 | Pwr Res |
Byteboy | Netherlands | None | 4 | 2 | abt. 64* | None | abt. 50 | 80 |
Jaac | Netherlands | __ | __ | __ | __ | __ | __ | __ |
illusionxx | Germany | __ | __ | __ | 24 | 24 | 10 | __ |
jacco vermeulen | Netherlands | __ | __ | __ | __ | 100 | 50 | 100 |
MEnsing | Netherlands | __ | __ | __ | __ | 50 | 20 | __ |
Creatre | Sweden | __ | __ | __ | 12 | 50 | 20 | 10 |
Ruben | Switzerland | 4 | 4 | __ | __ | 50 | 20 | __ |
Fepie | Italy | 4 | 2 | __ | 20 | 30 | 50 | 100 |
__ | __ | __ | __ | __ | __ | __ | __ | __ |
Totals | __ | 4 - 8 | 8 | 2 | 100 | 304 | 180 | 190 |
- Assumed caps are 22000µF/63Volts
