Status: It's on hold, the interest is too little
Background
The super regulator as it was presented had limited data because of the design but nothing says that it can be done for any voltage and any current but if the requirements are more than 36 volts out and 1.5 A (1 A in real life) a redesign is necessary. There are a half dozen of available pcb's out there. The latest one comes from Taiwan but this one and noone else is rather well suited for higher power.
[The original thread]
Technical specifications and features
So far I have written down some interesting features, please suggest more.
[Technical specifications]
Details and Instructions
In the table below you may write down a possible need for a high power super regulator and how you want to look like.
In the table below you may write down a possible need for a high power super regulator and how you want it to look like.
One line per type of request please.
The list
JUST INTEREST, NO COMMITMENTS AT THIS POINT.
Wanted Features List(only interest, no commitments)
user | Country | Max current | Min-Max out voltage | Min-Max in voltage | Neg Pos out voltage | Amount | Application | Remark |
peranders | Sweden | 8 | 20-50 | 20-100 | Pos | 1 | Power amp | - |
rjkdivin | USA | 8 | 24-90 | 24-120 | Pos&Neg | 2 | Power Amp | - |
flodstroem | Norway | 3 | 15-24 | 20-35 | Pos&Neg | 2 | Pre-amp | (Class-A) |
Bowdown | Australia | 8-10 | 15-100 | 15-120 | pos&neg | 4+ | Poweramp/preamp | - |
soltari_knight | USA | 5 | 15-100 | 15-110 | Pos&Neg | 5 | Audio | - |
rolandong | Philippines | 8 | 15-105 | 0-130 | Pos&Neg | ? | super leach frontend | - |
Loboone | New Zealand | 8-10 | 45-80 | 50-100 | Neg-Pos | 2 | power amp | For Leach 6 |
Novec | Norway | 8-10 | 50-70 | 50-100 | Pos & neg | 2 | Power amp | - |
JensRasmussen? | Denmark | 20 | 0-100 | 50-120 | Pos & neg | 10 | Bench supply | Constant current limiter, Constant power limiter |
Jacco Vermeulen | Netherlands | 8 | ?-100 | ?-130 | Pos & Neg | 4+ | poweramp |
gengis | US | 20 | 0-100 | ?-120 | pos & neg | 4+ | power amp. + bench |
JimmyB | UK | 8-10 | 20-100 | ?-120 | pos & neg | 4+ | Power amp | Naim/Avondale |
BrianUK? | UK | 8-10 | 20-50 | ?-70 | pos & neg | 4+ | Power amp | Naim/Avondale |
masag | Germany | 2 | 20-80 | 20-80 | Neg Pos out voltage | 4 | poweramp | Remark |
log51 | USA | 12 | 20-80 | 22-100 | Neg Pos | 4+ | Amp | solid state |
log51 | USA | 3 | 200-600 | 220-650 | Pos Pos | 4+ | Amp | tube |
ackcheng | HK | 4.5 | 50-200 | 70-250 | Pos Pos | 10+ | Amp | tube |
Z33 | USA | 3 | 35-70 | 50-100 | pos & neg | 2+ | Amp | solid state |
VILLAW | CY | 15-20 | 35-70 | 50-100 | pos & neg | 2+ | Amp | solid state |
AndrewT? | UK | 1-2 | 35-83 | 40-90 | pos & neg | 4+ | Volt Amp stage | protected pre reg |
fredlock | USA | 8 | 20-80 | 20-120 | pos & neg | 4 | Power Amp |
| Total | . | . | . | . | 64+ | . | . |
Per-Anders Sj�str�m aka peranders
