CLOSED
Info Section
Copyright Nelson Pass
He takes all the credit if you like the circuit - and I must agree with him it sounds terrific. ;)
The GB has been approved by Nelson Pass.
I have made a little guide, to keep useful info one place:
https://viller.eu/audio/2009jan_gbf5/gbf5_guide.pdf
I'll update it if someone thinks it needs additional sections/info/trick descriptions.
Ordering Info
Prices are:
Two F5 boards for one stereo set : $15 or 11euro
One PSU board for stereo set: $15 or 11euro
Postage: $10 or 7.5euro
Please use my site for ordering:
https://viller.eu/gb/
F5 Boards
The board is 10x5 cm and the mosfets are placed 8 cm apart.
https://www.diyaudio.com/forums/showthread.php?postid=1687317#post1687317
PSU Boards
These boards will be 18x8 cm and capable of holding 35mm diameter snap-ins.
https://www.diyaudio.com/forums/showthread.php?postid=1687351#post1687351
Got a question about components for the PSU (Post #104)
The layout I have made here is for the standard firstwatt style psu. So you'll need:
Onboard:
8 x snap in caps (at least 25V and 15mF more is better)
8 x 0.47 ohm 3W resistors
2 x 2.2k 3W resistors (for discharging caps)
Off board / somewhere else:
2 diode bridges mounted somewhere on the chassis
1 toroid 2x18 300VA
1-2 thermistors for soft starting the toroid
switches, connectors, fuses and all that stuff
This will be enough for a stereo amp or a monoblock, but remember diy people always want to go over the top.
PCB Process
Layers | Two layers |
Copper | 70um |
Color | Blue |
