diyAudio logo
Class D Amplification
Frequently Asked Questions about Tripath-based amplifiers
What Tripath-based amplifiers are available?
[41Hz]
[Autocostruire]
[Sure Electronics]
[DIY Paradise]
[KingRex]
[Silverstone]
[Sonic Impact Technologies]
[Trends Audio]
[Virtue Audio]
[Winsome Labs]
What amp is going to suit my needs best?
Where can I get it?
How much is it?
How do I assemble it without killing it, the rest of my gear, and myself?
Can the amps be bridged for more power?
How much power does the amp put out?
What size power supply do I need?
Can I run the amp on battery power, e.g. SLA? What size SLA?
Why does my Sonic Impact lack bass?
Is this a digital amp? Can it be connected directly to a digital signal?
How do I remove the case of the Sonic Impact?
Which input cap is best? What size cap do I need?
Do I really need an input cap?
Do they really sound that good?
What are the specifications of the Tripath based amplifiers?
AmplifierChipTHD+N/Power/LoadTHD+N/Power/LoadOutputsBridgeableSupply Voltage (Range)
AMP1*TA20220.1%/2x90W/4ohm0.1%/2x60W/8ohm2 Single EndedYes+/-31V (+/-12V to +/-36V)
AMP2*TK23500.1%/2x190W/4ohm0.1%/2x100W/8ohm2 Single EndedYes+/-45V (+/-15V to +/-65V)
AMP3*TA2021B0.1%/2x15.5W/4ohm0.1%/2x9W/8ohm2 BridgedNo14.2V (8.5V to 14.6V)
AMP4*TK20501%/2x35W/6ohm0.01%/2x35W/8ohm2 BridgedNo**30V (10V to 36V)
AMP5*TA20220.1%/2x90W/4ohm0.1%/2x60W/8ohm2 Single EndedYes+/-31V (+/-12V to +/-36V)
AMP6*TA20200.1%/2x11W/4ohm0.1%/2x7W/8ohm2 BridgedNo13.5V (8.5V to 14.6V)
Class-t-amp-2020-m*TA20200.1%/2x11W/4ohm0.1%/2x7W/8ohm2 BridgedNo13.5V (8.5V to 14.6V)
Fenice20TA20240.1%/2x11W/4ohm0.1%/2x6W/8ohm2 BridgedNo12V (8.5V to 13.2V)
CharlizeTA20200.1%/2x11W/4ohm0.1%/2x7W/8ohm2 BridgedNo13.5V (8.5V to 14.6V)
Michael Mardis TA-10.1TA20240.1%/2x11W/4ohm0.1%/2x6W/8ohm2 BridgedNo12V (8.5V to 13.2V)
SI 5066 T-AmpTA20240.1%/2x11W/ohm0.1%/2x6W/8ohm2 BridgedNo12V (8.5V to 13.2V)
SI 5062 Super T-AmpTA20240.1%/2x11W/4ohm0.1%/2x6W/8ohm2 BridgedNo12V (8.5V to 13.2V)
Trends Audio-10.1TA20240.1%/2x11W/4ohm0.1%/2x6W/8ohm2 BridgedNo12V (8.5V to 13.2V)
Virtue ONE2 x TP20510.01%/2x100W/4ohm0.01%/2x50W/8ohm2 BridgedNo30V
Virtue TWO2 x DDX22000.01%/2x100W/4ohm0.01%/2x50W/8ohm2 BridgedNo30V
Winsome Mouse2 x TP20500.01%/2x45W/4ohm0.01%/2x33W/8ohm2 BridgedNo30V SMPS included
Note 1: THD+N/Power/Load and Supply Voltage specifications were taken from the Tripath data sheets for the respective chip.
Note 2: * These amplifiers are kits that must be assembled (soldering skills are required).
Note 3: ** Depending on the implementation, AMP4's bridged outputs can be paralleled to drive a 4-ohm load.
What type of power supplies work well with Tripath Amps?
What default power connector size is used for the SI 5066 T-Amp?
What is the difference between Single-Ended and Bridged?
Why does the Tripath website not recommend the TA2020?
Will these low-power amps be able to drive my XXXX speakers with 8X-dB sensitivity?
Which amplifiers require break in?
Charlize Specific
General Information
What are the dimensions of the Charlize?
What is the gain for the Charlize Amplifier?
How do I remove the start-up "pop" when turning on the Charlize?
When I turn up the volume, the sound drops out then comes back on? What gives?
Modifications
Air Core Inductors
Input Capacitors
Sources
Recommendations by 32bit user
A list of recommended modification parts, brief explanation of the expected "improvement", and some suggested sources (with part numbers, typical pricing, web addresses, and/or phone numbers). Perhaps the sources could be broken down by major geographic location. And, of course, the parts would be broken down by specific item being modded.
More power from your TA2020 series, by Alastair E
It is possible to parallel the outputs of a TA2020 and its bridged O/P S.M. friends, but careful attention must be paid to the output voltage offset of each channel. A simple dual-opamp servo-circuit was documented by Tripath some years ago, when the TA2020 first came out. It was envisaged that a bridged-output TA2020 would be used for subwoofer duties at impedances less than 2.5 ohms. In this configuration an output power of 50W was possible.
Through many experiments with the TA2020, it was found that it will quite happily drive a 2-ohm load without resorting to parallelling its outputs, provided that O/P voltage overshoot was taken into consideration. Output overshoot above the supply rails can otherwise destroy the device. Most recent production boards contain the extra diodes needed to protect the TA2020 and its friends, but care must be taken to check older evaluation boards such as the TA2020-EB.
Extra decoupling caps of 470uF-1000uF, mounted directly across the power supply pins at the chip, are also recommended. Low-ESR types should be used.
It is worth mentioning that at these low impedances and high-output power a heatsink is a good idea.
