8K series CASE Features :
I found a kind of case solution.Stainless steel,is commonly called as "8K".let processing factory produce the machine cases of demand size.
For more informations,Please see this thread:
https://www.diyaudio.com/forums/showthread.php?s=&threadid=31953
To be created later,I need know that there is enough interest for an order.I posted some preliminary prices in the above referenced thread.
I think,the small case will relatively worthwhile to action,limit the volume and weight of case. For example do two different versions.
C1 devices:
The case size is 20cm 20cm 7.5cm,The thickness of the board is 1.2mm.Can be used for making all in one power amp or psu module.
My 200W transformers size is 10cm 10cm 7cm,the case can fit a couple of it.for more C1 detail,please see this post:
https://www.diyaudio.com/forums/showthread.php?postid=371046#post371046
C2 devices:
small one,it's size is 170(W)x40(H)x100(D)(mm).the board is 0.6mm,no holes.
just like 47lab's amp module,you can use it for mini amp or a pre-line stage.
C3 devices:
8K series C3,the size is 250X250X95,the board is 1.2mm,no holes.I think that is the max size case I can offered,the more bigger case will be very inconvenient to shipping transport.
additions:
The case of other sizes is easy to make.I can offer the case of the special requirement,but will not turn on holes.
I delimit a standard case for easy to shipping and easy to make:
1, the size is relative small.
2, can be in common use.
shipping:
The postal price of reference of China
https://www.chinapost.gov.cn/yyzn/zifei/guoji/gjkybgzf.htm (unit:RMB YUAN)
Order list :
# | Name | # of cases | Location | Device | Comments | price(USD) |
1 | digi01 | 2 | CHINA | C1 | for myself IGC use | 120 |
2 | uvodee | 2 | USA | C1 | | 120+60 |
3 | idex | 2 | USA | C1 | | 120+60 |
4 | jhead | 2 | USA | C1 | IEC,RCA,Venting holes | 120+60 |
5 | lgreen | 2 | USA | C1,C3 | IEC,RCA,XLR, vents, please post more pics of component case parts with good lighting! | 150+60? |
I add the price in upper forms,these case in course of making,please give me a mail to get payment circumstances.
