Hi guys,
does anyone know if there is a service manual available somewhere for the Myryad MA500?
I want to recap mine (23+ years old and it runs a bit warm). During dismantling I discovered that no bleed resistors are built in: the psu pcb shifted a bit and the filter caps discharged unplanned and uncontrolled on it's own mounting bracket. Optically, there's no damage other than a black spot on the pcb. But I can't test the unit at the moment. During the recap, I might as well replace any and all components around the fried spot on the pcb. Including some diodes I know nothing about, except a voltage rating of 22V (D609, D610). So a service manual might come in handy to identify risk-areas and components.
Thanks in advance!
James.
Thanks in advance!
James.
