So these reside in an Acoustat Servo Charge OTL. On standby, the filaments are lit up as normally, slight glow. I'm seeing tiny specs of white light poking through the mica support at the top. They are bright but very tiny. I have 3 other amps just like it in the same system. It's only happening in one. Does anyone know what this is? TIA
Any idea what the plate voltage is? Just curious, as I have a similar tube (6JM6) in my DCPP amp. I'm going to fire it up tonight with the lights out.I'm seeing tiny specs of white light poking through the mica support at the top. They are bright but very tiny.
jeff
There are no LEDs or other light sources. It's definitely coming through the mica support inside the tube.
Umm, on second thought, when I close the front door they disappear. It's the light coming through the front door of the house reflecting on the tubes. Sorry folks!
Thanks Osvaldo
Thanks Osvaldo
Safely first.It's difficult to capture through the cage but I cant' turn on the amp without the cage installed.
jeff
It appeared the light was coming through small holes in the mica but alas, the convex shape of the glass reduces the reflected image's size. The interesting thing is they appear on four corners simultaneously.
I should point out it is my WIFE who pointed this out to me. She was afraid the amp will blow up and burn the house down.![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Are you sure that tubes glass isn't reflecting lights from a pilot lamp or led?
Tell her the fuses will blow before it catches fire.I should point out it is my WIFE who pointed this out to me. She was afraid the amp will blow up and burn the house down.
jeff
- Tubes / Valves
- Secondary light emanating through the top support in 6HB5?
