| Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs |
#21 |
Thanks for the info provided I was well aware of the old Altec, Ev's and others having been involved in designing single driver fullrange systems for the last 45 years. The X max of 1.5 mm is not bad and certainly will do for fairly loud listening.
Attached is a design for a 8" fullrange driver to provide a cabinet of 80+ liters which can easily be adjusted to suit the driver and to take care of baffle step issues with out electronics, having build such a cabinet with a 6-1/2" driver, baffle size beeing 15" x 57" with a 2-1/4" at the sides and top of cabinet about 10 years ago and still listening to them maybe it is time to build an 8" the only one size I have not build yet. I am wondering whether the BetsyK is available without the whizzer and dustcap. |
#22 |
well done Paul this is real small gem !
I know is hard ,not all can understand what is a FR in OB.... this can wonderfull small system with 2w set amp like 45/46 or 10y ...as 95db rulez! or Pass F1/F2
Sic58
#23 |
You bring up a great point. I often have folks asking me about sensitivity and hoping to use a really small amp with the Betsy. I always advise that I use a 3W amp, as do many of my customers. I haven't tried something smaller, in large part because I haven't got one! The extra efficiency of the Purple Speaker might lend itself to things of the 1w variety. I'm thinking of that 3/4W triode amp that is popular. . . can't recall the name. . . Or the S.E.X. amp, or a Decware Zen. The slightly lower Q (compared to the Betsy) maybe work well too, as many smaller tube amps will have highish output impedances. And I do know that technically you'd want more like 100db for amps that small, but again, we're talking near field.
Paul Wild Burro Audio Labs - DIY Full Range Speakers |
#24 |
jpechloe,
That is a nice looking design! At this point, the BetsyK isn't available without the whizzer attached. I could probably get you a pair, but you'd have to pay up front and it could be awhile (a couple of months). I think it would be fairly easy to just cut the whizzer assembly off, if thats what you want. The BetsyK voice coil stands a little proud of the cone, which gives you some room to work. I've got plenty of extra whizzers. let me know, Paul Wild Burro Audio Labs - DIY Full Range Speakers |
#25 |
diy 6EM7 amp
That is exactly the sort of little tube amp that would mate well with a pair of these! Somebody should buy that, even if you don't get the speakers. Paul Wild Burro Audio Labs - DIY Full Range Speakers |
#26 |
my amp use 6em7 as input/driver stage work fine the second triodeis like a mini 2A3 .... the RCA not coin base sound sweet ...but my sugggestion is dht output tubes like a 46
Sic58
#27 |
grrrrr. the freight kills it... Nice units Paul - and congrats on keeping the profit motive at bay!
"Folks, you can't prove truthiness with information. You prove truthiness with more truthiness. In a process known as truthinessiness." - Stephen Colbert, The Colbert Report |
#28 |
Nicoch, I know you were thinking DHT. I wanted to be inclusive of all budgets and little tube amps. I wish I had some 45/46 action here! The closest I come is my 12B4 pre, and I know that isn't at all the same.
You just need to round up a few more folks. Shipping isn't that bad spread across four or so pairs! Paul Wild Burro Audio Labs - DIY Full Range Speakers |
#29 |
Well, if anybody else in OZ is interested, post here and we will see what we come up with. Postage to OZ is the issue: I own a Post Office, so getting them distributed around is easy once they are here...
#30 |
The big whizzers arrived earlier than I anticipated! So, for those that are waiting, I'll ship tomorrow. For those thinking of ordering, I'll be gone from Wednesday through the weekend. So, if you order through late tomorrow night, I should be able to get them off. Otherwise I won't be shipping again until Monday.
| 8" and smaller fullrange vs 12" and up fullrange in OB | c3conv | Full Range | 11 | 24th August 2010 05:59 AM |
| WTB 15" or 18" high qt. drivers | homemade | Swap Meet | 13 | 14th June 2010 07:15 PM |
| What can I do with an Oaktron High Fidelity 15" in a purple basket? | Foolforaradio | Multi-Way | 2 | 6th August 2008 04:05 PM |
| bass cabinet build two 18" speaker.. help | szgabor | Multi-Way | 3 | 7th August 2004 01:23 AM |
