Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz - Page 122 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 2nd February 2015, 03:59 PM   #1211
RollE2k is offline RollE2k  Sweden
Originally Posted by Marek View Post
Søren,
what about synchronous mode of dam1021? (external MCLK and I2S signals are synchronous). My I2S source is Amanero slaved to external Ian's XO board (with two Crystek XOs) which reclocks all I2S lines and provides very low jitter MCLK output.
Is it possible to enable this feature in future firmware release?
Marek, you have to read up regarding this dac, because this is already one of the main features of this dac. It already have a fifo built in - and it doesnt even need mck input, so there is no sync or async for this dac, as it is with ess-dacs.
Old 2nd February 2015, 04:11 PM   #1212
Dimdim is online now Dimdim  Greece
Originally Posted by randytsuch View Post
Curious why you didn't use the same USB source (PC versus touch) for the Amanero module?
At any rate, thanks for the comparison, it gives me some motivation to hurry up and get my dam dac working.
Randy
I didn't use the same source because I wanted to have both of the DACs playing the same material simultaneously. Then I was able to switch between them by selecting a different source on my preamp.
Considering that I used 2 identical Amaneros, I didn't think that the differences between the laptop and the SBT would be significant.
http://www.dimdim.gr
Old 2nd February 2015, 04:34 PM   #1213
OK, I understand why you did that, makes it easier to ab.
So a suggestion, can you try swapping the PC and SBT, and see if you get the same results?
I have been upgrading my music PC, and some of the upgrades did make rather significant changes. And I have an Amanero feeding my DAC.
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 2nd February 2015, 05:52 PM   #1214
Marek is offline Marek  Poland
I know that,I got dam1021 on my desk working with Amanero.
The goal is avoiding anoying clicks and mute when syncing after rewind or sample rate change. In synchronous mode there is no need to use onboard dejittering (and I don't need it because I got very low jitter I2S source already) and FPGA will only prepare signals for registers. Its sad that there are no reclocking after FPGA...Potato FF would be the best choice.
Anyway, dam1021 has 'FPGA MCLK OUT' on header so it is almost sure that this pin can be configured as input.
Old 2nd February 2015, 06:02 PM   #1215
Sorry - i thought it was one of those posts, when people hadn't read-up what it was all about.
But yes, i can agree that it would be good if the reclocking was after the FPGA, and also i would perfer the possiblity for better clocks than silabs. But, this will still be better than 99% of the market. And there is always a possiblity for a version 2.0 later on if it sells good, and Sören likes to experiment more :-)
Old 2nd February 2015, 06:23 PM   #1216
dimdim,
Thanks for your blog!
I was wondering how I was going to figure out how to upgrade the firmware.
Got lucky, my music computer board has an RS232 jack - GIGABYTE H81M-S2PV. Board has good BIOS adjustability, too, if someone is looking ...
Looking forward to future posts.
Thanks, again,
Rick McInnis
Old 2nd February 2015, 09:23 PM   #1217
Randy
I will definitely try that and let you know!
Dimitris
Old 2nd February 2015, 09:27 PM   #1218
Originally Posted by rickmcinnis View Post
dimdim,
Thanks, again,
You are quite welcome Rick.
I use my blog like a notebook. I keep notes of things that took me at least an hour to figure out. I like the idea that others are benefiting from my experience (and time).
Old 2nd February 2015, 09:48 PM   #1219
tods is offline tods  Germany
Have it running with WaveIO.
The WaveIO has its own isolator, so I had to power them both.
cheers
Torsten
Old 2nd February 2015, 09:50 PM   #1220
TNT is offline TNT  Sweden
Whats the "PLOP" situation with the WaveIO?
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
Copyright ©1999-2017 diyAudio
