Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz - Page 121 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 1st February 2015, 02:03 PM   #1201
Did anyone try with WaveIO?
Old 1st February 2015, 03:26 PM   #1202
Dimdim is online now Dimdim  Greece
I made a little video demonstrating how the board handles switching between different sampling rates, both with 0.8 and 0.9 firmware. You can see what the serial console outputs while the changes are being made.
https://www.youtube.com/watch?v=JxcbBjktgCw
I tested with sampling rates up to 352.8KHz.
Playback chain is Windows Laptop -> Amanero -> DAM1021 -> SE output to preamp.
You will notice that I am not getting any plops, just a tiny 'click'. Later I will try the balanced output straight to my Hypex 400HG amp.
http://www.dimdim.gr
Old 1st February 2015, 08:43 PM   #1203
Default Use dam dac for native DSd decoding
Originally Posted by soekris View Post
No, DSD is digital serial signal, a digital lowpass filter in the FPGA convert it to a PCM digital parallel signal. See Direct Stream Digital - Wikipedia, the free encyclopedia for more info on DSD.
Hi Soekris
For DSD decoding, Is it possible to program the dam dac as a simple 1bit pure DSD decoding dac?
No digital filter at all, just use the whole r2r dac as a 1 bit
For example , when dsd signal =1, set all r2r bits to high, when dsd=0, set all r2r bits to low.
2.844mhz should be ok for ur dac right?
Also, u can set the r2r high/low level for bit perfect volume control.
What do you think?
Old 2nd February 2015, 10:31 AM   #1204
I've done a quick A-B test of the dam1021 versus my Buffalo III DAC.
The playback chain was as such:
1) Laptop (i7, 16GB RAM, SSD, etc) running Windows 8.1 with Foobar, ASIO out to Amanero, I2S to dam1021, single ended output to AD797-based SE preamp
2) Squeezebox Touch with EDO firmware connected to Amanero, I2S output to B III w/ IVY III I/V stage (all powered by Salas BiB power supplies), single ended output to AD797-based SE preamp
The preamp was connected to my Hypex 400HG amp through single ended connections. My speakers are the Arcos II speakers.
The levels were matched by ear (I had to lower the Buffalo's output by 2dbs).
The music used was classic rock as well as some pop.
The end result was favorable for the dam1021. It had better dynamics, more detail, and perhaps a little better control of the bass. All in all, I couldn't say that the Buffalo was better in any respect.
Next step will be to compare the DACs using the balanced outputs directly on to my Hypex amp. There the Buffalo will have an advantage due to its true balanced design, so it will be an interesting comparison.
Old 2nd February 2015, 11:02 AM   #1205
As I'm not getting any plop's here with my diyinhk usb interface I will procure an amanero for testing, the plops need to, and will be eliminated....
Søren, which DIYINHK interface are you using? Does it require en external psu?
Old 2nd February 2015, 11:20 AM   #1206
soekris is offline soekris  Denmark
Don't know, their standard basis one ? For some reason it didn't have the parts needed to take power from the USB line but have space on the PCB, I had to add those parts (a 3.3V regulator and a couple of passives). It can then supply power to the isolators on the dam1021.
Søren
Old 2nd February 2015, 12:11 PM   #1207
Did a bit of a dress rehearsal with a diyinhk
I've no plopping noise either
done no comparisons or critical listening as of yet but it certainly doesn't sound ordinary
I used direct ac in and pc power to the diyinhk i2s and still manages not to sound ordinary
will try amanero next
Old 2nd February 2015, 02:15 PM   #1208
sounds encouraging~
Old 2nd February 2015, 03:32 PM   #1209
Curious why you didn't use the same USB source (PC versus touch) for the Amanero module?
At any rate, thanks for the comparison, it gives me some motivation to hurry up and get my dam dac working.
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 2nd February 2015, 04:30 PM   #1210
Marek is offline Marek  Poland
Søren,
what about synchronous mode of dam1021? (external MCLK and I2S signals are synchronous). My I2S source is Amanero slaved to external Ian's XO board (with two Crystek XOs) which reclocks all I2S lines and provides very low jitter MCLK output.
Is it possible to enable this feature in future firmware release?
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 06:11 PM
384 Khz DAC? SunRa Digital Source 8 2nd October 2009 12:14 AM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 06:14 PM
Copyright ©1999-2017 diyAudio
