VSSA Lateral MosFet Amplifier - Page 226 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 23rd August 2013, 12:25 PM   #2251
BYRTT is offline BYRTT  Denmark
Quote gannaji post 2250: Hi gannaji, after public v1.4 this thread went "Commercial sector", please respect.
kindly answer:
Your request say purpose is for education and learning hmmmm, then i say read this hole thread it is top stuff for education and learning, and when you have read hole thread you are able to compile same schematic as i have = learning. If you after have read the hole thread not are able to nearly understand circuit and compile nearly same schematic as shipped, then i claim your skills is at such level that if you got copy of mine v1.4x, you won't understand anyway = no learning.
Digging into this thread will also take you to 4 x other very hot VSSA version threads.
And remember i am hobbyist, so how true is my v1.4x.
Skeptical answer:
Truth is that v1.3 is splendeed for engineering education and learning, final version is just tuneup for real world stability and performance, what do you need this for ?
If you have hidden agenda/purpose behind request, for example build your own private high performance amp or go commercial production by your own, i suggest: Contact author to participate in group buy (for private amp), or negotiate with author about OEM possibility.
Last you could try request author for final version.
Ricky
Old 25th August 2013, 12:22 PM   #2252
analog_sa's Avatar
BYRTT 8 PCB set
CaféNoir 6 PCB set
ColinAlex 8 PCB set
DavorXXL 6 PCB set
DuffyDawg 4 PCB set + 4 SMPS400
electromf 4 PCB set
badrisuper 2 PCB set
volavola 2 PCB set
JethroTull 2 PCB set
kp93300 2 PCB set
momomo67890 4 pcb set
ua3grn 6pcb set
mj777 2pcb set
mkusan 2pcb set
Odysseas 4pcb (2 pairs)
hcbonfim 2pcb set
Albrerta 2pcb set
dw1narso 2 pcb set (1 stereo) + extra output device pairs & isolators (for stereo if possible)
supernet 2 pcb set
milandks 4pcb set
tjencks 2pcb set
quanghao: 2pcb set
audionootje: 4pcb set (2x stereo)
tritosine 4pcb (2 pairs)
Bobo le Chat 2 pcb set
AP2 2pcb set+2pcb empity (i need this also)
Meganinja 2 set ( stereo )
mikvous 2 pcb set
Rick G 2 PCB set
kindhornman 2 boards
ravid 2 pcb set
siberia 2 pcb set
gnat 2 pcb set
potepuh 2 pcb set
metallicus69 4 pcb set
Ranchu32 2 pcb set
woofertester 4 pcb set
edbk 4 pcb set
Raj1 2 pcb set (or 6 if available)
analog_sa 3pcb set + extra output device pairs & isolators (for stereo if possible)
Old 25th August 2013, 01:00 PM   #2253
mravlca is offline mravlca  Slovenia
mravlca's Avatar
BYRTT 8 PCB set
CaféNoir 6 PCB set
ColinAlex 8 PCB set
DavorXXL 6 PCB set
electromf 4 PCB set
volavola 2 PCB set
kp93300 2 PCB set
ua3grn 6pcb set
mj777 2pcb set
mkusan 2pcb set
hcbonfim 2pcb set
Albrerta 2pcb set
supernet 2 pcb set
milandks 4pcb set
tjencks 2pcb set
quanghao: 2pcb set
mikvous 2 pcb set
Rick G 2 PCB set
ravid 2 pcb set
siberia 2 pcb set
gnat 2 pcb set
potepuh 2 pcb set
Ranchu32 2 pcb set
edbk 4 pcb set
mravlca 2pcb set
Old 25th August 2013, 01:28 PM   #2254
Default VSSA Transistor Matching
Of the people who have built the SSA/VSSA/TSSA, who matches transistors by measuring at operating current and voltage?
I am about to start building an SSA and a VSSA. I have bought 2SA970, 2SC2240, MJE340, MJE350, etc. I have tested 10 pcs from each batch at Ic = 2mA at Vce = 40V. The input pair for VSSA has a Vce of about 40V from my calculations.
I set Vce to 40V and then adjust Ib from very small to about where Ic= 4mA and measure Beta throughout.
The MJE transistors were measured at Ic = 10 mA.
The values for Beta leave me absolutely no pairs of NPN/PNP transistors that match.
Here are the ranges for Beta
MJE340STU 91.4 - 104.8
MJE350STU 144.0 - 155.2
2SC2240-GR 279.7 - 356.9
2SA970BL - 509.4 - 632.0
KSA1381ESTU 126.5 - 134.3
KSC3503DSTU 79.0 - 80.5
I need to find some KSC3503E.
My goal is to get matched pairs. I believe that offset will be easier to control and distortion will be lower with matched pairs.
Withing a particular part number, identical matches abound.
Suggestions and comments are welcome.
Old 25th August 2013, 03:01 PM   #2255
2SC3502E are just as good as the ones you look for, it just have a 200 Vce limit.Other then that it`s the same device. they are available on ebay.. i got some and they tested good.
2SC3502E 2SC3502 Trans GP BJT NPN 200V 0 1A 3 PIN TO 126 | eBay
Old 25th August 2013, 08:47 PM   #2256
Cuda is offline Cuda  France
Hello,
What must I change on the schematic if I replace the LATFET with Sanken STD03 thermaltrack darlington
Old 26th August 2013, 09:16 PM   #2257
Lazy Cat's Avatar
Hi cuda
No problem at all, integrated thermal tracking (sensing) diodes should become a part of a TL431 bias generator, to prevent thermal runaway ie. to compensate PTC of a darlington pair.
Old 26th August 2013, 09:23 PM   #2258
Lazy Cat's Avatar
Old 26th August 2013, 09:35 PM   #2259
Way to go LC. Looking forward to hearing these!
Old 26th August 2013, 09:40 PM   #2260
Rick G is offline Rick G  United States
Rick G's Avatar
Those Pic's will make a LOT of people Happy, not to mention You!
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 10:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 06:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 11:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 06:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 07:49 PM
Copyright ©1999-2017 diyAudio
