| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#331 | |
![]() And here's the Impulse Response on the design axis: ![]() Jeff |
#332 |
just another
Hi Joachim, very nice first attempt! very good phase tracking between the drivers. Interesting null, it looks similar to the first iteration of my MTM crossovers null... what was the target crossover freq out of interest?
Tony. |
#333 | |
#334 |
Not much, it's only 14 degrees. I posted the measured response a few posts up so you can see there's no droop in the top octave at this angle. In reality if I raise the mic and angle it at the tweeter the response would be rising a bit more above 12khz, so the angle does help to flatten the forward radiating energy a tiny bit.
#335 | |
What's your baffle dimension (baffle width and baffle edge round-over)? I'm a bit curious because, when I started some simple quick and dirty cross-over simulations based on these measurements I found out that the baffle step where a bit more complicated than usual to take care of, at least when I simulated LR2 filter with 3kHz x-over point and didn't want an excessive amount of components. If I lower the x-over point to about 2.4kHz it looks easier. When I measured my Satori mid-woofer I used an 24.8cm wide baffle with (r=18mm) round-over for the baffle edges and get a broad hump (+5dB) centered at approximately 800Hz and f/2 at 570 and 1150Hz. For comparison: ![]() Measured @ Tweeter-axis, on-axis. Blue = Satori MW16P-4 (24,8cm baffle, r=18mm round-over) Red = ScanSpeak Revelator 15W/4531G00 (21,6cm baffle, r=12mm round-over) Green = AudioTechnology 15H520613SDK (21,6cm baffle, r=12mm round-over) Happy New Year! ![]() /Göran
Author of the "AudioExcite Loudspeaker Design" website http://www.audioexcite.com |
#336 |
I did not find the baffle step to be troublesome at all. However, you will find with a driver like this on this size baffle that the simplest crossover will typically net a crossover point close to 2 kHz or over lower. I never force a crossover (meaning pick the crossover point in advance and try to force that to be my crossover point). You will find that depending on the woofer and tweeter's natural response, their phase response, and the offset between the drivers, that with certain acoustic slopes there is a natural crossover point that you can arrive at with very simple electrical circuits and achieve the correct phase alignment at the same time. In my case the crossover in my Kairos speaker is a hair under 2 khz (about 1.9kHz, but slopes are gradual in this region). If I tried a higher crossover point, like 3khz, which I experimented with, then the circuits picked up considerably more elements. And remember, crossover types like LR2 or LR4 are always a combination of the driver's natural roll-off and the circuit's transfer function. In other words, for an LR4 crossover, if the tweeter is begining to roll-off naturally second order around 1-2 kHz then all you may need is a second order circuit to achieve a perfect LR4 response. And of course, if the drivers are on a flat baffle, then asymmetrical roll-offs are usually required to compensate for the relative offset of acoustic centers and arrive at good phase tracking (within the crosover region). Jeff |
#337 | |||
![]() Quote:
Picture 2: Experimental 2.4kHz LR2 x-over Picture 3: Mid-woofer 15deg off-axis, effect of LCR Sorry Joachim it wasn’t my intention to hijack your thread, but I was a bit curious and thought it was interesting to compare the different baffle dimensions we used, yours 30cm wide baffle and Jeffs 22.9cm and my 24.8cm. ![]() /Göran
#338 |
Göran, do not worry, your experiments are interesting and helpful.
Jeff, great work you did. I placed the crossover at ca.2.1kHz. Yes it seems to be that lower crossover points work better with the Satori Mid-Woofer. I prefer lower crossover points anyway to stay out of the problem zone in the upper range. The Satori is very extended but does not work as a perfect piston any more higher up. Fortunately modern tweeters are quite extended in the deeper regions too. Yes, the DIY version of the cabinet i designed has a straight baffle with the woofer on a thinker baffle but the professionally made cabinets made by SB will have an angled baffled, not much different then Jeffs design. I posted a rendering of that version some time ago. |
#339 | |
But true LR crossovers also have coherent phase between the crossed drivers. If you replace half the electrical filter with acoustic rolloff don't you lose that phase coherency? A 4th order electrical filter twists the phase faster than 2nd order electrical. I can understand that the rising inductance of the woofer coil adds some phase in the right direction, but does it change fast enough to match an electrical 4th order filter? I understand the low end roll off of the tweeter to be caused by decreasing acoustic impedance which I think will not affect its phase at all, but resonance affects phase. So is it really a true Linkwitz-Riley 4 crossover since phase is not necessarily coherent all the way through the filter band? Or is it? I see this point made occasionally, that acoustic slope is what matters, but I never had opportunity to ask for clarification about phase until now. It is rare to have accomplished designers willing to share their expertise as you guys are here. Thanks! Rich |
#340 |
Yes, it is the acoustic response that matters. That has the consequence that the crossover schematic does not look like a textbook example at all.
I have made L/R4 and L/R2 filters many times where the phase matched over a very wide range. I do that usually with LSP-CAD and do the rest by trimming with hand while watching the individual phase window. Here is a picture how the prototype box looks at the moment. I will round the edges and sink in the drivers. After this i will fine tune the crossover. When the factory made cabinets come i will have to fine tune again. While Jeff has made a phase linear version and Göran is working on an L/R4 i will stick to the L/R2. We have a lot of options then. |
| SB Acoustics 3 ways | cosmindaniel12 | Multi-Way | 18 | 1st June 2012 05:52 PM |
| More T/S specs needed for SB Acoustics | mcmahon48 | Multi-Way | 2 | 15th August 2010 12:34 PM |
| All SB Acoustics MTM ?? | Andy G | Multi-Way | 12 | 26th September 2009 12:35 PM |
| Anybody familiar with SB Acoustics | zimjj | Multi-Way | 0 | 13th March 2009 10:30 PM |
| SB Acoustics... The stuff looks good | sardonx | Multi-Way | 20 | 16th February 2008 08:15 AM |
