| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#361 |
#362 |
I think at me.
But as I don't know what is actually set by the new header on the Buffalo III SE it is difficult to say if qusp is right or wrong. |
#363 |
#364 | |||
is choosing a less facetious title...
I had actually taken it as essential but I guess the default PCM values for the filter work, but are just not really ideal. I dont use BIII as you know so checked the guide for you, see below. Quote:
so adjust to taste Last edited by qusp; 21st September 2012 at 05:25 PM. |
#365 |
yes, your diagram is correct. for some annoying reason the manufacturers still do not all comply to a standard naming. for the PCM179X series and some other dacs SCK is MCLK and the S is for System Clock, not Sample Clock as it can sometimes mean, which is the same as BCK.
#366 |
thanks for the reply.
but no sound come out, i am thinking, the pin 7 put high is dsd on, should i connect it to pin 8"gnd" to make it 0v? |
#367 |
Thanks to everyone who has replied about my noise problems. I discovered that one of my CAT5 wires was cut a little when I stripped the wires, so I reterminated, but that didn't change anything.
With my hackintosh home theater pc, I get a constant 4khz noise that is there regardless of sample rate (although I haven't tried DSD yet). My hackintosh runs Lion, and has a Gigabyte H67N-USB3-B3 motherboard. I pulled the firmware chip, and the noise persisted. I tried my HP hackintosh laptop using batteries, and the noise disappeared. I didn't try with the power supply connected to the laptop yet. Apparently the USB ports on my hackintosh cause a 4khz noise. Any suggestions for how I can fix this noise problem? I would like to use this computer with the Amanero. Would upgrading the computer's power supply (it is just the cheapo one that came with the case), or getting a USB PCI card make a difference? I have thought about rebuilding with an external linear power supply, but that would be a bit down the road. I still get "crunchy" noises that sound like dropouts. I get them with both the laptop and the PC, and I get them with and without the firmware chip installed in the Buffalo II. I never installed the LED's for lock and mute when I built my Buffalo. I'll have to go back and install them, and order the "best" firmware from TP. Is the default setting when I pull the firmware chip "best"? Sorry to hijack this thread with my questions about my specific implementation. I think that there are a lot of people who will use this board with a Buffalo II (I have the 80mhz version), so perhaps this will be helpful to more people than just me. Thanks to everyone for their help and suggestions. -Aaron. |
#368 |
hmm get actual mac mini? theres a suggestion
#369 |
Realizing that I am about to officially expose that I am a complete ignorant, talking about things I know nothing about, I have a fast OT question......
DSD over USB ![]() Does this require a music file in "DSD format" or are any type of music files converted by the PC software to this format before being send as USB "signal"? I am familiar with the DSD signal I tap from my SACD player, but I have never played with DSD/DXD files on my Mac..... Again, sorry for the OT. Cheers, Nic |
#370 | |
Did you use a USB cable with ferrite ? |
| HLLY USB SPDIF/ I2S CONVERTER | kp93300 | Digital Source | 12 | 29th January 2012 02:55 PM |
| exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 0 | 11th November 2011 11:41 AM |
| $40 USB to I2S converter | sharpi31 | Digital Line Level | 7 | 12th July 2009 04:09 PM |
