USB to I2S 384Khz - DSD Converter - Page 100 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 1st December 2012, 12:08 AM   #991
Good news for those intending to use the Amanero with an ES9023 based DAC, this inexpensive chip plays both 352.8 and 384KHz even if the data sheet states max accepted sample rate is 192.
We have tested this on three identical DACs, two in sync mode running on the Combo384's XOs and one running in async mode with a local 50KHz XO. All 3 DACs played 384 fine and 2 played 352.8 fine, the third (using a different firmware/driver) had noise when playing this sample rate.
Given the scarcity of such material is not that relevant but may be interesting for testing purposes.
Old 1st December 2012, 04:36 AM   #992
I did a test on a WM8741 DAC. PCM is very fine and i like that sound.
The experiment of DSD playback has also succeeded. But the gain of DSD is so low comparing to PCM decoding. Why? i don't understand.
The L/R channel is not correct and seems to be inverse, Combo384 just updated to latest version 1.056.
Old 1st December 2012, 04:43 AM   #993
Native DSD playback: J.River 18, KS, DoP Bitstreaming, Volume disabled.
Old 1st December 2012, 07:33 AM   #994
supra is offline supra  Australia
Just finished an Amanero/Buff3SE. Easy to connect and get going. DSD fine, PCM all good except noise and distortion on native 352Khz wav files and 44.1 upsampled to 384Khz, 176Khz upsampling is fine.
Hopefully will be bandwidth adjustment on buff3.
Old 1st December 2012, 08:50 AM   #995
Supra,
what drivers and firmware are you using?
Is the problem the same at both 352.8 and 384?
Old 1st December 2012, 09:00 AM   #996
Originally Posted by Jackal29a View Post
Supra,
Latest driver and firmware, JRiver, didn't have this problem with buff2, suspect it is a matter of finding right settings on dac, I hope!
Yes both 352 and 384.
Still prefer exa u2i for PCM, but the amanero is sensational on DSD.
Old 1st December 2012, 09:15 AM   #997
I'd suggest you try the Amanero with a HQ external PS, A Salas BiB definitely improved SQ of my Amanero. This way you can get closer noise performance to the ExaU2I's isolated USB input.
If your problem happens with both sampling rates then is not the same as mine, I can play 384 perfectly, I only get noise with 352.8.
Old 1st December 2012, 11:19 AM   #998
I suspected the exa had better isolation, thanks for the advice, I will look into that.
Old 1st December 2012, 11:38 AM   #999
qusp is offline qusp  Australia
qusp's Avatar
you mean SOME isolation
Old 1st December 2012, 01:02 PM   #1000
Whatever. qusp you can be tiresome.
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 12:41 PM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
Copyright 1999-2017 diyAudio
