Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 1st February 2013, 01:52 PM   #91
Orion33 is offline Orion33  Russian Federation
Originally Posted by locky_z View Post
You can goto
CurveTracer : Locky_z's Curve Tracer
and download V3.5(2012.8.12)
Can you attach it here?
Old 1st February 2013, 09:20 PM   #92
buzzforb's Avatar
Locky,
I have the the tracer workinf again, but now I am getting very ragged response and cannot even measure in the same way before. Seems unstable. I replaced both the PMos and the Q7 with alternate transistors. I assumed this was not an issue due to the fact that they are not active in the actual measuring process/ Could this be causing my problems? Also, Although I have never cased it up, shold this help performance, providing a sheild from RF or other interferences?
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 2nd February 2013, 01:28 AM   #93
locky_z is offline locky_z  China
Q7 and PMOS measurement does not play a role, you can even shorted PMOS D-S. But the protect will disable.
You also can short the Q1 B-E/ Q2 B-E / Q3 B-E /Q4 B-E ,then The LM358 driving the test unit direct. Q1~Q4 not play any role. But you only can measure small signal device.
In this way to see whether the system is stableand.
Old 2nd February 2013, 08:27 AM   #94
buzzforb,
Have you tried to connect the oscilloscope to the measured transistor? Possibly occurs RF generation. If so, try to connect 1-10 nF capacitor between B and C or G and S.
Old 2nd February 2013, 08:48 AM   #95
buzzforb's Avatar
It's a new problem. Never had issue in the past
Curve Tracer Stefanoo Equipment & Tools 57 29th December 2012 12:00 AM
curve tracer barclaycon Equipment & Tools 6 11th February 2010 08:10 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
intelligent semiconductor characteristic curve instrument locky_z Parts 14 6th November 2008 11:07 PM
Copyright ©1999-2013 diyAudio
