hypex ncore - Page 711 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 8th September 2013, 04:26 PM   #7101
Julf is offline Julf  Europe
Originally Posted by bbest View Post
I could lower volume in foobar2000 music player, but it decrease sound quality.
Why would lowering volume decrease sound quality?
"To try to judge the real from the false will always be hard. In this fast-growing art of 'high fidelity' the quackery will bear a solid gilt edge that will fool many people" - Paul W Klipsch, 1953
Old 8th September 2013, 04:35 PM   #7102
Send a message via MSN to sq225917
bbest, with a 24 bit volume control and correct dither you need not worry about reduced quality until you are beyond -20db attenuation. With modern software replay applications it's not an issue.
hoping to pick up some things.
Old 8th September 2013, 04:42 PM   #7103
As in way beyond. Starting at 24 bit, and applying no dither, you still have 16 bits (96 dB) of dynamic range left even at -48 dB attenuation. Add dither, and you have much more.
Old 8th September 2013, 05:04 PM   #7104
bbest,
A stereo build with a passive attenuator in front of the amp modules should work too.
The question whether one prefers to mess around in the digital or in the analog domain. Personally I still believe more in high quality active preamplification
Old 9th September 2013, 10:04 PM   #7105
Hi guys,
All of a sudden one of my nCore modules is producing pink noise, even when volume is idle or muted. I tried the other 4 modules, trial and error, but no problem. Just this one. Any ideas?
Thanx
Old 9th September 2013, 10:07 PM   #7106
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Keeping these blighters cool is a problem. Not as good as other class D amps. The iron ware could be better quality in the choke.
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 10th September 2013, 10:10 AM   #7107
Crikey - glad I mounted mine in finned cases.
Old 10th September 2013, 10:13 AM   #7108
Thanks for answers guys!
Originally Posted by Juhleren View Post
bbest,
May be active preamplification will be best choise. Something like this Vorführverstärker - Seite 2 - DIY-HIFI-Forum. But I don't know where to buy this preamplify :-)
Old 10th September 2013, 02:00 PM   #7109
Depends - do you need active amplification and the functionality a preamp provides?
Old 10th September 2013, 02:02 PM   #7110
A few users have reported heat issues, but most people have reported their ncores running cool. Have you checked that your ones don't oscillate?
Hypex problem, who can help Hansms Class D 9 18th August 2013 06:49 AM
Hypex steveww Class D 14 18th November 2010 01:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 09:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 03:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 04:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
